I’m using Thrust library to do some operations with vectors.Here is a simple example of the code and the error:
int maxthrust(float*a,int dim){
thrust::device_vector<float> mat(dim);
thrust::copy(a,a+dim,mat.begin());
int max = thrust::reduce(mat.begin(), mat.end(), -1,thrust::maximum<int>());
return max;
int main(){
float* a_h=(float*)malloc(10*sizeof(float));
thrust::sequence(a_h, a_h + 10, 0);
maxthrust(a_h,10);
When I execute there is the following error:
terminate called after throwing an instance of ‘std::bad_alloc’
what(): St9bad_alloc
Aborted
I think it is strange this error because I thought it only happens when there is a very large vector.
Thanks in advance
