Vast.ai support gb10 (host/renter)
ARM Support is Live!
Vast now officially supports ARM-based NVIDIA machines.
GB10s (DGX Sparks) are now rentable in the UI
Host installer now works on almost any ARM-based NVIDIA machine β€” see the host setup guide
Issues getting your ARM machine online? check host discord.
Good way to test before buying :)
If we could rent out our idle sparks that would be great otherwise this is just a ad.
I see 0 gb10’s anyways
You can rent it out, but nothing comes for free, vast.ai is a process. claude and co solves most of the hurdles.
And building up a inventory takes time.
So not an ad, assume more machines will pop up over time. Less machines, potensiale higher price per hour. Time will tell.
renting it out at .35 at 30% what vast takes .. will take 7 years to recoop the cost of the unit - and thats assuming full utilisation .. which i assume with gb10’s is sub 10% as there is generally a small market for those slow devices - agentic stuff wants fast compute - so h100/h200/b200/b300 - if your agent f’ks up which it will eventually you want it to be fast anyway ..
specially if you can rent a 6000 pro for sub 1usd / hour
good luck im happy to eat my words - yet i can not see an economic viability
Yeah and when you have RTX6000 for 0.7 per hour or majestic GH200 96GB that has 10x speed of Spark at 2$ per hour - who in sane mind will rent spark.
So GB10 already dead on arrival, and how will this be for the laptop chip?
Could be they prepping for GB300, which might be more exciting
Some machines showing
local and renting serves different markets - the gb10 was never a inference mashine - it was/is a POC mashine for dgx aka b200/b300 to play with connect x7 β†’ if you have to rent a 8 node cluster just to test if your code is working .. and that takes you a week you burn the same amount of cash the 8x gb10 cost you (formal validation of distributed code doesnt need speed) - different story for inference - there is just no way anyone wants to rent that for prod / agentic inference where speed = result
the community just made good work of it so it gets an actuall second life / every day use - you would not rent such a mashine
also the prices on there are ludacrist
  • thats a week rental on scan.co.uk - and those are already very expensive - so i be very very impressed why people would pay more on vast
