I’m no programmer, i didn’t work with fortran until now, as for C i have just a very basic idea. OpenACC i have no clue also.
But still i wanted to play a bit with openacc. I had a fractal example in C (or c++ i have no clue which one) that outputs a fractal in text. The program is multicore CPU. and it works.
I wanted to change it for openacc but it seems that complex type is not supported by pgi in c. Seems that fortran has no issues with it.
Anyway
After trying and trying and trying and trying i changed the code a bit
so the code looks like this
program test
integer,parameter :: width=100 ,height=100
integer :: maxiter
complex :: center,span,begin
character(len=99) :: char_a,char_b,char_c
integer :: x,y,n,a,b
complex :: c
character (len=1) :: ch
character (len = *), parameter::charset = ".,c8M@jawrpogOQEPGJ";
real :: temp
integer::testare,line
complex::temp3
integer::temp4
character(len=1),dimension(height,width)::lines
character(len=height*width)::string
center=(-0.7, 0)
span=(2.7, -1*(4/3.0)*2.7*height/width)
begin = center-span/2.0
maxiter = 100000
ch=" "
!$acc parallel loop
do line=0,height-1
do x=0,width-1
c = begin + CMPLX(x * span%re / (width +1), line * span%im / (height+1))
n=0
temp3=c
temp4=0
testare=0
do n=0,maxiter-1
if (abs(temp3)>=2) then
testare=1
else
temp3=temp3*temp3+c
end if
if (testare==0) temp4=temp4+1
end do
n=temp4
if (n == maxiter) n = 0
ch = " "
if(n > 0) then
lines(line+1,x+1)=charset(mod(n,len(charset))+1:mod(n,len(charset))+1)
else
! lines(line+1,x+1)=ch <---give error
lines(line+1,x+1)=" "
end if
end do
end do
!$acc end loop
do line=1,height
do x=1,width
write(*,'(a,$)') lines(line,x) !<---give error
end do
print*,"|"
end do
end program test
the problem is that if i try to compile it as it is now i get Unsupported local variable error
If i comment the write line from last loop i can compile the code. and it seems it works. i have no clue if it does since i can’t see the result.
Compiling it without -acc the code works without problems.
It seems that lines(a,b) does not accept values from another variable and i can’t read values from it after the loop is done.
What am i doing wrong?
Is there any openacc guide for noobies?
