Use CoreDump to capture GPU out-of-bounds memory access
In the debugging environment, compute-sanitizer can effectively capture GPU memory out-of-bounds issues. However, it is difficult to apply compute-sanitizer in actual production environments because it severely impacts performance.
I am trying to find an alternative tool that can capture information when CUDA memory out-of-bounds occurs. But when I attempted to capture core dumps, I discovered that a core dump is only generated if the memory out-of-bounds access goes far beyond the allocated range.
In my environment (Windows, RTX 3060, CUDA 12.9), I allocated 1 byte of memory and tried writing to addresses with larger offsets. My actual tests showed that a core dump is only generated when the write offset exceeds approximately 80MB relative to the start of the allocated memory address.
My questions are:
Why is the threshold around 80MB?
Is there an effective method to automatically detect GPU memory out-of-bounds with minimal performance impact?
Thanks for your reply.
MyDemo:
#include <cuda_runtime.h>
#include <stdio.h>
#include <windows.h>
__global__ void OutOfBoundsKernel(unsigned char* ptr, size_t offset) {
    unsigned long long write_addr = (unsigned long long)(ptr + offset);
    unsigned long long base_addr = (unsigned long long)ptr;
    if (threadIdx.x == 0 && blockIdx.x == 0) {
        printf("[Kernel] Base address: 0x%016llx\n", base_addr);
        printf("[Kernel] Write offset: %zu bytes (%.2f MB)\n", offset, offset / (1024.0 * 1024.0));
        printf("[Kernel] Write address: 0x%016llx\n", write_addr);
    // Out-of-bounds write
    ptr[offset] = 0xFF;
int main() {
    cudaError_t err;
    unsigned char* d_ptr = NULL;
    printf("========================================\n");
    printf("GPU Memory Protection Range Test\n");
    printf("========================================\n\n");
    // 1. Get device information
    int deviceCount;
    cudaGetDeviceCount(&deviceCount);
    if (deviceCount == 0) {
        printf("No CUDA device found!\n");
        return -1;
    cudaDeviceProp prop;
    cudaGetDeviceProperties(&prop, 0);
    printf("Device: %s\n", prop.name);
    printf("Total Memory: %.2f GB\n", prop.totalGlobalMem / (1024.0 * 1024.0 * 1024.0));
    // 2. Allocate memory (only 1 byte)
    size_t alloc_size = 1;
    err = cudaMalloc(&d_ptr, alloc_size);
    if (err != cudaSuccess) {
        printf("cudaMalloc failed: %s\n", cudaGetErrorString(err));
        return -1;
    printf("\nAllocated %zu bytes\n", alloc_size);
    printf("Allocated address: 0x%016llx\n", (unsigned long long)d_ptr);
    // 3. Get memory range info
    cudaPointerAttributes attrs;
    cudaPointerGetAttributes(&attrs, d_ptr);
    printf("Memory type: %d\n", attrs.type);
    // 4. Test different offsets
    size_t test_offsets[] = {
        1 * 1024 * 1024,               // 1MB
        2 * 1024 * 1024,           // 2MB
        4 * 1024 * 1024,               // 4MB
        8 * 1024 * 1024,               // 8MB
        16 * 1024 * 1024,               // 16MB
        32 * 1024 * 1024,               // 32MB
        64 * 1024 * 1024,               // 64MB
        79 * 1024 * 1024 - 1,          // 79MB
        80 * 1024 * 1024,              // 80MB
        100 * 1024 * 1024,              // 100MB
    printf("\n========================================\n");
    printf("Testing Different Offsets\n");
    for (int i = 0; i < sizeof(test_offsets) / sizeof(test_offsets[0]); i++) {
        size_t offset = test_offsets[i];
        unsigned long long write_addr = (unsigned long long)d_ptr + offset;
        printf("\n[Test %d] Offset %zu bytes (%.2f MB) -> Address 0x%016llx\n",
            i + 1, offset, offset / (1024.0 * 1024.0), write_addr);
        // Launch kernel
        OutOfBoundsKernel << <1, 1 >> > (d_ptr, offset);
        // Synchronize
        err = cudaDeviceSynchronize();
            printf("  CRASHED! %s (code=%d)\n", cudaGetErrorString(err), err);
            // Reallocate memory after crash
            cudaFree(d_ptr);
                printf("Failed to reallocate memory, test terminated\n");
                break;
            printf("  Reallocated address: 0x%016llx\n", (unsigned long long)d_ptr);
        else {
            printf(" SUCCESS\n");
        Sleep(500);
    return 0;
Result:
Device: NVIDIA GeForce RTX 3060
Total Memory: 12.00 GB
Allocated 1 bytes
Allocated address: 0x0000000b06200000
Memory type: 2
[Test 1] Offset 1048576 bytes (1.00 MB) → Address 0x0000000b06300000
[Kernel] Base address: 0x0000000b06200000
[Kernel] Write offset: 1048576 bytes (0.00 MB)
[Kernel] Write address: 0x0000000b06300000
SUCCESS
[Test 2] Offset 2097152 bytes (2.00 MB) → Address 0x0000000b06400000
[Kernel] Write offset: 2097152 bytes (0.00 MB)
[Kernel] Write address: 0x0000000b06400000
SUCCESS
[Test 3] Offset 4194304 bytes (4.00 MB) → Address 0x0000000b06600000
Kernel] Base address: 0x0000000b06200000
[Kernel] Write offset: 4194304 bytes (0.00 MB)
[Kernel] Write address: 0x0000000b06600000
SUCCESS
[Test 4] Offset 8388608 bytes (8.00 MB) → Address 0x0000000b06a00000
[Kernel] Write offset: 8388608 bytes (0.00 MB)
[Kernel] Write address: 0x0000000b06a00000
SUCCESS
[Test 5] Offset 16777216 bytes (16.00 MB) → Address 0x0000000b07200000
[Kernel] Write offset: 16777216 bytes (0.00 MB)
[Kernel] Write address: 0x0000000b07200000
SUCCESS
[Test 6] Offset 33554432 bytes (32.00 MB) → Address 0x0000000b08200000
[Kernel] Write offset: 33554432 bytes (0.00 MB)
[Kernel] Write address: 0x0000000b08200000
SUCCESS
[Test 7] Offset 67108864 bytes (64.00 MB) → Address 0x0000000b0a200000
[Kernel] Write offset: 67108864 bytes (0.00 MB)
[Kernel] Write address: 0x0000000b0a200000
SUCCESS
[Test 8] Offset 82837503 bytes (79.00 MB) → Address 0x0000000b0b0fffff
[Kernel] Write offset: 82837503 bytes (0.00 MB)
[Kernel] Write address: 0x0000000b0b0fffff
SUCCESS
[Test 9] Offset 83886080 bytes (80.00 MB) → Address 0x0000000b0b200000
[13:47:48.876775] coredump: Starting GPU coredump generation
[13:47:48.877101] coredump: Detected an exception of type CUDBG_EXCEPTION_WARP_ILLEGAL_ADDRESS (14)
[13:47:48.877214] coredump: - Device: 0
[13:47:48.877298] coredump: - SM: 0
[13:47:48.877407] coredump: - Warp: 0
[13:47:48.877487] coredump: - PC 0xb00e7bf90
[13:47:48.877920] coredump: Stack trace (lane masks: active 0x00000001, valid 0x00000001):
[13:47:48.878024] coredump: #0 0xb00e7bfa0 _Z17OutOfBoundsKernelPhy
[13:47:48.878922] coredump: SM 1/28 has finished state collection
[13:47:48.878981] coredump: SM 2/28 has finished state collection
[13:47:48.878998] coredump: SM 3/28 has finished state collection
[13:47:48.879014] coredump: SM 4/28 has finished state collection
[13:47:48.879030] coredump: SM 5/28 has finished state collection
[13:47:48.879046] coredump: SM 6/28 has finished state collection
[13:47:48.879062] coredump: SM 7/28 has finished state collection
[13:47:48.879080] coredump: SM 8/28 has finished state collection
[13:47:48.879097] coredump: SM 9/28 has finished state collection
[13:47:48.879115] coredump: SM 10/28 has finished state collection
[13:47:48.879132] coredump: SM 11/28 has finished state collection
[13:47:48.879148] coredump: SM 12/28 has finished state collection
[13:47:48.879164] coredump: SM 13/28 has finished state collection
[13:47:48.879181] coredump: SM 14/28 has finished state collection
[13:47:48.879199] coredump: SM 15/28 has finished state collection
[13:47:48.879217] coredump: SM 16/28 has finished state collection
[13:47:48.879235] coredump: SM 17/28 has finished state collection
[13:47:48.879252] coredump: SM 18/28 has finished state collection
[13:47:48.879270] coredump: SM 19/28 has finished state collection
[13:47:48.879288] coredump: SM 20/28 has finished state collection
[13:47:48.879305] coredump: SM 21/28 has finished state collection
[13:47:48.879323] coredump: SM 22/28 has finished state collection
[13:47:48.879340] coredump: SM 23/28 has finished state collection
[13:47:48.879357] coredump: SM 24/28 has finished state collection
[13:47:48.879375] coredump: SM 25/28 has finished state collection
[13:47:48.879393] coredump: SM 26/28 has finished state collection
[13:47:48.879410] coredump: SM 27/28 has finished state collection
[13:47:48.879428] coredump: SM 28/28 has finished state collection
[13:47:48.879450] coredump: Device 1/1 has finished state collection
[13:47:48.879471] coredump: Calculating ELF file layout
[13:47:48.879513] coredump: ELF file layout calculated
[13:47:48.879530] coredump: Writing ELF file to D:\Dumps\coreDump\core.dmp
[13:47:48.879551] coredump: Current working directory is D:\code\CompressTool\Project1
[13:47:48.880590] coredump: Writing out global memory (12582912 bytes)
[13:47:48.881128] coredump: 5%…
[13:47:48.881193] coredump: 10%…
[13:47:48.881212] coredump: 15%…
[13:47:48.933808] coredump: 20%…
[13:47:48.933912] coredump: 25%…
[13:47:48.933938] coredump: 30%…
[13:47:48.984957] coredump: 35%…
[13:47:48.985029] coredump: 40%…
[13:47:48.985076] coredump: 45%…
[13:47:48.985099] coredump: 50%…
[13:47:49.040064] coredump: 55%…
[13:47:49.040124] coredump: 60%…
[13:47:49.040146] coredump: 65%…
[13:47:49.090164] coredump: 70%…
[13:47:49.090309] coredump: 75%…
[13:47:49.090346] coredump: 80%…
[13:47:49.141109] coredump: 85%…
[13:47:49.141196] coredump: 90%…
[13:47:49.141225] coredump: 95%…
[13:47:49.141248] coredump: 100%…
[13:47:49.141367] coredump: Writing out device table
[13:47:49.142994] coredump: Writing out metadata
[13:47:49.143027] coredump: Finalizing
[13:47:49.143554] coredump: Writing done
[13:47:49.143586] coredump: All done (took 01s)
Hi @271732480
Thank you very much for your questions. Let me try to answer these:
This threshold depends on a number of internal implementation details and there is no guarantee that all such memory access would trigger memory exception. In your particular case the threshold seems to be 80MB, but there is no guarantee, that it would be the same for other applications/GPU driver version/consecutive runs.
At the moment, the only reliable way is to use the Compute Sanitizer tool (NVIDIA Compute Sanitizer | NVIDIA Developer ). It would provide more precise out-of-bounds memory access errors detection, but would have an impact of the application performance.
