hi i’m new at this forum and have a little problem compiling an application
I want create some shared library of different math function implementations which use the GPU. The problem appear when i try to link the program with shared library.
i’m using this Makefile to generate shared library
DIR = ../..
DIR_INCLUDE = $(DIR)/include/
DIR_LIB = $(DIR)/lib
DIR_GCC = /opt/gcc/bin
CC = nvcc
FLAGS = -G -g -arch=sm_20 -O3 -Xcompiler -fPIC #-ccbin $(DIR_GCC)
LIBFLAGS = -shared -Xlinker -soname,$(LIB).1
SRC = grad_conj.cu
OBJ = grad_conj.o
LIB = libgrad_conj_cublas.so
all: $(OBJ)
$(CC) $(LIBFLAGS) $(OBJ) -o $(DIR_LIB)/$(LIB).1.0 -lcublas
ln -sf $(LIB).1.0 $(DIR_LIB)/$(LIB).1
ln -sf $(LIB).1 $(DIR_LIB)/$(LIB)
$(OBJ):$(SRC)
$(CC) $(FLAGS) -I$(DIR_INCLUDE) $(SRC) -c
and this other one to generate to link with program
DIR = ..
DIR_CUDA = cuda
DIR_CUBLAS = cublas
DIR_C = c
DIR_DATA = estructuras
DIR_BIN = $(DIR)/bin
CC_CUDA = nvcc
CC = gcc
CFLAGS = -Wall -g -O3
CUDAFLAGS = -G -g -arch=sm_20 -O3
FUENTE = main.c
OBJETO = main.o
EXEC = $(DIR_BIN)/grad_conj
cublas:$(OBJ)
$(MAKE) -C $(DIR_DATA) cuda # to compile some other files .c
$(MAKE) -C $(DIR_CUBLAS) all # to create the shared library
$(CC) $(CFLAGS) $(OBJ) $(DIR_DATA)/vector.o $(DIR_DATA)/matrix.o -L$(DIR_LIB) -lgrad_conj_cublas -o $(EXEC)_cublas
$(OBJ):$(SRC)
$(CC) $(SRC) -c -o $(OBJ) $(CFLAGS) -I$(DIR_INCLUDE)
the problem is when I execute the Makefile, the result is:
make -C estructuras cuda
make[1]: se ingresa al directorio `/home/phirus/Facultad/ssii/desarrollo/fuentes/estructuras'
nvcc -G -g -arch=sm_20 -O3 -Xcompiler -fPIC vector.c matrix.c -I ../../include/ -c
make[1]: se sale del directorio `/home/phirus/Facultad/ssii/desarrollo/fuentes/estructuras'
make -C cublas all
make[1]: se ingresa al directorio `/home/phirus/Facultad/ssii/desarrollo/fuentes/cublas'
nvcc -G -g -arch=sm_20 -O3 -Xcompiler -fPIC -I../../include/ grad_conj.cu -c
nvcc -shared -Xlinker -soname,libgrad_conj_cublas.so.1 grad_conj.o -o ../../lib/libgrad_conj_cublas.so.1.0 -lcublas
ln -sf libgrad_conj_cublas.so.1.0 ../../lib/libgrad_conj_cublas.so.1
ln -sf libgrad_conj_cublas.so.1 ../../lib/libgrad_conj_cublas.so
make[1]: se sale del directorio `/home/phirus/Facultad/ssii/desarrollo/fuentes/cublas'
gcc main.c -c -o main.o -g -O3 -Wall-I../include
gcc -Wall -g -O3 main.o estructuras/vector.o estructuras/matrix.o -L../lib -lgrad_conj_cublas -lcuda -o ../bin/grad_conj_cublas
main.o: In function `main':
<b>/home/phirus/Facultad/ssii/desarrollo/fuentes/main.c:161: undefined reference to `Grad_Conjugado'</b>
collect2: ld devolvió el estado de salida 1
make: *** [cublas] Error 1
the name Grad_Conjugado is the extern function of shared library. the code is:
grad_conj.h
extern int Grad_Conjugado (matrix A, vector b, vector x_ini, vector x);
grad_conj.cu
#include <cuda_runtime.h>
#include <cublas_v2.h>
extern int Grad_Conjugado(matrix A, vector b, vector x_ini, vector x){
some cublas calls
main.c
int main (int argc, char *argv[]){
gettimeofday(&t1,NULL);
Grad_Conjugado(*A, *b, *x0, *xf);
gettimeofday(&t2,NULL);
How must i do it??
Edit:
the library has the correct name of function. Why gcc doesn’t find it:
nm ../lib/libgrad_conj_cublas.so | grep Grad_Conjugado
0000000000000b60 T _Z14Grad_Conjugado6matrix6vectorS0_S0
thx for your time, sorry for my english
