I want to uninstall cuda 9.1 since I just installed cuda 10. How would I do this ?
phung@UbuntuHW15:~/Downloads/pytorch$ sudo apt-get remove --purge cuda
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
cuda-10-0 cuda-command-line-tools-10-0 cuda-compiler-10-0 cuda-cublas-10-0
cuda-cublas-dev-10-0 cuda-cudart-10-0 cuda-cudart-dev-10-0 cuda-cufft-10-0
cuda-cufft-dev-10-0 cuda-cuobjdump-10-0 cuda-cupti-10-0 cuda-curand-10-0
cuda-curand-dev-10-0 cuda-cusolver-10-0 cuda-cusolver-dev-10-0
cuda-cusparse-10-0 cuda-cusparse-dev-10-0 cuda-demo-suite-10-0
cuda-documentation-10-0 cuda-driver-dev-10-0 cuda-drivers cuda-gdb-10-0
cuda-gpu-library-advisor-10-0 cuda-libraries-10-0 cuda-libraries-dev-10-0
cuda-license-10-0 cuda-memcheck-10-0 cuda-misc-headers-10-0 cuda-npp-10-0
cuda-npp-dev-10-0 cuda-nsight-10-0 cuda-nsight-compute-10-0 cuda-nvcc-10-0
cuda-nvdisasm-10-0 cuda-nvgraph-10-0 cuda-nvgraph-dev-10-0 cuda-nvjpeg-10-0
cuda-nvjpeg-dev-10-0 cuda-nvml-dev-10-0 cuda-nvprof-10-0 cuda-nvprune-10-0
cuda-nvrtc-10-0 cuda-nvrtc-dev-10-0 cuda-nvtx-10-0 cuda-nvvp-10-0
cuda-runtime-10-0 cuda-samples-10-0 cuda-toolkit-10-0 cuda-tools-10-0
cuda-visual-tools-10-0 dkms freeglut3 freeglut3-dev libglu1-mesa-dev
libnvidia-cfg1-410 libnvidia-common-410 libnvidia-decode-410
libnvidia-encode-410 libnvidia-fbc1-410 libnvidia-gl-410 libnvidia-ifr1-410
libxmu-dev libxmu-headers libxnvctrl0 libxt-dev nvidia-compute-utils-410
nvidia-dkms-410 nvidia-driver-410 nvidia-kernel-common-410
nvidia-kernel-source-410 nvidia-modprobe nvidia-prime nvidia-settings
nvidia-utils-410 screen-resolution-extra xserver-xorg-video-nvidia-410
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
cuda*
0 upgraded, 0 newly installed, 1 to remove and 1 not upgraded.
After this operation, 25.6 kB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
phung@UbuntuHW15:~/Downloads/pytorch$ cat /usr/lib/cuda/version.txt
CUDA Version 9.1.85
phung@UbuntuHW15:~/Downloads/pytorch$ cat /usr/local/cuda-10.0/version.txt
CUDA Version 10.0.130
phung@UbuntuHW15:~/Downloads/pytorch$ /usr/bin/nvcc --version
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Nov__3_21:07:56_CDT_2017
Cuda compilation tools, release 9.1, V9.1.85
phung@UbuntuHW15:~/Downloads/pytorch$ which nvcc
/usr/local/cuda-10.0/bin/nvcc
I have just removed my freshly installed cuda-10 and now working on uninstalling cuda-9.1 which I had difficulty at.
[url]https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#runfile-uninstallation[/url] does not help because the pl script is not found.
phung@UbuntuHW15:~/Downloads/pytorch$ ls -al /usr/local/cuda/
total 16
drwxr-xr-x 4 root root 4096 Sep 27 13:11 .
drwxr-xr-x 13 root root 4096 Nov 14 21:00 ..
drwxr-xr-x 2 root root 4096 Sep 27 13:12 include
drwxr-xr-x 2 root root 4096 Sep 27 13:12 lib64
