I am getting the following syntax error:
“Syntax error at or near <”
I can work around this problem by replacing the statement with something like this:
901 format(a25,’ = ',i6)
We like to use variables in FORMAT statements in some cases. In a post from 2007 I read that this was supported in F77 but is not for current versions. Is this still true? The documentation states that this is supported.
I am using PGI Visual FoORTRAN 2008 on Windows Vista.
Below is a reply related to this topic. I am trying to find out if this is still current or if something is in the works. Good workarounds are also appreciated.
Thanks,
Tom
Posted: Thu Nov 29, 2007 12:23 pm
Hi Catherine,
Unfornately, we currently support only pgf77. If possible, please try to modify your program to be f77 for now. We have filed a TPR# 14158 for pgf90 support.
Unfortunately, this feature is still only supported in pgf77. What I would suggest is to build your format string into an character array. It’s a little awkward but more portable. For example:
% cat testme.f90
program testme
character (100) chr
chr = 'TESTME'
call test(chr, 6, 6, 0)
chr = 'TESTME AGAIN'
call test(chr, 12, 12, 0)
end program testme
subroutine test (variable_name, varnamelength, variable_value, output_unit)
integer output_unit
integer varnamelength
character*(*) variable_name
integer*2 variable_value
character*(varnamelength) varname
character(100) frmt
varname=adjustl(variable_name)
write(frmt,*) '(a', varnamelength, ''' = '', i6)'
write(*,frmt) varname, variable_value
end subroutine test
% pgf90 testme.f90 -o testme.out
% testme.out
TESTME = 6
TESTME AGAIN = 12
this will help. I guess variable formatting is a legacy extension and not in the newer FORTRAN standard. Gnu and Sun don’t seem to support it either. Thanks for the code.
