Using SED (Self-encrypting drive) on Jetson Orin Nano
i would like to use an SED drive on Orin Jetson Nano and install jetpack on it. I saw some high-level information about using sedutil and u-boot configuration.
  1. I am using Jetpack.
  2. I want to use SED and use sedutil to lock and unlock the drive. I don’t need any other encyption like LUKS.
  3. Based from what i’ve read, I need to run the sedutil via u-boot to unlock the SED before it boots up.
  4. Regarding u-boot configuration, should I use the u-boot source code from here GitHub - u-boot/u-boot: "Das U-Boot" Source Tree or is there a specific U-boot source code that i should use for the Jetpack?
  5. Do i really need to modify the u-boot? Are there any other alternatives to be able to unlock the SED before it boots up?
thanks
just for confirmation, you’re working with Jetson Nano (t210) instead of Jetson Orin Nano (t234), right?
it’s due to t234 series is not using uboot
yes, I’m using t234 Jetson Orin Nano. And is this absence of u-boot mentioned on any documentation online?
Based from what I’ve researched, I need to call the sedutil command on u-boot to be able to unlock the SED. If Orin Nano isn’t using u-boot, what are my options to be able to unlock the SED before it boots-up?
thank you
hello nvidiartx10000,
the boot sequence is… MB1 → MB2 → UEFI → linux kernel.
it’s UEFI uses an OS loader (L4TLauncher) to load the file system,
you may please refer to developer guide, UEFI Adaptation for more details.
Hi Jerry,
I read the UEFI adaptation but I am a bit lost. I dont have much experience with UEFI but I’ll ask anyway and might need some guidance.
I have an executable compiled in C that unlocks the Self Encrypting Drive. I need to run this executable, which will ask for a passphrase, before the SED gets mounted and/or before the kernel gets loaded. This SED has a Jetpack OS installed on it.
Given that the SED drive is locked on power-up, how will i be able to execute and include this executable on boot-up before the Jetson Nano accesses the SED drive with the Jetpack OS on it? (by the way, I wont be using LUKS, i will solely use the SED’s hardware encryption/decryption)
thanks
as you can see per Disk Encryption section, it uses EKB key to flash a target to enable disk encryption.
we’re not supported with a prompt for passphrase to unlock. please customize it by yourself.
