I am coding a cuda project and trying to make it run on TX2. The code runs fine on my PC (with a GTX850 card). However, when I tried to compile it on TX2, it shows following errors:
[100%] Linking CXX executable cudagmmHierEM
libCuda_Lib_.a(Cuda_Lib__intermediate_link.o): In function `__cudaRegisterLinkedBinary_38_cuda_device_runtime_compute_62_cpp1_ii_8b1a5d37':
/tmp/tmpxft_00006d4d_00000000-2_Cuda_Lib__intermediate_link.reg.c:4: undefined reference to `__fatbinwrap_38_cuda_device_runtime_compute_62_cpp1_ii_8b1a5d37'
collect2: error: ld returned 1 exit status
CMakeFiles/cudagmmHierEM.dir/build.make:101: recipe for target 'cudagmmHierEM' failed
make[2]: *** [cudagmmHierEM] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/cudagmmHierEM.dir/all' failed
make[1]: *** [CMakeFiles/cudagmmHierEM.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
And my cmake file shows as follows:
cmake_minimum_required(VERSION 3.5)
project(cudagmm)
#set(CMAKE_BUILD_TYPE Release)
set(CMAKE_BUILD_TYPE DEBUG)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++11")
#set(CMAKE_CXX_STANDARD 11)
find_package(CUDA REQUIRED)
find_package(Eigen3 REQUIRED)
set(CUDA_PROPAGATE_HOST_FLAGS OFF)
set(CUDA_SEPARABLE_COMPILATION ON)
set(CUDA_NVCC_FLAGS "-gencode" "arch=compute_62,code=compute_62") #TX2
list(APPEND CUDA_NVCC_FLAGS "-gencode" "arch=compute_50,code=compute_50")
list(APPEND CUDA_NVCC_FLAGS "-rdc=true" "-std=c++11")
list(APPEND CUDA_NVCC_FLAGS "-g" "-G")
include_directories(include
${CUDA_INCLUDE_DIRS}
${EIGEN3_INCLUDE_DIRS}
"/usr/include/eigen3"
"/usr/include"
${Boost_INCLUDE_DIRS}
link_directories(
/usr/local/cuda/lib64
src
lib
file(GLOB CU_Files "src/*.cu")
cuda_add_library(Cuda_Lib_
${CU_Files})
cuda_add_executable(${PROJECT_NAME}HierEM
test/cudatest.cc
target_link_libraries(${PROJECT_NAME}HierEM
Cuda_Lib_
${CUDA_LIBRARIES}
${CUDA_CUBLAS_LIBRARIES}
${CUDA_cusolver_LIBRARY}
${CUDA_cudadevrt_LIBRARY}
stdc++
The error has something to do with CDP. The following cmake file works on TX2
project(cuda)
set(CUDA_NVCC_FLAGS
${CUDA_NVCC_FLAGS};
-gencode arch=compute_62,code=sm_62
-rdc=true -std=c++11
/usr/local/cuda/include
link_directories(
cuda_add_library(culib
src/cuda.cu)
test/cudatest.cc
culib
-lcudart
-lcublas
-lcusolver
-lcudadevrt
