Using CUDA with NVIDIA Grid K2
Hi!
Just a simple question: Do you know if it’s possible to use an NVIDIA GRID K2 with CUDA, doing a full GPU passthrough or (ideally) one of the virtualized GPUs like the K280Q?
GPU acceleration is really nice once you install base (XenServer) and VM NVIDIA drivers, but I would like to know if it’s possible to use CUDA.
Best regards!
You might want to search further, but I believe CUDA is only doable for a straight passthroughIn VMWare terms… Virtual Shared Graphics Acceleration (vSGA) does not provide CUDA, however Virtual Direct Graphics Acceleration (vDGA) does.
See also:
[url]Behavior of CUDA kernels from guest VM on NVIDIA GRID vGPU - Stack Overflow
[url]http://acceleware.com/blog/state-gpu-virtualization-cuda-applications-2014[/url]
etc…
you might want to check the latest driver version of grid, (currently 5.2) it should support using cuda on windows platform only, we tried it with P40.
-Nir
