I’m here again.
This time I’m going to write an iteration solver GMRES to solve the linear system.
I know that the “iteration” is very hard to parallel.
Here is my situation.
I can’t get the correct data in the iteration, so the answer was always wrong.
Without openacc, the code is correct and the iteration will converges.
2 points:
- How to get the correct data in the iteration solver?
2.If we get the correct data, will it faster than cpu?
(Maybe for N is very large.)
Compile command : pgc++ -acc -ta=tesla -Minfo filename.cpp
Here’s my code:
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <time.h>
void print_vector(double *x, int N);
void matrix_vector(double *A, double *x, double *b, int N);
void print_matrixH(double *x, int N, int k);
void exact_solution(double *u, int N);
void initial(double *A, double *b, double *x0, int N);
void gmres(double *A, double *x, double *b, int N, int max_restart, int max_iter, double tol);
double error(double *x, double *y, int N);
int main()
int N, max_restart, max_iter;
clock_t t1, t2;
printf(" Please input N = ");
scanf("%d",&N);
printf(" Please input max restart times max_restart = ");
scanf("%d",&max_restart);
printf(" Please input max iteration times max_iter = ");
scanf("%d",&max_iter);
printf(" N = %d , max_restart = %d , max_iter = %d \n \n", N, max_restart, max_iter);
double *A, *x, *b, *u, tol;
A = (double *) malloc(N*N*sizeof(double));
x = (double *) malloc(N*sizeof(double));
b = (double *) malloc(N*sizeof(double));
u = (double *) malloc(N*sizeof(double));
exact_solution(u, N);
initial(A, b, x, N);
tol = 1.0e-4;
t1 = clock();
gmres(A, x, b, N, max_restart, max_iter, tol);
t2 = clock();
printf(" error = %e \n", error(x, u, N));
printf(" times = %f \n", 1.0*(t2-t1)/CLOCKS_PER_SEC);
return 0;
int i;
double temp, error;
error = 0.0;
for(i=0; i<N; i++)
temp = fabs(x[i] - y[i]);
if(temp > error) error = temp;
return error;
int i;
for(i=0; i<N; i++)
printf(" %f ", x[i]);
printf("\n");
void print_matrix(double *x, int N)
int i, j;
for(i=0;i<N;i++)
for (j=0;j<N;j++) printf(" %f ", x[N*i+j]);
printf("\n");
printf("\n");
int i, j;
for(i=0;i<=k;i++)
for (j=0;j<=k;j++) printf(" %f ", x[N*i+j]);
printf("\n");
printf("\n");
int i;
double h, x;
h = M_PI/(N+1);
for(i=0; i<N; i++)
x = (1+i)*h;
u[i] = x*sin(x);
int i, j;
double h, h2, temp, x;
h = M_PI/(N+1);
h2 = h*h;
for(i=0; i<N; i++)
for(j=0; j<N; j++)
A[N*i+j] = 0.0;
temp = -2.0/h2;
for(i=0; i<N; i++)
x0[i] = 0.0;
x = (1+i)*h;
b[i] = 2*cos(x) - x*sin(x);
A[N*i+i] = temp;
temp = 1.0/h2;
for(i=0; i<N-1; i++)
A[N*(i+1)+i] = temp;
A[N*i+(i+1)] = temp;
double norm(double *x, int N)
int i;
double norm;
norm=0.0;
#pragma acc parallel loop seq
for(i=0; i<N; i++)
norm += x[i]*x[i];
norm = sqrt(norm);
return norm;
double inner_product(double *x, double *y, int N)
int i;
double temp;
temp = 0.0;
#pragma acc parallel loop seq present(x[0:N], y[0:N])
for(i=0; i<N; i++)
temp += x[i]*y[i];
return temp;
int i, j;
#pragma acc parallel loop independent present(A[0:N*N], x[0:N], b[0:N])
for(i=0; i<N; i++)
b[i] = 0.0;
#pragma acc loop seq
for(j=0; j<N; j++)
b[i] += A[N*i+j]*x[j];
void q_subQ(double *q, double *Q, int N, int iter)
int i;
#pragma acc parallel loop independent present(q[0:N], Q[0:(N+1)*N])
for(i=0; i<N; i++)
q[i] = Q[(N+1)*i + iter];
void subQ_v(double *Q, double *v, int N, int iter, double norm_v)
int i;
#pragma acc parallel loop independent present(Q[0:(N+1)*N], v[0:N])
for(i=0; i<N; i++)
Q[(N+1)*i + iter] = v[i]/norm_v;
void v_shift(double *v, double *q, double h, int N)
int i;
#pragma acc parallel loop independent present(v[0:N], q[0:N])
for(i=0; i<N; i++)
v[i] -= h*q[i];
void backsolve(double *H, double *s, double *y, int N, int i)
// i = iter
int j, k;
double temp;
for(j=i; j>=0; j--)
temp = s[j];
for(k=j+1; k<=i; k++)
temp -= y[k]*H[N*j+k];
y[j] = temp/H[N*j+j];
void GeneratePlaneRotation(double dx, double dy, double *cs, double *sn, int i)
double temp;
if (dy == 0.0)
cs[i] = 1.0;
sn[i] = 0.0;
else if (fabs(dy) > fabs(dx))
temp = dx / dy;
sn[i] = 1.0 / sqrt( 1.0 + temp*temp );
cs[i] = temp * sn[i];
else
temp = dy / dx;
cs[i] = 1.0 / sqrt( 1.0 + temp*temp );
sn[i] = temp * cs[i];
/*void ApplyPlaneRotation(Real &dx, Real &dy, Real &cs, Real &sn)
Real temp = cs * dx + sn * dy;
dy = -sn * dx + cs * dy;
dx = temp;
int i, j, k, m;
double resid, normb, beta, temp, *tempv, *r, *q, *v, *cs, *sn, *s, *y, *Q, *H;
Q = (double *) malloc(N*(N+1)*sizeof(double));
H = (double *) malloc((N+1)*N*sizeof(double));
tempv = (double *) malloc(N*sizeof(double));
r = (double *) malloc(N*sizeof(double));
q = (double *) malloc(N*sizeof(double));
cs = (double *) malloc((N+1)*sizeof(double));
sn = (double *) malloc((N+1)*sizeof(double));
y = (double *) malloc(N*sizeof(double));
/* for(i=0; i<N+1; i++)
cs[i] = 0.0;
sn[i] = 0.0;
s[i] = 0.0;
for(k=0; k<N; k++)
Q[N*i+k] = 0.0;
H[N*i+k] = 0.0;
normb = norm(b, N);
#pragma acc data create(Q[0:(N+1)*N], H[0:(N+1)*N], tempv[0:N], r[0:N], q[0:N], v[0:N], cs[0:N+1], sn[0:N+1], s[0:N+1], y[0:N]), copyin(A[0:N*N], b[0:N]), copyout(x[0:N])
matrix_vector(A, x, tempv, N);
for (i=0; i<N; i++) r[i] = b[i] - tempv[i];
beta = norm(r, N);
for (m=0; m<max_restart; m++)
for (i=0; i<N; i++)
s[i+1] = 0.0;
Q[(N+1)*i+0] = r[i]/beta;
s[0] = beta;
for (i = 0; i<max_iter; i++)
q_subQ(q, Q, N, i);
matrix_vector(A, q, v, N);
for (k=0; k<=i; k++)
q_subQ(q, Q, N, k);
H[N*k+i] = inner_product(q, v, N);
v_shift(v, q, H[N*k+i], N);
H[N*(i+1)+i] = norm(v, N);
subQ_v(Q, v, N, i+1, H[N*(i+1)+i]);
for (k = 0; k < i; k++)
//ApplyPlaneRotation(H(k,i), H(k+1,i), cs(k), sn(k))
temp = cs[k]*H[N*k+i] + sn[k]*H[N*(k+1)+i];
H[N*(k+1)+i] = -1.0*sn[k]*H[N*k+i] + cs[k]*H[N*(k+1)+i];
H[N*k+i] = temp;
GeneratePlaneRotation(H[N*i+i], H[N*(i+1)+i], cs, sn, i);
//ApplyPlaneRotation(H(i,i), H(i+1,i), cs(i), sn(i))
H[N*i+i] = cs[i]*H[N*i+i] + sn[i]*H[N*(i+1)+i];
H[N*(i+1)+i] = 0.0;
//ApplyPlaneRotation(s(i), s(i+1), cs(i), sn(i));
temp = cs[i]*s[i];
s[i+1] = -1.0*sn[i]*s[i];
s[i] = temp;
resid = fabs(s[i+1]/beta);
if (resid < tol)
printf(" resid = %e \n", resid);
printf(" Converges at %d step ", i+1);
backsolve(H, s, y, N, i);
for(j=0; j<N; j++)
for(k=0; k<=i; k++)
x[j] += Q[(N+1)*j+k]*y[k];
break;
}//end inside for
// Caution : i = i + 1.
if (resid < tol)
printf(" %d cycle \n", m);
break;
backsolve(H, s, y, N, i-1);
for(j=0; j<N; j++)
for(k=0; k<=i-1; k++)
for (j=0; j<N; j++) r[j] = b[j] - tempv[j];
beta = norm(r, N);
s[i] = beta;
resid = s[i]/normb;
if ( resid < tol)
printf(" Converges at %d cycle %d step. \n", m, i);
break;
}//end outside for
}//end pragma acc
