Unable to use gstreamer programmaticaly with nvjpegenc and opencv 4.1.1 simultaneously
I link my C++ software with opencv4.1.1 and g-streamer, when the c++ instruction
_jpegEncoder = gst_element_factory_make ("nvjpegenc", "jpegEncoder_0");
is executed, I got following error:
JPEG parameter struct mismatch: library thinks size is 584, caller expects 728.
I think the problem is located on the library libjpeg that now I use libjpeg.so.8 with new opencv. Before I was using libjpeg.so.6 with an older opencv. But I can’t find how I can make it works.
I tried something I’ve seen in the forum to replace libgstnvjpeg.so by libgstjpeg.so I don’t get the error anymore but it don’t work too.
You need to use either libjpeg.so or libnvjpeg.so. Please refer to related topic threads:
The main differences with your answer is that I don’t link my software with libjpeg or libnvjpeg directly.
I use opencv 4.1 which is dynamically linked with lib-jpeg.so.8
and
I use g-streamer programmaticaly in c++ and the command
uses libgstnvjpeg.so which seems to be statically linked with an old lib-jpeg
so I can’t change libjpeg to libnvjpeg because I can’t rebuild libgstnvjpeg.so (or sources are available somewhere I havn’t seen)
The only action I can do is to change the nvjpegenc by jpegenc into my g-streamer pipeline.
In order to do that, I made som tries in command line with gst-launch command.
> gst-launch-1.0 -vvv nvarguscamerasrc num-buffers=1 ! 'video/x-raw(memory:NVMM), width=(int)3280, height=(int)2464, framerate=2/1' ! nvjpegenc ! filesink location=test.jpg -e
This command works well and provide me a jpg.
When I use jpegenc instead of nvjpegenc I got following error
WARNING: erroneous pipeline: could not link nvarguscamerasrc0 to jpegenc0, jpegenc0 can’t handle caps video/x-raw(memory:NVMM), width=(int)3280, height=(int)2464, framerate=(fraction)2/1
jpegenc expects input frames from standard CPU memory. You would try adding nvvidconv for copying from NVMM to CPU memory:
gst-launch-1.0 -vvv nvarguscamerasrc num-buffers=1 ! 'video/x-raw(memory:NVMM), width=(int)3280, height=(int)2464, framerate=2/1' ! nvvidconv ! jpegenc ! filesink location=test.jpg -e
Thanks for your answer.
Yes I’ve just found the same solution. Here is the command line that’s works well:
gst-launch-1.0 nvarguscamerasrc num-buffers=1 sensor_id=2 ! 'video/x-raw(memory:NVMM), width=(int)3280, height=(int)2464, framerate=2/1' ! nvvidconv ! 'video/x-raw, format=(string)BGRx' ! jpegenc ! filesink location=test.jpg -e
But I would prefer to use the nvjpegenc because I think my performances will reduce making jpeg encoding with CPU instead of GPU.
Is there any other solution to use nvjpegenc ? Is it possible to have a more recent library ?
This may work:
gst-launch-1.0 nvarguscamerasrc num-buffers=1 ! 'video/x-raw(memory:NVMM), width=(int)3280, height=(int)2464, framerate=2/1' ! nvjpegenc ! filesink location=test.jpg -e
I cannot tell how to fix the jpeg lib mismatch with opencv. A solution may be using 2 processes (one gst-launch doing nvjpegenc, and your opencv app) communicating through shmsink/shmsrc.
It could be a solution to use shmsink/shmsrc but it complexify my software. I will take a look. thanks.
