I’m working on facial recognition algorithm using OpenCV and Tensorflow librairies. It’s running well on my computer and now I try to run it on my Jetson AGX Xavier. I successfully install opencv using this tutorial and Tensorflow using this one.
My code is running properly on the AGX Xavier, but the performance are the same comparing to my dev computer (who don’t have any dedicated GPU and less CPU power).
I’m pretty surprise because I would assumed that running OpenCV on the AGX Xavier automatically use the power of the GPU for video reading and analysis.
Currently, I can’t reach more than 10 fps while reading a 4k video (without any treatment). Using the jtop function show me that GPU usage during the video reading is near to 0 % (CPU is around 75%).
I’m pretty sure there is something I’m missing in my understanding. Is there a way to force OpenCV to use the GPU for image processing ? Or maybe it is about the AGX Xavier initialisation ?
First you need to build OpenCV with CUDA support, the OpenCV version delivered with JetPack has NO CUDA-support. Look around here in the forums or use this script by community member @mdegans.
Side note: Note sure but looking at the opencv build script you mentionned, it seems it sets CUDA arch to 7.0
For Xavier, I think it should be 7.2.
You may consider using the script that @dkreutz mentioned.
Thanks I didn’t know that. I will investigate this part.
Indeed. I made the modification in the CMake options before compiling, so it’s supposed to be good. Nevertheless I currently consider to reinstall OpenCV using the script mentioned by @dkreutz
