I am running Ubuntu 18.04 and I don’t think my laptop recognizes my graphic card (Quadro P600 Mobile).
This is the result of lshw -c display:
*-display UNCLAIMED
description: 3D controller
product: GP107GLM [Quadro P600 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: latency=0
resources: memory:ec000000-ecffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:3000(size=128) memory:ed000000-ed07ffff
*-display
description: VGA compatible controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:131 memory:eb000000-ebffffff memory:80000000-8fffffff ioport:4000(size=64) memory:c0000-dffff
Any idea why the graphic card is ‘unclaimed’, and how to solve it?
PS: I am new to Linux
lshw prints “unclaimed” if no driver is installed for the device.
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post. You will have to rename the file ending to something else since the forum software doesn’t accept .gz files (nifty!).
Hi. I’m facing the same issue as well. Attaching bug report along.
nvidia-bug-report.log (1.4 MB)
None of the NVIDIA kernel modules are loaded. Do you have the drivers installed?
dpkg -l | grep -i nvidia
ii libnvidia-cfg1-460-server:amd64 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-460-server 460.73.01-0ubuntu0.20.04.1 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-460:amd64 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-460-server:amd64 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-460-server:i386 460.73.01-0ubuntu0.20.04.1 i386 NVIDIA libcompute package
ii libnvidia-decode-460-server:amd64 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-460-server:i386 460.73.01-0ubuntu0.20.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-460-server:amd64 460.73.01-0ubuntu0.20.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-460-server:i386 460.73.01-0ubuntu0.20.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-460-server:amd64 460.73.01-0ubuntu0.20.04.1 amd64 Extra libraries for the NVIDIA Server Driver
ii libnvidia-fbc1-460-server:amd64 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-460-server:i386 460.73.01-0ubuntu0.20.04.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-460-server:amd64 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-460-server:i386 460.73.01-0ubuntu0.20.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-460-server:amd64 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii libnvidia-ifr1-460-server:i386 460.73.01-0ubuntu0.20.04.1 i386 NVIDIA OpenGL-based Inband Frame Readback runtime library
rc nvidia-compute-utils-460 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA compute utilities
ii nvidia-compute-utils-460-server 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA compute utilities
rc nvidia-dkms-460 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA DKMS package
ii nvidia-dkms-460-server 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-460-server 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA Server Driver metapackage
rc nvidia-kernel-common-460 460.73.01-0ubuntu0.20.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-common-460-server 460.73.01-0ubuntu0.20.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-460-server 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.16~0.20.04.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 455.32.00-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-460-server 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA Server Driver support binaries
ii screen-resolution-extra 0.18build1 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-460-server 460.73.01-0ubuntu0.20.04.1 amd64 NVIDIA binary Xorg driver
What does dkms status say about the nvidia kernel module, and what happens if you run sudo modprobe nvidia manually?
I uninstalled all the nvidia drivers and followed steps here.
This time around, it prompted for a password (for secure boot) and I followed the steps as prompted. Everything works as expected now.
Thanks for your assistance.
$nvidia-smi
| NVIDIA-SMI 460.73.01 Driver Version: 460.73.01 CUDA Version: 11.2 |
| | | MIG M. |
| 0 GeForce RTX 207... Off | 00000000:01:00.0 On | N/A |
| N/A 45C P8 4W / N/A | 339MiB / 7982MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2322 G /usr/lib/xorg/Xorg 35MiB |
| 0 N/A N/A 3200 G /usr/lib/xorg/Xorg 84MiB |
| 0 N/A N/A 3365 G /usr/bin/gnome-shell 124MiB |
| 0 N/A N/A 3824 G ...AAAAAAAAA= --shared-files 80MiB |
