Hello everyone,
I created a kernel that evidently requires shared memory that doesn’t exist. I was hoping that the required shared would ‘spill’ into the global memory, the same way registers spill in shared memory. I guess it was wrong thinking…
The point is that I need arrays that have the properties of shared memory (aka the sharing within the block and having the lifetime of the block) without necessarily having the fast access the actual shared memory has.
On the other hand, to replace these arrays with global memory directly from the ‘outside’, means that I would need to reserve memory quantities proportionate to the size of the whole grid, to account for all the blocks that will run (which would be way too much).
I would really appreciate any ideas on the issue, and please if you see anything wrong with the above way of thinking don’t hesitate to correct.
