I’m trying to execute an npp function in multiple streams in parallel.
However, in the following example code, nppiMean_StdDev_8u_C1R returns NPP_RANGE_ERROR.
This example code creates two threads, and each thread tries to run nppiMean_StdDev_8u_C1R.
Each thread creates a stream and uses nppSetStream to set the cuda stream which the npp function should run on.
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include "npp.h"
#include "nppi.h"
#include <omp.h>
#include <opencv2/opencv.hpp>
int main()
#pragma omp parallel num_threads(2)
// Source image : 512x512 1channel 8bit, all pixels set to 5
GpuMat src(512, 512, CV_8UC1);
src.setTo(Scalar(5));
// Destination buffer where mean and stddev value is stored
GpuMat dst(1, 2, CV_64FC1);
// Create scratch buffer
int bufSize;
NppiSize sz;
sz.width = src.cols;
sz.height = src.rows;
nppSafeCall( nppiMeanStdDevGetBufferHostSize_8u_C1R(sz, &bufSize) );
GpuMat buf(1, bufSize, CV_8UC1);
// Create stream
cudaStream_t stream;
cudaStreamCreate(&stream);
// Set npp to use this stream
nppSetStream(stream);
nppSafeCall( nppiMean_StdDev_8u_C1R(src.ptr<Npp8u>(), static_cast<int>(src.step), sz, buf.ptr<Npp8u>(), dst.ptr<Npp64f>(), dst.ptr<Npp64f>() + 1) );
// Wait until npp call finish
cudaStreamSynchronize(stream);
// Destroy stream
cudaStreamDestroy(stream);
// Print output (expects mean = 5, stddev = 0)
Mat h_dst;
dst.download(h_dst);
std::string out = "thread" + std::to_string(omp_get_thread_num()) + " : (mean)" + std::to_string(h_dst.at<Npp64f>(0, 0)) + " (stddev)" + std::to_string(h_dst.at<Npp64f>(0, 1)) + "\n";
std::cout << out;
When I comment out line 32( nppSetStream(stream) ), the program ends with correct answer.
So my question is :
Is it not safe to use the npp function in multiple streams with setNppStream?
Thank you.
CUDA version : 8.0, 9.1
OS : Windows10
GPU : GTX 1080
Driver version : 388.19
Nice investigation, devnglee,
I made the source code more shorter.
Now the sample code which crashes on my laptop doesn’t rely on OpenCV at all.
It’s purely calling CUDA and NPP functions.
Am I doing something wrong ?
I hope someone from nvidia can give me a hand about this point.
