Unexpected behavior of nvstreammux with multiple rtsp sources
• Jetson Xavier NX
• DeepStream 6.2
• JetPack SDK 5.0.2
• Issue Type: Bug/Question
I am trying to use the new nvstreammux with sync-inputs=1 and multiple rtsp sources. It doesn’t drop frames when nvinfer is not able to keep up with rtsp sources rate of 25fps.
Can you elaborate the details of which case you have run and how did you check the frame dropping?
source bin
def create_source_bin(uri):
    nbin = Gst.parse_bin_from_description(
        f"rtspsrc location={uri} latency=0 ! decodebin ! identity name=identity",
        False
    ret = nbin.add_pad(
        Gst.GhostPad.new("src", nbin.get_by_name("identity").get_static_pad("src"))
    assert ret
    return nbin
processing bin
def create_propcessing_bin(num_sources):
    nbin = Gst.Bin.new("processing-bin")
    assert nbin
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    assert streammux
    streammux.set_property("width", 640)
    streammux.set_property("height", 640)
    streammux.set_property("batch-size", num_sources)
    streammux.set_property("batched-push-timeout", 4000000)
    # streammux.set_property("nvbuf-memory-type", 0)
    streammux.set_property("sync-inputs", 1)
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    assert pgie
    pgie.set_property("config-file-path", "cfg/config_infer_primary_yoloV7.txt")
    pgie.set_property("batch-size", num_sources)
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    assert tracker
    tracker.set_property("tracker-width", 320)
    tracker.set_property("tracker-height", 320)
    tracker.set_property("gpu_id", 0)
        "ll-lib-file",
        "/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so"
        "ll-config-file",
        "/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml"
    tracker.set_property("enable_batch_process", 1)
    tracker.set_property("enable_past_frame", 1)
    nvanalytics = Gst.ElementFactory.make("nvdsanalytics", "analytics")
    assert nvanalytics
    nvanalytics.set_property("config-file", "cfg/config_nvdsanalytics.txt")
    nvdslogger = Gst.ElementFactory.make("nvdslogger", "logger")
    assert nvdslogger
    nbin.add(streammux)
    nbin.add(pgie)
    nbin.add(tracker)
    nbin.add(nvanalytics)
    nbin.add(nvdslogger)
    streammux.link(pgie)
    pgie.link(tracker)
    tracker.link(nvanalytics)
    nvanalytics.link(nvdslogger)
    def get_request_pad(name):
        pad = Gst.GhostPad.new(name, streammux.get_request_pad(name))
        nbin.add_pad(pad)
        return pad
    nbin.get_request_pad = get_request_pad
    bin_src_pad = nbin.add_pad(Gst.GhostPad.new("src", nvdslogger.get_static_pad("src")))
    assert bin_src_pad
    return nbin
display bin
def create_display_bin(num_sources, udpsink_port_num):
    nbin = Gst.Bin.new("display-bin")
    assert nbin
    # Use convertor to convert from NV12 to RGBA as required by nvosd
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    assert nvvidconv
    tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    assert tiler
    tiler_rows = int(math.sqrt(num_sources))
    tiler_columns = int(math.ceil((1.0 * num_sources) / tiler_rows))
    tiler.set_property("rows", tiler_rows)
    tiler.set_property("columns", tiler_columns)
    tiler.set_property("width", 1280)
    tiler.set_property("height", 720)
    # Create OSD to draw on the converted RGBA buffer
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    assert nvosd
    nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
    assert nvvidconv_postosd
    caps = Gst.ElementFactory.make("capsfilter", "filter")
    assert caps
    caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
    encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
    assert encoder
    encoder.set_property("bitrate", 4000000)
    if is_aarch64():
        encoder.set_property("preset-level", 1)
        encoder.set_property("insert-sps-pps", 1)
        #encoder.set_property("bufapi-version", 1)
    rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
    assert rtppay
    sink = Gst.ElementFactory.make("udpsink", "udpsink")
    assert sink
    sink.set_property("host", "224.224.255.255")
    sink.set_property("port", udpsink_port_num)
    sink.set_property("async", False)
    sink.set_property("sync", True)
    sink.set_property("qos", 0)
    nbin.add(nvvidconv)
    nbin.add(tiler)
    nbin.add(nvosd)
    nbin.add(nvvidconv_postosd)
    nbin.add(caps)
    nbin.add(encoder)
    nbin.add(rtppay)
    nbin.add(sink)
    nvvidconv.link(tiler)
    tiler.link(nvosd)
    nvosd.link(nvvidconv_postosd)
    nvvidconv_postosd.link(caps)
    caps.link(encoder)
    encoder.link(rtppay)
    rtppay.link(sink)
    bin_sink_pad = nbin.add_pad(Gst.GhostPad.new("sink", nvvidconv.get_static_pad("sink")))
    assert bin_sink_pad
    return nbin
main code
    Gst.init(None)
    pipeline = Gst.Pipeline()
    assert pipeline
    source_bins = [create_source_bin(uri_name) for uri_name in uri_names]
    num_sources = len(uri_names)
    processing_bin = create_propcessing_bin(num_sources)
    udpsink_port_num = 5400
    display_bin = create_display_bin(num_sources, udpsink_port_num)
    for source_bin in source_bins:
        pipeline.add(source_bin)
    pipeline.add(processing_bin)
    pipeline.add(display_bin)
    for i, source_bin in enumerate(source_bins):
        source_bin.get_static_pad("src").link(processing_bin.get_request_pad("sink_%u" % i))
    processing_bin.link(display_bin)
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    pipeline.set_state(Gst.State.PLAYING)
    server = GstRtspServer.RTSPServer.new()
    rtsp_port_num = 8554
    server.props.service = "%d" % rtsp_port_num
    server.attach(None)
    factory = GstRtspServer.RTSPMediaFactory.new()
    factory.set_launch(
        "( udpsrc name=pay0 port=%d buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)H264, payload=96 \" )"
        % (udpsink_port_num,)
    factory.set_shared(True)
    server.get_mount_points().add_factory("/ds-test", factory)
    try:
        loop.run()
    finally:
        # loop.quit()
        pipeline.set_state(Gst.State.NULL)
I run this command to watch the output stream:
gst-launch-1.0 rtspsrc location=rtsp://localhost:8554/ds-test latency=0 ! decodebin ! nvvidconv ! autovideosink
Result
There is an increasing discrepancy between the time displayed in the output stream frames and the current time.
To prove that the issue is only with nvstreammux element:
Test 1
  • I removed display bin
  • I added probe callback to processing bin
def processing_src_pad_buffer_probe(pad, info, u_data):
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
        except StopIteration:
            break
        l_user = frame_meta.frame_user_meta_list
        while l_user:
            try:
                user_meta = pyds.NvDsUserMeta.cast(l_user.data)
                if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSFRAME.USER_META"):
                    user_meta_data = pyds.NvDsAnalyticsFrameMeta.cast(user_meta.user_meta_data)
                    if user_meta_data.objInROIcnt:
                        if user_meta_data.objInROIcnt["RF"] > 0:
                            print("You appeared now")
                        else:
                            pass
                break
            try:
                l_user = l_user.next
                break
        try:
            l_frame = l_frame.next
            break
    return Gst.PadProbeReturn.OK
processing_bin_src_pad = processing_bin.get_static_pad("src")
assert processing_bin_src_pad
processing_bin_src_pad.add_probe(Gst.PadProbeType.BUFFER, processing_src_pad_buffer_probe, 0)
Result
There is a delay between my appearance in front of one of the cameras and logging of the message “You appeared now”.
The issue is not with display bin.
Test 2
  • I added probe callback to nvstreammux element:
def streammux_src_pad_buffer_probe(pad, info, u_data):
    time.sleep(0.5)
    return True
  • I removed pgie, tracker, nvanalytics elements from processing bin.
  • I returned back display bin, I watched the output stream and I found the same delay issue.
Result
The issue is not with pgie, tracker, nvanalytics elements
Test 3
def dummy_sleep(pad, info, u_data):
    import time
    time.sleep(1)
pipeline = Gst.parse_launch(
    f"rtspsrc location={location} latency=0 ! decodebin ! identity name=identity ! nvvidconv ! autovideosink"
assert pipeline
pipeline.get_by_name("identity").get_static_pad("src").add_probe(Gst.PadProbeType.BUFFER, dummy_sleep, 0)
Although I added a sleep time in the middle of the pipeline, there is no delay between the output stream and the current time.
Result
The delay issue is not with the source bin and it is only with the nvstreammux element which probably caches frames.
Since you are using RTSP sources, please add “streammux.set_property(“live-source”, 1)” in the source bin. And you can set a proper “batched-push-timeout” value according to your actual RTSP streaming FPS.
I am working with DeepStream 6.2 and streammux live-source is deprecated.
Gst-nvstreammux New — DeepStream 6.2 Release documentation
I added “streammux.set_property(“live-source”, 1)” and I set “batched-push-timeout” to 50000 and 50 and I got same result.
Note also that I am working with Dahua Network video recorder (NVR) H265 Codec.
Do you mean the output delay will increase with time?
Yes
I found that I used the default nvstreammux. With the new nvstreammux, the delay disappears.
