Using KDGB on L4T 36.4
Hi all,
I wonder know whether can I use KGDB on Jetson Orin NX with custom carrier borad and L4T 36.4.4?
Hi r76121243,
Are you using the devkit or custom board for Orin NX?
Jetson Linux 36.4.4 does support Jetson Orin NX on a custom carrier board after the required board adaptation. However, KGDB over serial is not supported on Orin NX in the usual way, because KGDB requires a SoC-level UART and that is only available on AGX Orin.
So for Orin NX, the answer is no for standard KGDB usage on your custom carrier board with L4T 36.4.4.
Are you using the devkit or custom board for Orin NX? => custom board
Okay, I understand. Thanks for your reply.
