I have the GEFORCE GTX 1050 GPU to use i installed the nvidia 884.98 driver using RHEL/CentOS 7.3 Bumblebee setup procedure from " http://ezequielm.com/blog/rhelcentos-7-3-bumblebee-setup/" on redhat 7.4 linux x86_64. The nvidia driver is installed according to the above blog i checked using “optirun nvidia-settings -c :8.0” command and got the Nvidia X server settings screen and when i used this commad “dmesg | grep bbswitch” also i got the following output.
21.900440] bbswitch: version 0.8
[ 21.900451] bbswitch: Found integrated VGA device 0000:00:02.0: SB.PCI0.GFX0
[ 21.900459] bbswitch: Found discrete VGA device 0000:01:00.0: SB.PCI0.PEG0.PEGP
[ 21.900618] bbswitch: detected an Optimus _DSM function
[ 21.900630] bbswitch: device 0000:01:00.0 is in use by driver ‘nvidia’, refusing OFF
[ 21.900634] bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is on
i think the driver is working. Next, i try to install the CUDA toolkit and i try to validate the successful installation of the toolkit using “nvcc -V” command and i got:
vcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2017 NVIDIA Corporation
Built on Fri_Sep__1_21:08:03_CDT_2017
Cuda compilation tools, release 9.0, V9.0.176
Next, i try to run the make command to run the CUDA sample before running the command “./deviceQuery” but i face an error as follows:
[root@localhost ~]# cd NVIDIA_CUDA-9.0_Samples
[root@localhost NVIDIA_CUDA-9.0_Samples]# make
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleOccupancy’
make[1]: Nothing to be done forall’.
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleOccupancy’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleMultiCopy’
make[1]: Nothing to be done for all’.
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleMultiCopy’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/matrixMul’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/matrixMul’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleCallback’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleCallback’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/vectorAdd_nvrtc’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/vectorAdd_nvrtc’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/template’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/template’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleCubemapTexture’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleCubemapTexture’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/cppOverload’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/cppOverload’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/cudaTensorCoreGemm’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/cudaTensorCoreGemm’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/systemWideAtomics’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/systemWideAtomics’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleIPC’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleIPC’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleVoteIntrinsics’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleVoteIntrinsics’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleSeparateCompilation’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleSeparateCompilation’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleTexture’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleTexture’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/UnifiedMemoryStreams’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/UnifiedMemoryStreams’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/cudaOpenMP’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/cudaOpenMP’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleSurfaceWrite’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleSurfaceWrite’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/cppIntegration’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/cppIntegration’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/inlinePTX_nvrtc’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/inlinePTX_nvrtc’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/clock_nvrtc’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/clock_nvrtc’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/fp16ScalarProduct’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/fp16ScalarProduct’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleTemplates’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleTemplates’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/matrixMulCUBLAS’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/matrixMulCUBLAS’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/vectorAddDrv’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/vectorAddDrv’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/matrixMulDrv’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/matrixMulDrv’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleAssert_nvrtc’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleAssert_nvrtc’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/cdpSimpleQuicksort’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/cdpSimpleQuicksort’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleStreams’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleStreams’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simplePrintf’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simplePrintf’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleLayeredTexture’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleLayeredTexture’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/clock’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/clock’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleVoteIntrinsics_nvrtc’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleVoteIntrinsics_nvrtc’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleCooperativeGroups’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleCooperativeGroups’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleZeroCopy’
make[1]: Nothing to be done for `all’.
make[1]: Leaving directory `/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleZeroCopy’
WARNING - No MPI compiler found.
CUDA Sample “simpleMPI” cannot be built without an MPI Compiler.
This will be a dry-run of the Makefile.
For more information on how to set up your environment to build and run this
sample, please refer the CUDA Samples documentation and release notes
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleMPI’
[@] mpicxx -I…/…/common/inc -o simpleMPI_mpi.o -c simpleMPI.cpp
[@] /usr/local/cuda-9.0/bin/nvcc -ccbin g++ -I…/…/common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleMPI.o -c simpleMPI.cu
[@] mpicxx -o simpleMPI simpleMPI_mpi.o simpleMPI.o -L/usr/local/cuda-9.0/lib64 -lcudart
[@] mkdir -p …/…/bin/x86_64/linux/release
[@] cp simpleMPI …/…/bin/x86_64/linux/release
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleMPI’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/cdpSimplePrint’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/cdpSimplePrint’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleTextureDrv’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleTextureDrv’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/vectorAdd’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/vectorAdd’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleAtomicIntrinsics_nvrtc’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleAtomicIntrinsics_nvrtc’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleAtomicIntrinsics’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleAtomicIntrinsics’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/inlinePTX’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/inlinePTX’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simplePitchLinearTexture’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simplePitchLinearTexture’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleMultiGPU’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleMultiGPU’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleTemplates_nvrtc’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleTemplates_nvrtc’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleP2P’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleP2P’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/asyncAPI’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/asyncAPI’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/matrixMul_nvrtc’
cp “”/usr/local/cuda-9.0"/include/cooperative_groups.h" .
cp “”/usr/local/cuda-9.0"/include/cooperative_groups_helpers.h" .
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/0_Simple/matrixMul_nvrtc’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleAssert’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/0_Simple/simpleAssert’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/1_Utilities/deviceQueryDrv’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/1_Utilities/deviceQueryDrv’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/1_Utilities/deviceQuery’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/1_Utilities/deviceQuery’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/1_Utilities/p2pBandwidthLatencyTest’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/1_Utilities/p2pBandwidthLatencyTest’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/1_Utilities/topologyQuery’
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/1_Utilities/topologyQuery’
make[1]: Entering directory /root/NVIDIA_CUDA-9.0_Samples/1_Utilities/bandwidthTest’
make[1]: Leaving directory /root/NVIDIA_CUDA-9.0_Samples/1_Utilities/bandwidthTest’
make[1]: Entering directory/root/NVIDIA_CUDA-9.0_Samples/2_Graphics/Mandelbrot’
“/usr/local/cuda-9.0”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o Mandelbrot Mandelbrot.o Mandelbrot_cuda.o Mandelbrot_gold.o -L/usr/lib64/nvidia -lGL -lGLU -lX11 -lglut
/usr/bin/ld: warning: libGLX.so.0, needed by /usr/lib64/nvidia/libGL.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libGLdispatch.so.0, needed by /usr/lib64/nvidia/libGL.so, not found (try using -rpath or -rpath-link)
/usr/lib64/nvidia/libGL.so: undefined reference to __glDispatchRegisterStubCallbacks’
/usr/lib64/nvidia/libGL.so: undefined reference to__glXGLLoadGLXFunction’
/usr/lib64/nvidia/libGL.so: undefined reference to _glapi_Current’
/usr/lib64/nvidia/libGL.so: undefined reference to__glDispatchFini’
/usr/lib64/nvidia/libGL.so: undefined reference to _glapi_get_current’
/usr/lib64/nvidia/libGL.so: undefined reference to__glDispatchUnregisterStubCallbacks’
/usr/lib64/nvidia/libGL.so: undefined reference to __glDispatchInit’
collect2: error: ld returned 1 exit status
make[1]: *** [Mandelbrot] Error 1
make[1]: Leaving directory/root/NVIDIA_CUDA-9.0_Samples/2_Graphics/Mandelbrot’
make: *** [2_Graphics/Mandelbrot/Makefile.ph_build] Error 2
What is the error that happed? and how to fix it?
Please i need solution highly!
