Hi, I’m experiencing an issue with my Mellanox ConnectX-5 NIC (MCX555A-ECA_Ax_Bx) and a QSFP28 module (INPHI CORP IN-Q2AY2-20-M1). The NIC is not enabling the High Power Class (>3.5W) for the module, which is capable of 5.0W operation.
Current status:
- NIC Firmware version: 16.35.3502
- QSFP28 module is recognized but operates in low power mode
- ethtool -m shows: “5.0W max. Power consumption, High Power Class (> 3.5 W) not enabled”
- PCIe link is operating at full capacity (Speed 8GT/s, Width x16)
- DISABLE_SLOT_POWER_LIMITER and ADVANCED_POWER_SETTINGS are both set to True(1)
I’ve tried:
- Adjusting NIC settings using mlxconfig
- Resetting the NIC using mlxfwreset
- Checking BIOS settings for PCIe power
However, I haven’t found a way to enable the high power mode for the QSFP module. Is there a specific setting or procedure to enable the 5.0W power class for this NIC and QSFP module combination? Any assistance or guidance would be greatly appreciated."
$ sudo ethtool -m enp23s0np0
Identifier : 0x11 (QSFP28)
Extended identifier : 0xcf
Extended identifier description : 3.5W max. Power consumption
Extended identifier description : CDR present in TX, CDR present in RX
Extended identifier description : 5.0W max. Power consumption, High Power Class (> 3.5 W) not enabled
Power set : On
Power override : On
Connector : 0x07 (LC)
Transceiver codes : 0x80 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Transceiver type : 100GE-DWDM2 (DWDM transceiver using 2 wavelengths on a 1550 nm DWDM grid with a reach up to 80 km)
Encoding : 0x08 (PAM4)
BR, Nominal : 25500Mbps
Rate identifier : 0x00
Length (SMF,km) : 80km
Length (OM3 50um) : 0m
Length (OM2 50um) : 0m
Length (OM1 62.5um) : 0m
Length (Copper or Active cable) : 0m
Transmitter technology : 0x50 (1550 nm DFB)
Laser wavelength : 1561.400nm
Laser wavelength tolerance : 0.025nm
Vendor name : INPHI CORP
Vendor OUI : 00:21:b8
Vendor PN : IN-Q2AY2-20-M1
Vendor rev : 10
Vendor SN : L2XXXXXXXX
Date code : 210330
Revision Compliance : SFF-8636 Rev 2.5/2.6/2.7
Module temperature : 0.00 degrees C / 32.00 degrees F
Module voltage : 3.3507 V
$ sudo mlxconfig -d /dev/mst/mt4119_pciconf0 q
Device #1:
Device type: ConnectX5
Description: ConnectX-5 VPI adapter card; EDR IB (100Gb/s) and 100GbE; single-port QSFP28; PCIe3.0 x16; tall bracket; ROHS R6
Device: /dev/mst/mt4119_pciconf0
DISABLE_SLOT_POWER_LIMITER True(1)
ADVANCED_POWER_SETTINGS True(1)
AUTO_POWER_SAVE_LINK_DOWN_P1 False(0)
