I am trying to update u-boot binary on Jetson NANO flashed with JetPack 4.3. I followed the steps on NVIDIA’s documentation in order to customize U-Boot. Copied the u-boot.bin to host system under {LINUX_FOR_TEGRA}/bootloader/t210ref/p3450-porg/ dir.
However, when I tried to create signed/encrypted boot.img.encrypt file for partition “LNX” in order to “dd” it on the target NANO, I got below error message:
*** Signing boot.img ***
./tegraflash.py --chip 0x21 --cmd "sign ./signed/boot.img.encrypt"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0031 ] Generating signature
Error: Not supported
Failed to flash/read t210ref.
Full log has been attached.
Also, it’s just not about u-boot partition flashing, this error occurs while trying to create encrypted binaries for other partitions. This issue is only for Jetson NANO, other Jetson products work as expected.
I can’t directly connect the target hardware to the host system, hence need to “dd” the encrypted binary. May I know what I could be doing wrong here?
