V4l2src & nvvideoconvert connection issue
• Hardware Platform (DGPU)
• DeepStream Version - 6.2
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) - 535
• Issue Type( questions, new requirements, bugs) - Questions
[Note: I am using NV Docker container]
I am trying to run deepstream gst pipeline using v4l camera.
Some point to note that I am able to successfully do the below things
  1. Able to run “deepstream-app -c source1_usb_dec_infer_resnet_int8.txt”
  2. Able to check the device by v4l2-ctl -d /dev/video0 --list-formats-ext. Below is the output
    ioctl: VIDIOC_ENUM_FMT
    Type: Video Capture
     	Interval: Discrete 0.033s (30.000 fps)
     	Interval: Discrete 0.100s (10.000 fps)
Now, when I try to run the below pipeline
“gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw,format=YUY2,width=640,height=480,framerate=30/1’ ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! fakesink”
I am getting error as below
“WARNING: erroneous pipeline: could not link v4l2src0 to nvvideoconvert0, nvvideoconvert0 can’t handle caps video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, framerate=(fraction)30/1”
Kindly clarify.
What’s the format of your camera video?
It is ‘YUYV’ (YUYV 4:2:2). v4l2-ctl -d /dev/video0 --list-formats-ext returns below.
Type: Video Capture
[0]: 'MJPG' (Motion-JPEG, compressed)
**[1]: 'YUYV' (YUYV 4:2:2)**
But you set the format to YUY2 in your pipeline. Could you try to change that and run the pipeline?
But it is still giving the same error
WARNING: erroneous pipeline: could not link v4l2src0 to nvvideoconvert0, neither element can handle caps video/x-raw, format=(string)YUYV, width=(int)640, height=(int)480, framerate=(fraction)30/1
BTW, Earlier I had set it to YUY2 (even though my format is YUYV) based on one of the comment from NVIDIA member on this post.
However, even if I give YUYV, it still throws same error
Command used this time :
gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw,format=YUYV,width=640,height=480,framerate=30/1’ ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! fakesink
OK. Could you refer to the 28.3.2 of the FAQ and try to add a videoconvert first?
It worked.
Thanks for the support.
BTW, Using the same camera set up,
When I run “deepstream-app -c source1_usb_dec_infer_resnet_int8.txt”, the video runs smoothly without any lag.
However, when I try the below gst pipeline, the video lags a lot and not smooth and I also get message like “WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: A lot of buffers are being dropped.”
gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw,format=YUY2,width=640,height=480,framerate=30/1’ ! videoconvert ! ‘video/x-raw, format=NV12’ ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt batch-size=1 unique-id=1 ! nvtracker ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so ! nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvvideoconvert ! nvdsosd ! nveglglessink
Am I missing in the pipeline?
You can try to set the same parameter of each plugin. Like nvstreammux, you can set the batched-push-timeout=40000, live-source=1, etc…
When I used sync=0, it worked
