• DeepStream Version
• TensorRT Version
Hello ,
Iam running the sample model in deepstreamsdk-5.0.0 with RTSP input and iam getting the RTSP output URL.
Is there any way that i can store the output stream inside the docker container ??
Can you provide the basic information as following?
• TensorRT Version
Hardware Platform (GPU in which we are running docker container ) - (linux based)
Deepstream Version : 5.0.1
NVIDIA GPU Driver Version : 450.66
Which app is you using? Can you post your configuration file?
We found the working solution and its working fine .
Thanks for your response
