Unexpected Behavior with __syncthreads() in CUDA Kernel Leading to Deadlock and Garbage Values
Hello everyone,
I am encountering a perplexing issue with a CUDA kernel I’ve written. The kernel is designed to update a matrix and compute some results. It runs perfectly on my local laptop’s GPU, but when I compile and run it on a server or Google Colab, the application runs indefinitely, suggesting a deadlock.
Kernel Code
__global__ void updateMatrix(double* matrix, double* result, int lpivot, int m, int n, double* up, double* cl)
    double b = (*up) * matrix[(lpivot - 1) * n + lpivot - 1];
    if (b >= 0.0) return;
    b = 1 / b;
    extern __shared__ double sharedPivot[];
    __shared__ double sharedResults[ROW_PER_BLOCK][COL_PER_BLOCK];
    int tidx = threadIdx.x + blockIdx.x * blockDim.x;
    int tidy = threadIdx.y + blockIdx.y * blockDim.y;
    int row = lpivot + blockIdx.y * blockDim.y + threadIdx.y;
    int iterations =  (n - lpivot + COL_PER_BLOCK - 1) / COL_PER_BLOCK;
    for(int it = 0; it < iterations; it++)
        int colStart = lpivot + it * blockDim.x;
        if (threadIdx.y == 0 && colStart + threadIdx.x < n)
            sharedPivot[threadIdx.x] = matrix[(lpivot - 1) * n + colStart + threadIdx.x];
        __syncthreads();
        if (row < m && colStart + threadIdx.x < n)
            sharedResults[threadIdx.y][threadIdx.x] = matrix[row * n + colStart + threadIdx.x] * sharedPivot[threadIdx.x];
        else
            sharedResults[threadIdx.y][threadIdx.x] = 0;
        __syncthreads();
        reduceSum<COL_PER_BLOCK>(sharedResults[threadIdx.y]);
        if (row < m && threadIdx.x == 0)
            result[row - lpivot] += sharedResults[threadIdx.y][0];
        __syncthreads();
        if(tidx < COL_PER_BLOCK && tidy < ROW_PER_BLOCK)
            sharedPivot[tidx] = 0;
            sharedResults[tidy][tidx] = 0;
        __syncthreads();
    if(row < m && threadIdx.x == 0)
        result[row - lpivot] += matrix[row * n + lpivot - 1] * (*up);
        if (result[row - lpivot] == 0) return;
        result[row - lpivot] *= b;
        matrix[row * n + lpivot - 1] += result[row - lpivot] * (*up);
    __syncthreads();
    for (int it = 0; it < iterations; it++)
       int col = it * blockDim.x + threadIdx.x + lpivot;
       if (col < n && row < m)
            matrix[row * n + col] += result[row - lpivot] * matrix[(lpivot - 1) * n + col];
        __syncthreads();
        if (row == lpivot && col < n)
            sharedPivot[threadIdx.x] = matrix[row * n + col] * matrix[row * n + col];
        else
            sharedPivot[threadIdx.x] = 0;
        __syncthreads();
        reduceSum<COL_PER_BLOCK>(sharedPivot);
        if (threadIdx.x == 0)
            atomicAdd(&sumOfSquares, sharedPivot[0]);
        __syncthreads();
    if (lpivot == 1)
        printf("sumOfSquares = %f\n", sumOfSquares);
    atomicAdd(&counter, 1);
    printf("lpivot = %d counter = %d\n", counter);
    if (counter == blockDim.x * blockDim.y * gridDim.y)
        *cl = matrix[lpivot * n + lpivot];
        *cl = (*cl > 0.0) ? -sqrt(sumOfSquares) : sqrt(sumOfSquares);
        *up = matrix[lpivot * n + lpivot] - *cl;
        matrix[lpivot * n + lpivot] = *cl;
        sumOfSquares = 0; // Reset for the next iteration
        counter = 0;
Deadlock Identification: I initially identified that the threads entering the following block were not leaving it due to conditional synchronization.
    __syncthreads();
        sumOfSquares += sharedPivot[0];
    __syncthreads();
After moving __syncthreads() out of conditional blocks, the kernel avoids deadlock but results in garbage values being loaded into shared memory, leading to incorrect computation of sumOfSquares, which is printed as zero.
         __syncthreads();
        if(row == lpivot && col < n)
            if(lpivot == 1)
            printf("before shared pivot loaded sharedPivot[%d] = %f\n",threadIdx.x , sharedPivot[threadIdx.x]);
            if(lpivot == 1)
            printf("after shared pivot loaded sharedPivot[%d] = %f\n",threadIdx.x , sharedPivot[threadIdx.x]);
        else
         __syncthreads();
            if(threadIdx.x == 0)
              printf("sum of sqaures = %f\n",sumOfSqaures);
        __syncthreads();
How can I properly handle synchronization in this scenario to avoid deadlocks without introducing garbage values? Is there a more robust way to ensure correct accumulation of sumOfSquares across all threads?
Please post a complete minimal example that reproduces your problem.
The code does not compile for me using cuda 12.4
main.cu(180): error: identifier "gpuErrchk" is undefined
      gpuErrchk(cudaMalloc((void**)&matrix, sizeof(double) * m * n));
main.cu(196): error: identifier "start" is undefined
      cudaEventRecord(start);
main.cu(198): error: identifier "updatePivotElement" is undefined
      updatePivotElement<<<1, 512, 512 * sizeof(double)>>>(matrix, 1, m, n, d_up_old, d_cl);
main.cu(225): error: expected a ";"
      householder(input_matrix);
I am sorry , i have updated the code , please try again
Now the code compiles but execution gives segmentation fault.
