had a problem with my nvidia driver for linux. I left my computer in standby mode for a while. When I turned it back on I entered my password then a new modal asked me for the password again but I couldn’t enter it. I switched off the computer using the power button and when I restarted my second screen, which works with the nvidia drivers, no longer displayed anything. I’ve had this problem before but now I can’t solve it. I’ve tried reinstalling the drivers but I always get this error
sudo ubuntu-drivers autoinstall
Reading package lists...
Done Build dependency tree...
Done Reading status information...
Done Some packages cannot be installed.
This may mean that you have asked for the impossible or,
if you are using the unstable distribution,
that some packages have not yet been created or have not been released from Incoming.
The following information should help you resolve the situation:
The following packages contain unsatisfied dependencies:
nvidia-dkms-545: Depends on: dkms but it is not installable E:
Unable to fix problems, faulty packages are in "keep as is" mode.
dpkg -l |grep nvidia
rc libnvidia-compute-470:amd64 470.223.02-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-545:amd64 545.29.06-0ubuntu0~gpu22.04.1 amd64 NVIDIA libcompute package
rc linux-modules-nvidia-535-6.2.0-33-generic 6.2.0-33.33~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.2.0-33
rc linux-modules-nvidia-535-6.2.0-34-generic 6.2.0-34.34~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.2.0-34
rc linux-modules-nvidia-535-6.2.0-35-generic 6.2.0-35.35~22.04.1 amd64 Linux kernel nvidia modules for version 6.2.0-35
rc linux-modules-nvidia-535-6.2.0-36-generic 6.2.0-36.37~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.2.0-36
rc linux-modules-nvidia-535-6.2.0-37-generic 6.2.0-37.38~22.04.1 amd64 Linux kernel nvidia modules for version 6.2.0-37
rc linux-modules-nvidia-535-6.2.0-39-generic 6.2.0-39.40~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.2.0-39
rc linux-modules-nvidia-535-6.5.0-14-generic 6.5.0-14.14~22.04.1+5 amd64 Linux kernel nvidia modules for version 6.5.0-14
rc linux-modules-nvidia-535-6.5.0-15-generic 6.5.0-15.15~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.5.0-15
rc linux-modules-nvidia-535-6.5.0-18-generic 6.5.0-18.18~22.04.1 amd64 Linux kernel nvidia modules for version 6.5.0-18
rc linux-modules-nvidia-535-6.5.0-21-generic 6.5.0-21.21~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.5.0-21
rc linux-modules-nvidia-535-6.5.0-25-generic 6.5.0-25.25~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.5.0-25
rc linux-objects-nvidia-535-6.2.0-33-generic 6.2.0-33.33~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.2.0-33 (objects)
rc linux-objects-nvidia-535-6.2.0-34-generic 6.2.0-34.34~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.2.0-34 (objects)
rc linux-objects-nvidia-535-6.2.0-35-generic 6.2.0-35.35~22.04.1 amd64 Linux kernel nvidia modules for version 6.2.0-35 (objects)
rc linux-objects-nvidia-535-6.2.0-36-generic 6.2.0-36.37~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.2.0-36 (objects)
rc linux-objects-nvidia-535-6.2.0-37-generic 6.2.0-37.38~22.04.1 amd64 Linux kernel nvidia modules for version 6.2.0-37 (objects)
rc linux-objects-nvidia-535-6.2.0-39-generic 6.2.0-39.40~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.2.0-39 (objects)
rc linux-objects-nvidia-535-6.5.0-14-generic 6.5.0-14.14~22.04.1+5 amd64 Linux kernel nvidia modules for version 6.5.0-14 (objects)
rc linux-objects-nvidia-535-6.5.0-15-generic 6.5.0-15.15~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.5.0-15 (objects)
rc linux-objects-nvidia-535-6.5.0-18-generic 6.5.0-18.18~22.04.1 amd64 Linux kernel nvidia modules for version 6.5.0-18 (objects)
rc linux-objects-nvidia-535-6.5.0-21-generic 6.5.0-21.21~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.5.0-21 (objects)
rc linux-objects-nvidia-535-6.5.0-25-generic 6.5.0-25.25~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.5.0-25 (objects)
rc linux-objects-nvidia-535-6.5.0-26-generic 6.5.0-26.26~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.5.0-26 (objects)
ii linux-objects-nvidia-535-6.5.0-27-generic 6.5.0-27.28~22.04.1+2 amd64 Linux kernel nvidia modules for version 6.5.0-27 (objects)
ii linux-objects-nvidia-535-6.5.0-28-generic 6.5.0-28.29~22.04.1+2 amd64 Linux kernel nvidia modules for version 6.5.0-28 (objects)
ii linux-signatures-nvidia-6.5.0-27-generic 6.5.0-27.28~22.04.1+2 amd64 Linux kernel signatures for nvidia modules for version 6.5.0-27-generic
ii linux-signatures-nvidia-6.5.0-28-generic 6.5.0-28.29~22.04.1+2 amd64 Linux kernel signatures for nvidia modules for version 6.5.0-28-generic
Please post the output of dpkg -l |grep nvidia
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
It gets installed alongside the driver. Since nearly no packages got installed, the file is missing.
Please try installing the modules
sudo apt install linux-modules-nvidia-$(uname -r)
and then the rest of the driver
sudo apt install nvidia-driver-535
sudo apt install linux-modules-nvidia-$(uname -r) Reading package lists... Done Build dependency tree... Done Read status information... Done E: Unable to find the package linux-modules-nvidia-6.5.0-28-generic E: Unable to find a package matching the regular expression "linux-modules-nvidia-6.5.0-28-generic".
I have test with the result of uname -r :
sudo apt install linux-modules-6.5.0-28-generic
linux-modules-6.5.0-28-generic is already the most recent version (6.5.0-28.29~22.04.1).
linux-modules-6.5.0-28-generic changed to "manually installed".
0 updated, 0 newly installed, 0 to be removed and 2 not updated.
Did you run sudo apt update beforehand?
Sorry, it should have read
sudo apt install linux-modules-nvidia-535-$(uname -r)
Réception de :1 http://download.opensuse.org/repositories/devel:/languages:/crystal/xUbuntu_22.04 InRelease [1.544 B]
Atteint :2 https://ppa.launchpadcontent.net/graphics-drivers/ppa/ubuntu jammy InRelease
Atteint :3 https://repo.radeon.com/amdgpu/23.20/amdgpu/ubuntu focal InRelease
Atteint :4 https://ppa.launchpadcontent.net/lutris-team/lutris/ubuntu jammy InRelease
Atteint :5 https://dl.winehq.org/wine-builds/ubuntu jammy InRelease
Atteint :6 https://download.docker.com/linux/ubuntu jammy InRelease
Atteint :7 https://packages.microsoft.com/repos/edge stable InRelease
Atteint :8 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy InRelease
Atteint :9 https://dl.winehq.org/wine-builds/ubuntu mantic InRelease
Atteint :10 https://ppa.launchpadcontent.net/ubuntu-x-swat/updates/ubuntu jammy InRelease
Atteint :11 https://repo.radeon.com/amdgpu/23.20/rocm/apt/5.7 focal InRelease
Atteint :12 https://download.sublimetext.com apt/stable/ InRelease
Atteint :14 https://deb.opera.com/opera-stable stable InRelease
Atteint :13 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy InRelease
1.544 o réceptionnés en 2s (698 o/s)
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances... Fait
Lecture des informations d'état... Fait
2 paquets peuvent être mis à jour. Exécutez « apt list --upgradable » pour les voir.
W: La cible Packages (main/binary-amd64/Packages) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible Packages (main/binary-all/Packages) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible Translations (main/i18n/Translation-fr_CA) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible Translations (main/i18n/Translation-fr) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible Translations (main/i18n/Translation-en_US) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible Translations (main/i18n/Translation-en) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible DEP-11 (main/dep11/Components-amd64.yml) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible DEP-11 (main/dep11/Components-all.yml) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible DEP-11-icons-small (main/dep11/icons-48x48.tar) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible DEP-11-icons (main/dep11/icons-64x64.tar) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible DEP-11-icons-hidpi (main/dep11/icons-64x64@2.tar) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible CNF (main/cnf/Commands-amd64) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible CNF (main/cnf/Commands-all) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/microsoft-edge-dev.list:3 et /etc/apt/sources.list.d/microsoft-edge.list:3
W: La cible Packages (non-free/binary-amd64/Packages) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible Packages (non-free/binary-i386/Packages) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible Packages (non-free/binary-all/Packages) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible Translations (non-free/i18n/Translation-fr_CA) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible Translations (non-free/i18n/Translation-fr) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible Translations (non-free/i18n/Translation-en_US) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible Translations (non-free/i18n/Translation-en) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible DEP-11 (non-free/dep11/Components-amd64.yml) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible DEP-11 (non-free/dep11/Components-all.yml) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible DEP-11-icons-small (non-free/dep11/icons-48x48.tar) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible DEP-11-icons (non-free/dep11/icons-64x64.tar) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible DEP-11-icons-hidpi (non-free/dep11/icons-64x64@2.tar) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible CNF (non-free/cnf/Commands-amd64) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
W: La cible CNF (non-free/cnf/Commands-all) est spécifiée plusieurs fois dans /etc/apt/sources.list.d/archive_uri-https_deb_opera_com_opera-stable_-jammy.list:1 et /etc/apt/sources.list.d/opera-stable.list:4
Sorry for the french text.
desperrois@desperrois-TUF-Gaming-FX705DT-TUF705DT:/etc/apt/sources.list.d
