Hi:
I need some help in setting up Visual Studio 2008 to run cuda examples I been trying for three weeks to get one example to compile and exe, I can get a sucessful compile but can’t build an .exe for some reason
I get the following error message
What am I missing in config file
OS Visata 64 bits
IDE Visual Studion 2008
cuda 2.3
Linking…
deviceQueryDrv.obj : error LNK2019: unresolved external symbol __imp__cutCheckCmdLineFlag@12 referenced in function _main
deviceQueryDrv.obj : error LNK2019: unresolved external symbol _cuDeviceGetAttribute@12 referenced in function _main
deviceQueryDrv.obj : error LNK2019: unresolved external symbol _cuDeviceTotalMem@8 referenced in function _main
deviceQueryDrv.obj : error LNK2019: unresolved external symbol _cuDriverGetVersion@4 referenced in function _main
deviceQueryDrv.obj : error LNK2019: unresolved external symbol _cuDeviceGetName@12 referenced in function _main
deviceQueryDrv.obj : error LNK2019: unresolved external symbol _cuDeviceComputeCapability@12 referenced in function _main
deviceQueryDrv.obj : error LNK2019: unresolved external symbol _cuDeviceGetCount@4 referenced in function _main
deviceQueryDrv.obj : error LNK2019: unresolved external symbol _cuInit@4 referenced in function _main
MSVCRTD.lib(crtexew.obj) : error LNK2019: unresolved external symbol _WinMain@16 referenced in function ___tmainCRTStartup
Debug\mp_test.exe : fatal error LNK1120: 9 unresolved externals
The total error message
Build Log Build started: Project: mp_test, Configuration: Debug|Win32
Command Lines Creating temporary file “d:\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\src _learning\deviceQueryDrv\Debug\RSP0000127122248.rsp” with contents
/OUT:“Debug\mp_test.exe” /VERSION:1 /INCREMENTAL /LIBPATH:“D:\CUDA\include” /MANIFEST /MANIFESTFILE:“Debug\mp_test.exe.intermediate.manifest” /MANIFESTUAC:“level=‘asInvoker’ uiAccess=‘false’” /DEBUG /PDB:“d:\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\src _learning\deviceQueryDrv\Debug\mp_test.pdb” /SUBSYSTEM:WINDOWS /DYNAMICBASE /NXCOMPAT /MACHINE:X86 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib
“.\Debug\deviceQueryDrv.obj”
“.\Debug\mp_test.exe.embed.manifest.res”
Creating command line “link.exe @“d:\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\src _learning\deviceQueryDrv\Debug\RSP0000127122248.rsp” /NOLOGO /ERRORREPORT:PROMPT”
Output Window Linking…
Results Build Time 0:00
Build log was saved at “file://d:\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\src _learning\deviceQueryDrv\Debug\BuildLog.htm”
mp_test - 10 error(s), 0 warning(s)
