Uncoherent timing of convolution using CUDA events
I am trying to time a cudnn convolution operation (through PyTorch), using torch.cudnn_convolution. I am using cuda events to time the convolution operation. I have noticed that the frequency with which I refresh the convolution data (input and kernel) impacts the timing of the operation. This seems weird, as the only things between the CUDA events is the convolution itself. Would you have any idea of why this is?
I know this might be a pytorch issue, but (i) they have been quite unresponsive on their forums (ii) pytorch binds cuda events and cudnn events directly, so this also concerns Nvidia.
Below is the figures drawn to show this phenomenon (I have observed it, with various intensities, on various GPUs but I am limited to one image in this post) and the code used to draw it.
Windows, Torch 1.11.0, Cuda 11.3, RTX 3070 Laptop
Linux and torch 1.13.1+cu117 and A100
Last figure, linux, torch 1.13.1+cu117, RTX3060
## Imports
from typing import *
import torch
from tqdm.auto import trange
import numpy as np
from torch import Tensor
from torch.cuda import Event
from torch.backends import cudnn
import matplotlib.pyplot as plt
## Constants for convolution / data
BATCH_SIZE = 32
OUT_CHANNELS = 16
FM_SIZE = 64
KERNEL_SIZE = 3
cudnn_convolution_kwargs = dict(
    padding=(1, 1), stride=(1, 1), dilation=(1, 1), groups=1,
    benchmark=True, deterministic=True, allow_tf32=True
## Functions
def generate_data() -> Tuple[Tensor, Tensor]:
    # Generate ImageNet-like input
    x = torch.normal(mean=0, std=1, size=(BATCH_SIZE, 3, 224, 224), device='cuda')
    x *= torch.tensor((0.229, 0.224, 0.225), device='cuda').reshape((1, 3, 1, 1))
    x += torch.tensor((0.485, 0.456, 0.406), device='cuda').reshape((1, 3, 1, 1))
    # Generate properly initialized convolution weight
    w = torch.zeros((OUT_CHANNELS, 3, KERNEL_SIZE, KERNEL_SIZE), device='cuda')
    torch.nn.init.xavier_normal_(w)
    return x, w
def time_convolution(iters: int,
                     op_per_iter: int,
                     data_refresh_rate: int,
                     warmup_duration: int,
                     ) -> List[float]:
    cudnn.benchmark = True
    times = []
    # Warmup
    x, w = generate_data()
    for i in range(warmup_duration):
        torch.cudnn_convolution(x, w, **cudnn_convolution_kwargs)
    # Timing loop
    for i in range(iters):
        # Refresh data if needed
        if not i % data_refresh_rate:
        # Launch timing
        start, end = Event(True), Event(True)
        torch.cuda.synchronize()
        start.record()
        # Operation loop
        for j in range(op_per_iter):
        # End timing
        end.record()
        end.synchronize()
        times.append(start.elapsed_time(end) / op_per_iter)
    return times
## Script
if __name__ == '__main__':
    # Runtime constants
    ITERS = 200
    WARMUP = 1000
    # Accumulators
    drrs: List[int] = []
    means: List[float] = []
    medians: List[float] = []
    # Data-gathering loop
    for drr in trange(1, ITERS+1):
        ts = time_convolution(iters=ITERS, op_per_iter=1,
                            data_refresh_rate=drr, warmup_duration=WARMUP)
        drrs.append(drr)
        means.append(np.mean(ts))
        medians.append(np.median(ts))
    # Figure
    fig, ax = plt.subplots(1, 1, figsize=(12, 8))
    ax.plot(drrs, means, label='Mean')
    ax.plot(drrs, medians, label='Median')
    ax.set_title('Latency of convolution depending on its data refresh rate '
                 f"(measured on {ITERS} iterations)")
    ax.set_xlabel('Data refresh rate')
    ax.set_ylabel('Latency (ms)')
    ax.legend()
    plt.savefig('__tmp__.png')
    plt.show()
The 3 images/patterns you have posted all look different to me. There does not appear to be just one phenomenon to explain here. Is that your view as well?
Indeed, the pattern all look different, although they are from the same script. For the former, it might be because the laptop’s GPU gets throttled due to heat, but for number 2 and 3, that are two non-laptop GPUs with the same environment, the fact that the curves go in opposite way is surprising, maybe it’s something about the cache. Nonetheless, I have no explanation for the phenomenon, this is why I’m asking. Would you have a better guess?
I guess if I were doing this, I would want to see a careful measurement of the clock frequency in each case. That might be difficult to do if the overall test time is short.
GPUs tend to lower their clocks during idle periods. If the test has a significant (GPU) idle period in-between the test iterations, then having the data refresh is going to bump the clock back up before you get into the convolution that you are measuring. I would want to rule this theory in or out. Alternatively, for the non-GeForce GPUs, you could try locking the clocks (you can google for that, here) is an example).
