use float AtomicAdd to write to a float4
For “Fermi” cards, the arithmetic function atomicAdd can be applied to floats. I want to use it for a float3, without having to revise how my data is stored.
It seems like I should be able to hand the atomicAdd the address of the components of the float3 and then use three atomicAdds.
        // write out to the force array in global/cache with an atomicadd
        float * addr = &d_force[n_idx];
        atomicAdd(addr+0, val_x);
        atomicAdd(addr+4, val_y);
        atomicAdd(addr+8, val_z);
However, my compiler has not been fooled
error: a value of type “float3 *” cannot be used to initialize an entity of type "float *
Suggestions?
Yes:
			float * addr = &(d_force[n_idx].x);
			atomicAdd(addr+1, val_y);
			atomicAdd(addr+2, val_z);
or better (because it prevents accidental mistakes with flawed pointer arithmetics, like in your case):
			atomicAdd(&(d_force[n_idx].x), val_x);
			atomicAdd(&(d_force[n_idx].y), val_y);
			atomicAdd(&(d_force[n_idx].z), val_z);
Yes:
