Hello there,
I encountered something rather odd while experimenting with C++ inheritance and OpenACC.
The following code compiles well with “pgc++ -acc -ta=nvidia -Minfo=accel” and produces correct results.
#include <iostream>
#include "openacc.h"
#include "accel.h"
class Base1 {
protected:
int len1;
int* varbase1;
Base1()
len1 = 2;
varbase1 = new int[len1];
for(int i=0; i<len1; i++) varbase1[i]=1;
class Level2: public Base1 {
public:
Level2()
#pragma acc enter data copyin(this)
#pragma acc enter data create(varbase1[0:len1] )
void printAll()
std::cout << "==========printAll================" << std::endl;
for(int i=0; i<len1; i++) std::cout << "Base1: element" << i <<"=" << varbase1[i] << std::endl;
#pragma acc routine seq
void updatebase()
for(int i=0; i<len1; i++) varbase1[i] = i*2;
void updatehost()
#pragma acc update host(varbase1[0:len1])
int main () {
Level2 obj_level2;
obj_level2.printAll();
#pragma acc serial
obj_level2.updatebase();
obj_level2.updatehost();
return 0;
However, compilation would fail if “int* varbase1” is placed first in the Base1 class definition, as follows:
class Base1 {
protected:
int* varbase1;
int len1;
Base1()
len1 = 2;
and the compilation error message is:
[my login]$ pgc++ -acc -ta=nvidia -Minfo=accel inheritance.C
main:
45, Accelerator serial kernel generated
Generating Tesla code
Generating implicit copy(obj_level2)
PGCC-F-0155-Compiler failed to translate accelerator region (see -Minfo messages): Unexpected name table type (inheritance.C: 23)
PGCC/x86 Linux 18.10-1: compilation aborted
and line 23 corresponds to the “}” under #pragma acc enter data create(varbase1[0:len1] )
The version of the PGI compiler used is:
[my login]$ pgcc --version
pgcc 18.10-1 64-bit target on x86-64 Linux -tp skylake
PGI Compilers and Tools
Copyright © 2018, NVIDIA CORPORATION. All rights reserved.
Is this behavior expected?
