I’m getting highly non-uniform performance for float16 matmul on P3 using recommended NVidia container. I was told by Tom Reed at GTC that this is not expected so maybe someone could redirect this to proper channel:
To reproduce, run the following on Volta machine.
wget https://raw.githubusercontent.com/yaroslavvb/stuff/master/matmul_benchmark_seq.py
export TF_CPP_MIN_LOG_LEVEL=1
python matmul_benchmark_seq.py --dtype=float16
You’ll see something like this.
7512,76.0847702634
8192,87.2323633474
8933,15.2443599021
9741,15.0255254543
This means that it got 87 Tops/second for 8192x8192 matmul, followed by 15 T ops/second for 8933.
For more graphs, see Peak performance of Amazon P3 instances | by Yaroslav Bulatov | Medium
For more details, I used Amazon Ubuntu CUDA 9 AMI – AWS Marketplace: Deep Learning AMI with Source Code (CUDA 9, Ubuntu)
Then used AWS instructions to optimize for GPUs
Then used nvidia docker with official TensorFlow container.
sudo nvidia-persistenced
sudo nvidia-smi -ac 877,1530 # p3
sudo apt-get install apt-transport-https ca-certificates curl software-properties-common
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu xenial stable"
sudo apt-get update
apt-cache search docker-ce
sudo apt-get install -y docker-ce
wget https://github.com/NVIDIA/nvidia-docker/releases/download/v1.0.1/nvidia-docker_1.0.1-1_amd64.deb
sudo dpkg -i nvidia-docker_1.0.1-1_amd64.deb
sudo docker login nvcr.io
sudo docker pull nvcr.io/nvidia/tensorflow:17.10
sudo nvidia-docker run -it --shm-size=1g --ulimit memlock=-1 --ulimit stack=67108864 --rm -v /home/ubuntu/docker:/data/mnist nvcr.io/nvidia/tensorflow:17.10
export CUDA_VISIBLE_DEVICES=0
