command used for package installation :
conda install -c anaconda keras-gpu
It installed :
tensorboard 2.0.0 pyhb38c66f_1
tensorflow 2.0.0 gpu_py37h57d29ca_0
tensorflow-base 2.0.0 gpu_py37h390e234_0
tensorflow-estimator 2.0.0 pyh2649769_0
tensorflow-gpu 2.0.0 h0d30ee6_0 anaconda
cudatoolkit 10.0.130 0
cudnn 7.6.5 cuda10.0_0
keras-applications 1.0.8 py_0
keras-base 2.2.4 py37_0
keras-gpu 2.2.4 0 anaconda
keras-preprocessing 1.1.0 py_1
code :
from tensorflow.keras.models import Sequential
from tensorflow.keras.layers import Convolution2D
from tensorflow.keras.layers import MaxPooling2D
from tensorflow.keras.layers import Flatten
from tensorflow.keras.layers import Dense
classifier = Sequential()
classifier.add(Convolution2D(32, 3, 3, input_shape = (64, 64, 3), activation = 'relu'))
classifier.add(MaxPooling2D(pool_size = (2, 2)))
classifier.add(Convolution2D(32, 3, 3, activation = 'relu'))
classifier.add(Flatten())
classifier.add(Dense(units = 128, activation = 'relu'))
classifier.add(Dense(units = 1, activation = 'sigmoid'))
classifier.compile(optimizer = 'adam', loss = 'binary_crossentropy', metrics = ['accuracy'])
from tensorflow.keras.preprocessing.image import ImageDataGenerator
train_datagen = ImageDataGenerator(rescale = 1./255,
shear_range = 0.2,
zoom_range = 0.2,
horizontal_flip = True)
test_datagen = ImageDataGenerator(rescale = 1./255)
training_set = train_datagen.flow_from_directory('dataset/training_set',
target_size = (64, 64),
batch_size = 4,
class_mode = 'binary')
test_set = test_datagen.flow_from_directory('dataset/test_set',
batch_size = 4,
classifier.fit_generator(training_set,
steps_per_epoch = 8000,
epochs = 25,
validation_data = test_set,
validation_steps = 2000)
Traceback :
File "D:\Machine Learning\Machine Learning A-Z Template Folder\Part 8 - Deep Learning\Section 40 - Convolutional Neural Networks (CNN)\cnn.py", line 70, in <module>
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\engine\training.py", line 1297, in fit_generator
steps_name='steps_per_epoch')
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\engine\training_generator.py", line 265, in model_iteration
batch_outs = batch_function(*batch_data)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\engine\training.py", line 973, in train_on_batch
class_weight=class_weight, reset_metrics=reset_metrics)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\engine\training_v2_utils.py", line 264, in train_on_batch
output_loss_metrics=model._output_loss_metrics)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\engine\training_eager.py", line 311, in train_on_batch
output_loss_metrics=output_loss_metrics))
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\engine\training_eager.py", line 252, in _process_single_batch
training=training))
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\engine\training_eager.py", line 127, in _model_loss
outs = model(inputs, **kwargs)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\engine\base_layer.py", line 891, in __call__
outputs = self.call(cast_inputs, *args, **kwargs)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\engine\sequential.py", line 256, in call
return super(Sequential, self).call(inputs, training=training, mask=mask)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\engine\network.py", line 708, in call
convert_kwargs_to_constants=base_layer_utils.call_context().saving)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\engine\network.py", line 860, in _run_internal_graph
output_tensors = layer(computed_tensors, **kwargs)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\keras\layers\convolutional.py", line 197, in call
outputs = self._convolution_op(inputs, self.kernel)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\ops\nn_ops.py", line 1134, in __call__
return self.conv_op(inp, filter)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\ops\nn_ops.py", line 639, in __call__
return self.call(inp, filter)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\ops\nn_ops.py", line 238, in __call__
name=self.name)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\ops\nn_ops.py", line 2010, in conv2d
name=name)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\ops\gen_nn_ops.py", line 1031, in conv2d
data_format=data_format, dilations=dilations, name=name, ctx=_ctx)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\ops\gen_nn_ops.py", line 1130, in conv2d_eager_fallback
ctx=_ctx, name=name)
File "C:\Anaconda\envs\ML\lib\site-packages\tensorflow_core\python\eager\execute.py", line 67, in quick_execute
six.raise_from(core._status_to_exception(e.code, message), None)
File "<string>", line 3, in raise_from
UnknownError: Failed to get convolution algorithm. This is probably because cuDNN failed to initialize, so try looking to see if a warning log message was printed above. [Op:Conv2D]
