Very slow initialization of training and first epoch
• Hardware (RTX 3070)
• Network Type (Yolo_v4)
• TLT Version
Configuration of the TLT Instance
dockers:
        nvidia/tlt-streamanalytics:
                docker_registry: nvcr.io
                docker_tag: v3.0-py3
                tasks:
                        1. augment
                        2. bpnet
                        3. classification
                        4. detectnet_v2
                        5. dssd
                        6. emotionnet
                        7. faster_rcnn
                        8. fpenet
                        9. gazenet
                        10. gesturenet
                        11. heartratenet
                        12. lprnet
                        13. mask_rcnn
                        14. multitask_classification
                        15. retinanet
                        16. ssd
                        17. unet
                        18. yolo_v3
                        19. yolo_v4
                        20. tlt-converter
        nvidia/tlt-pytorch:
                tasks:
                        1. speech_to_text
                        2. speech_to_text_citrinet
                        3. text_classification
                        4. question_answering
                        5. token_classification
                        6. intent_slot_classification
                        7. punctuation_and_capitalization
format_version: 1.0
tlt_version: 3.0
published_date: 04/16/2021
• Training spec file(default spec file from Yolo_v4)
• How to reproduce the issue?
Run tlt yolo_v4 train with parameters from the sample notebook.
I had to wait 10+ minutes for training just to start. How can I try to debug it?
Where did you need to wait for 10+ minutes? Did you have logs?
There is a known limitation for slow training speed in each epoch. But it will not take a long time before you see “Epoch 1” after initialization.
So I start a tlt train command at
2021-07-02 12:20:11,719
at
2021-07-02 12:20:27,750 - loading a model (3 minutes)
2021-07-02 12:23:20,990 - message about dataset (I have 10 images in dataset)
I wait here for several minutes
10 minutes for 1 epoch
Epoch 1/1
2/10 [=====>…] - ETA: 34:42 - loss: 96.4671 /usr/local/lib/python3.6/dist-packages/keras/callbacks.py:122: UserWarning: Method on_batch_end() is slow compared to the batch update (3.052041). Check your callbacks.
% delta_t_median)
10/10 [==============================] - 522s 52s/step - loss: 92.5794
Whole logs
To run with multigpu, please change --gpus based on the number of available GPUs in your machine.
2021-07-02 14:20:11,719 [INFO] root: Registry: ['nvcr.io']
2021-07-02 14:20:11,998 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the ~/.tlt_mounts.json file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-07-02 12:20:17,634 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-07-02 12:20:17,634 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:52: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2021-07-02 12:20:17,760 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:52: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:55: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-07-02 12:20:17,761 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:55: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-07-02 12:20:18,079 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-07-02 12:20:18,080 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-07-02 12:20:18,097 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2021-07-02 12:20:19,463 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-07-02 12:20:19,488 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
2021-07-02 12:20:22,664 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-07-02 12:20:23,062 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-07-02 12:20:23,063 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-07-02 12:20:24,383 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
2021-07-02 12:20:26,412 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:3295: The name tf.log is deprecated. Please use tf.math.log instead.
2021-07-02 12:20:26,416 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:3295: The name tf.log is deprecated. Please use tf.math.log instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2021-07-02 12:20:27,418 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2021-07-02 12:20:27,750 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
__________________________________________________________________________________________________
Layer (type)                    Output Shape         Param #     Connected to
Input (InputLayer)              (None, 3, 384, 384)  0
conv1 (Conv2D)                  (None, 64, 192, 192) 9408        Input[0][0]
bn_conv1 (BatchNormalization)   (None, 64, 192, 192) 256         conv1[0][0]
activation_2 (Activation)       (None, 64, 192, 192) 0           bn_conv1[0][0]
block_1a_conv_1 (Conv2D)        (None, 64, 96, 96)   4096        activation_2[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 96, 96)   256         block_1a_conv_1[0][0]
block_1a_relu_1 (Activation)    (None, 64, 96, 96)   0           block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D)        (None, 64, 96, 96)   36864       block_1a_relu_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 96, 96)   256         block_1a_conv_2[0][0]
block_1a_relu_2 (Activation)    (None, 64, 96, 96)   0           block_1a_bn_2[0][0]
block_1a_conv_3 (Conv2D)        (None, 256, 96, 96)  16384       block_1a_relu_2[0][0]
block_1a_conv_shortcut (Conv2D) (None, 256, 96, 96)  16384       activation_2[0][0]
block_1a_bn_3 (BatchNormalizati (None, 256, 96, 96)  1024        block_1a_conv_3[0][0]
block_1a_bn_shortcut (BatchNorm (None, 256, 96, 96)  1024        block_1a_conv_shortcut[0][0]
add_17 (Add)                    (None, 256, 96, 96)  0           block_1a_bn_3[0][0]
        block_1a_bn_shortcut[0][0]
block_1a_relu (Activation)      (None, 256, 96, 96)  0           add_17[0][0]
block_1b_conv_1 (Conv2D)        (None, 64, 96, 96)   16384       block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 96, 96)   256         block_1b_conv_1[0][0]
block_1b_relu_1 (Activation)    (None, 64, 96, 96)   0           block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D)        (None, 64, 96, 96)   36864       block_1b_relu_1[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 96, 96)   256         block_1b_conv_2[0][0]
block_1b_relu_2 (Activation)    (None, 64, 96, 96)   0           block_1b_bn_2[0][0]
block_1b_conv_3 (Conv2D)        (None, 256, 96, 96)  16384       block_1b_relu_2[0][0]
block_1b_conv_shortcut (Conv2D) (None, 256, 96, 96)  65536       block_1a_relu[0][0]
block_1b_bn_3 (BatchNormalizati (None, 256, 96, 96)  1024        block_1b_conv_3[0][0]
block_1b_bn_shortcut (BatchNorm (None, 256, 96, 96)  1024        block_1b_conv_shortcut[0][0]
add_18 (Add)                    (None, 256, 96, 96)  0           block_1b_bn_3[0][0]
        block_1b_bn_shortcut[0][0]
block_1b_relu (Activation)      (None, 256, 96, 96)  0           add_18[0][0]
block_1c_conv_1 (Conv2D)        (None, 64, 96, 96)   16384       block_1b_relu[0][0]
block_1c_bn_1 (BatchNormalizati (None, 64, 96, 96)   256         block_1c_conv_1[0][0]
block_1c_relu_1 (Activation)    (None, 64, 96, 96)   0           block_1c_bn_1[0][0]
block_1c_conv_2 (Conv2D)        (None, 64, 96, 96)   36864       block_1c_relu_1[0][0]
block_1c_bn_2 (BatchNormalizati (None, 64, 96, 96)   256         block_1c_conv_2[0][0]
block_1c_relu_2 (Activation)    (None, 64, 96, 96)   0           block_1c_bn_2[0][0]
block_1c_conv_3 (Conv2D)        (None, 256, 96, 96)  16384       block_1c_relu_2[0][0]
block_1c_conv_shortcut (Conv2D) (None, 256, 96, 96)  65536       block_1b_relu[0][0]
block_1c_bn_3 (BatchNormalizati (None, 256, 96, 96)  1024        block_1c_conv_3[0][0]
block_1c_bn_shortcut (BatchNorm (None, 256, 96, 96)  1024        block_1c_conv_shortcut[0][0]
add_19 (Add)                    (None, 256, 96, 96)  0           block_1c_bn_3[0][0]
        block_1c_bn_shortcut[0][0]
block_1c_relu (Activation)      (None, 256, 96, 96)  0           add_19[0][0]
block_2a_conv_1 (Conv2D)        (None, 128, 48, 48)  32768       block_1c_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 48, 48)  512         block_2a_conv_1[0][0]
block_2a_relu_1 (Activation)    (None, 128, 48, 48)  0           block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D)        (None, 128, 48, 48)  147456      block_2a_relu_1[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 48, 48)  512         block_2a_conv_2[0][0]
block_2a_relu_2 (Activation)    (None, 128, 48, 48)  0           block_2a_bn_2[0][0]
block_2a_conv_3 (Conv2D)        (None, 512, 48, 48)  65536       block_2a_relu_2[0][0]
block_2a_conv_shortcut (Conv2D) (None, 512, 48, 48)  131072      block_1c_relu[0][0]
block_2a_bn_3 (BatchNormalizati (None, 512, 48, 48)  2048        block_2a_conv_3[0][0]
block_2a_bn_shortcut (BatchNorm (None, 512, 48, 48)  2048        block_2a_conv_shortcut[0][0]
add_20 (Add)                    (None, 512, 48, 48)  0           block_2a_bn_3[0][0]
        block_2a_bn_shortcut[0][0]
block_2a_relu (Activation)      (None, 512, 48, 48)  0           add_20[0][0]
block_2b_conv_1 (Conv2D)        (None, 128, 48, 48)  65536       block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 48, 48)  512         block_2b_conv_1[0][0]
block_2b_relu_1 (Activation)    (None, 128, 48, 48)  0           block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D)        (None, 128, 48, 48)  147456      block_2b_relu_1[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 48, 48)  512         block_2b_conv_2[0][0]
block_2b_relu_2 (Activation)    (None, 128, 48, 48)  0           block_2b_bn_2[0][0]
block_2b_conv_3 (Conv2D)        (None, 512, 48, 48)  65536       block_2b_relu_2[0][0]
block_2b_conv_shortcut (Conv2D) (None, 512, 48, 48)  262144      block_2a_relu[0][0]
block_2b_bn_3 (BatchNormalizati (None, 512, 48, 48)  2048        block_2b_conv_3[0][0]
block_2b_bn_shortcut (BatchNorm (None, 512, 48, 48)  2048        block_2b_conv_shortcut[0][0]
add_21 (Add)                    (None, 512, 48, 48)  0           block_2b_bn_3[0][0]
        block_2b_bn_shortcut[0][0]
block_2b_relu (Activation)      (None, 512, 48, 48)  0           add_21[0][0]
block_2c_conv_1 (Conv2D)        (None, 128, 48, 48)  65536       block_2b_relu[0][0]
block_2c_bn_1 (BatchNormalizati (None, 128, 48, 48)  512         block_2c_conv_1[0][0]
block_2c_relu_1 (Activation)    (None, 128, 48, 48)  0           block_2c_bn_1[0][0]
block_2c_conv_2 (Conv2D)        (None, 128, 48, 48)  147456      block_2c_relu_1[0][0]
block_2c_bn_2 (BatchNormalizati (None, 128, 48, 48)  512         block_2c_conv_2[0][0]
block_2c_relu_2 (Activation)    (None, 128, 48, 48)  0           block_2c_bn_2[0][0]
block_2c_conv_3 (Conv2D)        (None, 512, 48, 48)  65536       block_2c_relu_2[0][0]
block_2c_conv_shortcut (Conv2D) (None, 512, 48, 48)  262144      block_2b_relu[0][0]
block_2c_bn_3 (BatchNormalizati (None, 512, 48, 48)  2048        block_2c_conv_3[0][0]
block_2c_bn_shortcut (BatchNorm (None, 512, 48, 48)  2048        block_2c_conv_shortcut[0][0]
add_22 (Add)                    (None, 512, 48, 48)  0           block_2c_bn_3[0][0]
        block_2c_bn_shortcut[0][0]
block_2c_relu (Activation)      (None, 512, 48, 48)  0           add_22[0][0]
block_2d_conv_1 (Conv2D)        (None, 128, 48, 48)  65536       block_2c_relu[0][0]
block_2d_bn_1 (BatchNormalizati (None, 128, 48, 48)  512         block_2d_conv_1[0][0]
block_2d_relu_1 (Activation)    (None, 128, 48, 48)  0           block_2d_bn_1[0][0]
block_2d_conv_2 (Conv2D)        (None, 128, 48, 48)  147456      block_2d_relu_1[0][0]
block_2d_bn_2 (BatchNormalizati (None, 128, 48, 48)  512         block_2d_conv_2[0][0]
block_2d_relu_2 (Activation)    (None, 128, 48, 48)  0           block_2d_bn_2[0][0]
block_2d_conv_3 (Conv2D)        (None, 512, 48, 48)  65536       block_2d_relu_2[0][0]
block_2d_conv_shortcut (Conv2D) (None, 512, 48, 48)  262144      block_2c_relu[0][0]
block_2d_bn_3 (BatchNormalizati (None, 512, 48, 48)  2048        block_2d_conv_3[0][0]
block_2d_bn_shortcut (BatchNorm (None, 512, 48, 48)  2048        block_2d_conv_shortcut[0][0]
add_23 (Add)                    (None, 512, 48, 48)  0           block_2d_bn_3[0][0]
        block_2d_bn_shortcut[0][0]
block_2d_relu (Activation)      (None, 512, 48, 48)  0           add_23[0][0]
block_3a_conv_1 (Conv2D)        (None, 256, 24, 24)  131072      block_2d_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 24, 24)  1024        block_3a_conv_1[0][0]
block_3a_relu_1 (Activation)    (None, 256, 24, 24)  0           block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D)        (None, 256, 24, 24)  589824      block_3a_relu_1[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 24, 24)  1024        block_3a_conv_2[0][0]
block_3a_relu_2 (Activation)    (None, 256, 24, 24)  0           block_3a_bn_2[0][0]
block_3a_conv_3 (Conv2D)        (None, 1024, 24, 24) 262144      block_3a_relu_2[0][0]
block_3a_conv_shortcut (Conv2D) (None, 1024, 24, 24) 524288      block_2d_relu[0][0]
block_3a_bn_3 (BatchNormalizati (None, 1024, 24, 24) 4096        block_3a_conv_3[0][0]
block_3a_bn_shortcut (BatchNorm (None, 1024, 24, 24) 4096        block_3a_conv_shortcut[0][0]
add_24 (Add)                    (None, 1024, 24, 24) 0           block_3a_bn_3[0][0]
        block_3a_bn_shortcut[0][0]
block_3a_relu (Activation)      (None, 1024, 24, 24) 0           add_24[0][0]
block_3b_conv_1 (Conv2D)        (None, 256, 24, 24)  262144      block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 24, 24)  1024        block_3b_conv_1[0][0]
block_3b_relu_1 (Activation)    (None, 256, 24, 24)  0           block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D)        (None, 256, 24, 24)  589824      block_3b_relu_1[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 24, 24)  1024        block_3b_conv_2[0][0]
block_3b_relu_2 (Activation)    (None, 256, 24, 24)  0           block_3b_bn_2[0][0]
block_3b_conv_3 (Conv2D)        (None, 1024, 24, 24) 262144      block_3b_relu_2[0][0]
block_3b_conv_shortcut (Conv2D) (None, 1024, 24, 24) 1048576     block_3a_relu[0][0]
block_3b_bn_3 (BatchNormalizati (None, 1024, 24, 24) 4096        block_3b_conv_3[0][0]
block_3b_bn_shortcut (BatchNorm (None, 1024, 24, 24) 4096        block_3b_conv_shortcut[0][0]
add_25 (Add)                    (None, 1024, 24, 24) 0           block_3b_bn_3[0][0]
        block_3b_bn_shortcut[0][0]
block_3b_relu (Activation)      (None, 1024, 24, 24) 0           add_25[0][0]
block_3c_conv_1 (Conv2D)        (None, 256, 24, 24)  262144      block_3b_relu[0][0]
block_3c_bn_1 (BatchNormalizati (None, 256, 24, 24)  1024        block_3c_conv_1[0][0]
block_3c_relu_1 (Activation)    (None, 256, 24, 24)  0           block_3c_bn_1[0][0]
block_3c_conv_2 (Conv2D)        (None, 256, 24, 24)  589824      block_3c_relu_1[0][0]
block_3c_bn_2 (BatchNormalizati (None, 256, 24, 24)  1024        block_3c_conv_2[0][0]
block_3c_relu_2 (Activation)    (None, 256, 24, 24)  0           block_3c_bn_2[0][0]
block_3c_conv_3 (Conv2D)        (None, 1024, 24, 24) 262144      block_3c_relu_2[0][0]
block_3c_conv_shortcut (Conv2D) (None, 1024, 24, 24) 1048576     block_3b_relu[0][0]
block_3c_bn_3 (BatchNormalizati (None, 1024, 24, 24) 4096        block_3c_conv_3[0][0]
block_3c_bn_shortcut (BatchNorm (None, 1024, 24, 24) 4096        block_3c_conv_shortcut[0][0]
add_26 (Add)                    (None, 1024, 24, 24) 0           block_3c_bn_3[0][0]
        block_3c_bn_shortcut[0][0]
block_3c_relu (Activation)      (None, 1024, 24, 24) 0           add_26[0][0]
block_3d_conv_1 (Conv2D)        (None, 256, 24, 24)  262144      block_3c_relu[0][0]
block_3d_bn_1 (BatchNormalizati (None, 256, 24, 24)  1024        block_3d_conv_1[0][0]
block_3d_relu_1 (Activation)    (None, 256, 24, 24)  0           block_3d_bn_1[0][0]
block_3d_conv_2 (Conv2D)        (None, 256, 24, 24)  589824      block_3d_relu_1[0][0]
block_3d_bn_2 (BatchNormalizati (None, 256, 24, 24)  1024        block_3d_conv_2[0][0]
block_3d_relu_2 (Activation)    (None, 256, 24, 24)  0           block_3d_bn_2[0][0]
block_3d_conv_3 (Conv2D)        (None, 1024, 24, 24) 262144      block_3d_relu_2[0][0]
block_3d_conv_shortcut (Conv2D) (None, 1024, 24, 24) 1048576     block_3c_relu[0][0]
block_3d_bn_3 (BatchNormalizati (None, 1024, 24, 24) 4096        block_3d_conv_3[0][0]
block_3d_bn_shortcut (BatchNorm (None, 1024, 24, 24) 4096        block_3d_conv_shortcut[0][0]
add_27 (Add)                    (None, 1024, 24, 24) 0           block_3d_bn_3[0][0]
        block_3d_bn_shortcut[0][0]
block_3d_relu (Activation)      (None, 1024, 24, 24) 0           add_27[0][0]
block_3e_conv_1 (Conv2D)        (None, 256, 24, 24)  262144      block_3d_relu[0][0]
block_3e_bn_1 (BatchNormalizati (None, 256, 24, 24)  1024        block_3e_conv_1[0][0]
block_3e_relu_1 (Activation)    (None, 256, 24, 24)  0           block_3e_bn_1[0][0]
block_3e_conv_2 (Conv2D)        (None, 256, 24, 24)  589824      block_3e_relu_1[0][0]
block_3e_bn_2 (BatchNormalizati (None, 256, 24, 24)  1024        block_3e_conv_2[0][0]
block_3e_relu_2 (Activation)    (None, 256, 24, 24)  0           block_3e_bn_2[0][0]
block_3e_conv_3 (Conv2D)        (None, 1024, 24, 24) 262144      block_3e_relu_2[0][0]
block_3e_conv_shortcut (Conv2D) (None, 1024, 24, 24) 1048576     block_3d_relu[0][0]
block_3e_bn_3 (BatchNormalizati (None, 1024, 24, 24) 4096        block_3e_conv_3[0][0]
block_3e_bn_shortcut (BatchNorm (None, 1024, 24, 24) 4096        block_3e_conv_shortcut[0][0]
add_28 (Add)                    (None, 1024, 24, 24) 0           block_3e_bn_3[0][0]
        block_3e_bn_shortcut[0][0]
block_3e_relu (Activation)      (None, 1024, 24, 24) 0           add_28[0][0]
block_3f_conv_1 (Conv2D)        (None, 256, 24, 24)  262144      block_3e_relu[0][0]
block_3f_bn_1 (BatchNormalizati (None, 256, 24, 24)  1024        block_3f_conv_1[0][0]
block_3f_relu_1 (Activation)    (None, 256, 24, 24)  0           block_3f_bn_1[0][0]
block_3f_conv_2 (Conv2D)        (None, 256, 24, 24)  589824      block_3f_relu_1[0][0]
block_3f_bn_2 (BatchNormalizati (None, 256, 24, 24)  1024        block_3f_conv_2[0][0]
block_3f_relu_2 (Activation)    (None, 256, 24, 24)  0           block_3f_bn_2[0][0]
block_3f_conv_3 (Conv2D)        (None, 1024, 24, 24) 262144      block_3f_relu_2[0][0]
block_3f_conv_shortcut (Conv2D) (None, 1024, 24, 24) 1048576     block_3e_relu[0][0]
block_3f_bn_3 (BatchNormalizati (None, 1024, 24, 24) 4096        block_3f_conv_3[0][0]
block_3f_bn_shortcut (BatchNorm (None, 1024, 24, 24) 4096        block_3f_conv_shortcut[0][0]
add_29 (Add)                    (None, 1024, 24, 24) 0           block_3f_bn_3[0][0]
        block_3f_bn_shortcut[0][0]
block_3f_relu (Activation)      (None, 1024, 24, 24) 0           add_29[0][0]
block_4a_conv_1 (Conv2D)        (None, 512, 24, 24)  524288      block_3f_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 24, 24)  2048        block_4a_conv_1[0][0]
block_4a_relu_1 (Activation)    (None, 512, 24, 24)  0           block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D)        (None, 512, 24, 24)  2359296     block_4a_relu_1[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 24, 24)  2048        block_4a_conv_2[0][0]
block_4a_relu_2 (Activation)    (None, 512, 24, 24)  0           block_4a_bn_2[0][0]
block_4a_conv_3 (Conv2D)        (None, 2048, 24, 24) 1048576     block_4a_relu_2[0][0]
block_4a_conv_shortcut (Conv2D) (None, 2048, 24, 24) 2097152     block_3f_relu[0][0]
block_4a_bn_3 (BatchNormalizati (None, 2048, 24, 24) 8192        block_4a_conv_3[0][0]
block_4a_bn_shortcut (BatchNorm (None, 2048, 24, 24) 8192        block_4a_conv_shortcut[0][0]
add_30 (Add)                    (None, 2048, 24, 24) 0           block_4a_bn_3[0][0]
        block_4a_bn_shortcut[0][0]
block_4a_relu (Activation)      (None, 2048, 24, 24) 0           add_30[0][0]
block_4b_conv_1 (Conv2D)        (None, 512, 24, 24)  1048576     block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 24, 24)  2048        block_4b_conv_1[0][0]
block_4b_relu_1 (Activation)    (None, 512, 24, 24)  0           block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D)        (None, 512, 24, 24)  2359296     block_4b_relu_1[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 24, 24)  2048        block_4b_conv_2[0][0]
block_4b_relu_2 (Activation)    (None, 512, 24, 24)  0           block_4b_bn_2[0][0]
block_4b_conv_3 (Conv2D)        (None, 2048, 24, 24) 1048576     block_4b_relu_2[0][0]
block_4b_conv_shortcut (Conv2D) (None, 2048, 24, 24) 4194304     block_4a_relu[0][0]
block_4b_bn_3 (BatchNormalizati (None, 2048, 24, 24) 8192        block_4b_conv_3[0][0]
block_4b_bn_shortcut (BatchNorm (None, 2048, 24, 24) 8192        block_4b_conv_shortcut[0][0]
add_31 (Add)                    (None, 2048, 24, 24) 0           block_4b_bn_3[0][0]
        block_4b_bn_shortcut[0][0]
block_4b_relu (Activation)      (None, 2048, 24, 24) 0           add_31[0][0]
block_4c_conv_1 (Conv2D)        (None, 512, 24, 24)  1048576     block_4b_relu[0][0]
block_4c_bn_1 (BatchNormalizati (None, 512, 24, 24)  2048        block_4c_conv_1[0][0]
block_4c_relu_1 (Activation)    (None, 512, 24, 24)  0           block_4c_bn_1[0][0]
block_4c_conv_2 (Conv2D)        (None, 512, 24, 24)  2359296     block_4c_relu_1[0][0]
block_4c_bn_2 (BatchNormalizati (None, 512, 24, 24)  2048        block_4c_conv_2[0][0]
block_4c_relu_2 (Activation)    (None, 512, 24, 24)  0           block_4c_bn_2[0][0]
block_4c_conv_3 (Conv2D)        (None, 2048, 24, 24) 1048576     block_4c_relu_2[0][0]
block_4c_conv_shortcut (Conv2D) (None, 2048, 24, 24) 4194304     block_4b_relu[0][0]
block_4c_bn_3 (BatchNormalizati (None, 2048, 24, 24) 8192        block_4c_conv_3[0][0]
block_4c_bn_shortcut (BatchNorm (None, 2048, 24, 24) 8192        block_4c_conv_shortcut[0][0]
add_32 (Add)                    (None, 2048, 24, 24) 0           block_4c_bn_3[0][0]
        block_4c_bn_shortcut[0][0]
block_4c_relu (Activation)      (None, 2048, 24, 24) 0           add_32[0][0]
yolo_spp_pool_1 (MaxPooling2D)  (None, 2048, 24, 24) 0           block_4c_relu[0][0]
yolo_spp_pool_2 (MaxPooling2D)  (None, 2048, 24, 24) 0           block_4c_relu[0][0]
yolo_spp_pool_3 (MaxPooling2D)  (None, 2048, 24, 24) 0           block_4c_relu[0][0]
yolo_spp_concat (Concatenate)   (None, 8192, 24, 24) 0           yolo_spp_pool_1[0][0]
        yolo_spp_pool_2[0][0]
        yolo_spp_pool_3[0][0]
        block_4c_relu[0][0]
yolo_spp_conv (Conv2D)          (None, 512, 24, 24)  4194304     yolo_spp_concat[0][0]
yolo_spp_conv_bn (BatchNormaliz (None, 512, 24, 24)  2048        yolo_spp_conv[0][0]
yolo_spp_conv_lrelu (LeakyReLU) (None, 512, 24, 24)  0           yolo_spp_conv_bn[0][0]
yolo_expand_conv1 (Conv2D)      (None, 1024, 12, 12) 4718592     yolo_spp_conv_lrelu[0][0]
yolo_expand_conv1_bn (BatchNorm (None, 1024, 12, 12) 4096        yolo_expand_conv1[0][0]
yolo_expand_conv1_lrelu (LeakyR (None, 1024, 12, 12) 0           yolo_expand_conv1_bn[0][0]
yolo_conv1_1 (Conv2D)           (None, 512, 12, 12)  524288      yolo_expand_conv1_lrelu[0][0]
yolo_conv1_1_bn (BatchNormaliza (None, 512, 12, 12)  2048        yolo_conv1_1[0][0]
yolo_conv1_1_lrelu (LeakyReLU)  (None, 512, 12, 12)  0           yolo_conv1_1_bn[0][0]
yolo_conv1_2 (Conv2D)           (None, 1024, 12, 12) 4718592     yolo_conv1_1_lrelu[0][0]
yolo_conv1_2_bn (BatchNormaliza (None, 1024, 12, 12) 4096        yolo_conv1_2[0][0]
yolo_conv1_2_lrelu (LeakyReLU)  (None, 1024, 12, 12) 0           yolo_conv1_2_bn[0][0]
yolo_conv1_3 (Conv2D)           (None, 512, 12, 12)  524288      yolo_conv1_2_lrelu[0][0]
yolo_conv1_3_bn (BatchNormaliza (None, 512, 12, 12)  2048        yolo_conv1_3[0][0]
yolo_conv1_3_lrelu (LeakyReLU)  (None, 512, 12, 12)  0           yolo_conv1_3_bn[0][0]
yolo_conv1_4 (Conv2D)           (None, 1024, 12, 12) 4718592     yolo_conv1_3_lrelu[0][0]
yolo_conv1_4_bn (BatchNormaliza (None, 1024, 12, 12) 4096        yolo_conv1_4[0][0]
yolo_conv1_4_lrelu (LeakyReLU)  (None, 1024, 12, 12) 0           yolo_conv1_4_bn[0][0]
yolo_conv1_5 (Conv2D)           (None, 512, 12, 12)  524288      yolo_conv1_4_lrelu[0][0]
yolo_conv1_5_bn (BatchNormaliza (None, 512, 12, 12)  2048        yolo_conv1_5[0][0]
yolo_conv1_5_lrelu (LeakyReLU)  (None, 512, 12, 12)  0           yolo_conv1_5_bn[0][0]
yolo_conv2 (Conv2D)             (None, 256, 12, 12)  131072      yolo_conv1_5_lrelu[0][0]
yolo_conv2_bn (BatchNormalizati (None, 256, 12, 12)  1024        yolo_conv2[0][0]
yolo_conv2_lrelu (LeakyReLU)    (None, 256, 12, 12)  0           yolo_conv2_bn[0][0]
upsample0 (UpSampling2D)        (None, 256, 24, 24)  0           yolo_conv2_lrelu[0][0]
concatenate_3 (Concatenate)     (None, 768, 24, 24)  0           upsample0[0][0]
yolo_conv3_1 (Conv2D)           (None, 256, 24, 24)  196608      concatenate_3[0][0]
yolo_conv3_1_bn (BatchNormaliza (None, 256, 24, 24)  1024        yolo_conv3_1[0][0]
yolo_conv3_1_lrelu (LeakyReLU)  (None, 256, 24, 24)  0           yolo_conv3_1_bn[0][0]
yolo_conv3_2 (Conv2D)           (None, 512, 24, 24)  1179648     yolo_conv3_1_lrelu[0][0]
yolo_conv3_2_bn (BatchNormaliza (None, 512, 24, 24)  2048        yolo_conv3_2[0][0]
yolo_conv3_2_lrelu (LeakyReLU)  (None, 512, 24, 24)  0           yolo_conv3_2_bn[0][0]
yolo_conv3_3 (Conv2D)           (None, 256, 24, 24)  131072      yolo_conv3_2_lrelu[0][0]
yolo_conv3_3_bn (BatchNormaliza (None, 256, 24, 24)  1024        yolo_conv3_3[0][0]
yolo_conv3_3_lrelu (LeakyReLU)  (None, 256, 24, 24)  0           yolo_conv3_3_bn[0][0]
yolo_conv3_4 (Conv2D)           (None, 512, 24, 24)  1179648     yolo_conv3_3_lrelu[0][0]
yolo_conv3_4_bn (BatchNormaliza (None, 512, 24, 24)  2048        yolo_conv3_4[0][0]
yolo_conv3_4_lrelu (LeakyReLU)  (None, 512, 24, 24)  0           yolo_conv3_4_bn[0][0]
yolo_conv3_5 (Conv2D)           (None, 256, 24, 24)  131072      yolo_conv3_4_lrelu[0][0]
yolo_conv3_5_bn (BatchNormaliza (None, 256, 24, 24)  1024        yolo_conv3_5[0][0]
yolo_conv3_5_lrelu (LeakyReLU)  (None, 256, 24, 24)  0           yolo_conv3_5_bn[0][0]
yolo_conv4 (Conv2D)             (None, 128, 24, 24)  32768       yolo_conv3_5_lrelu[0][0]
yolo_conv4_bn (BatchNormalizati (None, 128, 24, 24)  512         yolo_conv4[0][0]
yolo_conv4_lrelu (LeakyReLU)    (None, 128, 24, 24)  0           yolo_conv4_bn[0][0]
upsample1 (UpSampling2D)        (None, 128, 48, 48)  0           yolo_conv4_lrelu[0][0]
expand_upsample (UpSampling2D)  (None, 256, 48, 48)  0           block_3f_relu_2[0][0]
concatenate_4 (Concatenate)     (None, 384, 48, 48)  0           upsample1[0][0]
        expand_upsample[0][0]
yolo_conv5_1 (Conv2D)           (None, 128, 48, 48)  49152       concatenate_4[0][0]
yolo_conv5_1_bn (BatchNormaliza (None, 128, 48, 48)  512         yolo_conv5_1[0][0]
yolo_conv5_1_lrelu (LeakyReLU)  (None, 128, 48, 48)  0           yolo_conv5_1_bn[0][0]
yolo_conv5_2 (Conv2D)           (None, 256, 48, 48)  294912      yolo_conv5_1_lrelu[0][0]
yolo_conv5_2_bn (BatchNormaliza (None, 256, 48, 48)  1024        yolo_conv5_2[0][0]
yolo_conv5_2_lrelu (LeakyReLU)  (None, 256, 48, 48)  0           yolo_conv5_2_bn[0][0]
yolo_conv5_3 (Conv2D)           (None, 128, 48, 48)  32768       yolo_conv5_2_lrelu[0][0]
yolo_conv5_3_bn (BatchNormaliza (None, 128, 48, 48)  512         yolo_conv5_3[0][0]
yolo_conv5_3_lrelu (LeakyReLU)  (None, 128, 48, 48)  0           yolo_conv5_3_bn[0][0]
yolo_conv5_4 (Conv2D)           (None, 256, 48, 48)  294912      yolo_conv5_3_lrelu[0][0]
yolo_conv5_4_bn (BatchNormaliza (None, 256, 48, 48)  1024        yolo_conv5_4[0][0]
yolo_conv5_4_lrelu (LeakyReLU)  (None, 256, 48, 48)  0           yolo_conv5_4_bn[0][0]
yolo_conv5_5 (Conv2D)           (None, 128, 48, 48)  32768       yolo_conv5_4_lrelu[0][0]
yolo_conv5_5_bn (BatchNormaliza (None, 128, 48, 48)  512         yolo_conv5_5[0][0]
yolo_conv5_5_lrelu (LeakyReLU)  (None, 128, 48, 48)  0           yolo_conv5_5_bn[0][0]
yolo_conv1_6 (Conv2D)           (None, 1024, 12, 12) 4718592     yolo_conv1_5_lrelu[0][0]
yolo_conv3_6 (Conv2D)           (None, 512, 24, 24)  1179648     yolo_conv3_5_lrelu[0][0]
yolo_conv5_6 (Conv2D)           (None, 256, 48, 48)  294912      yolo_conv5_5_lrelu[0][0]
yolo_conv1_6_bn (BatchNormaliza (None, 1024, 12, 12) 4096        yolo_conv1_6[0][0]
yolo_conv3_6_bn (BatchNormaliza (None, 512, 24, 24)  2048        yolo_conv3_6[0][0]
yolo_conv5_6_bn (BatchNormaliza (None, 256, 48, 48)  1024        yolo_conv5_6[0][0]
yolo_conv1_6_lrelu (LeakyReLU)  (None, 1024, 12, 12) 0           yolo_conv1_6_bn[0][0]
yolo_conv3_6_lrelu (LeakyReLU)  (None, 512, 24, 24)  0           yolo_conv3_6_bn[0][0]
yolo_conv5_6_lrelu (LeakyReLU)  (None, 256, 48, 48)  0           yolo_conv5_6_bn[0][0]
conv_big_object (Conv2D)        (None, 24, 12, 12)   24600       yolo_conv1_6_lrelu[0][0]
conv_mid_object (Conv2D)        (None, 24, 24, 24)   12312       yolo_conv3_6_lrelu[0][0]
conv_sm_object (Conv2D)         (None, 24, 48, 48)   6168        yolo_conv5_6_lrelu[0][0]
bg_permute (Permute)            (None, 12, 12, 24)   0           conv_big_object[0][0]
md_permute (Permute)            (None, 24, 24, 24)   0           conv_mid_object[0][0]
sm_permute (Permute)            (None, 48, 48, 24)   0           conv_sm_object[0][0]
bg_reshape (Reshape)            (None, 432, 8)       0           bg_permute[0][0]
md_reshape (Reshape)            (None, 1728, 8)      0           md_permute[0][0]
sm_reshape (Reshape)            (None, 6912, 8)      0           sm_permute[0][0]
bg_anchor (YOLOAnchorBox)       (None, 432, 6)       0           conv_big_object[0][0]
bg_bbox_processor (BBoxPostProc (None, 432, 8)       0           bg_reshape[0][0]
md_anchor (YOLOAnchorBox)       (None, 1728, 6)      0           conv_mid_object[0][0]
md_bbox_processor (BBoxPostProc (None, 1728, 8)      0           md_reshape[0][0]
sm_anchor (YOLOAnchorBox)       (None, 6912, 6)      0           conv_sm_object[0][0]
sm_bbox_processor (BBoxPostProc (None, 6912, 8)      0           sm_reshape[0][0]
encoded_bg (Concatenate)        (None, 432, 14)      0           bg_anchor[0][0]
        bg_bbox_processor[0][0]
encoded_md (Concatenate)        (None, 1728, 14)     0           md_anchor[0][0]
        md_bbox_processor[0][0]
encoded_sm (Concatenate)        (None, 6912, 14)     0           sm_anchor[0][0]
        sm_bbox_processor[0][0]
encoded_detections (Concatenate (None, 9072, 14)     0           encoded_bg[0][0]
        encoded_md[0][0]
        encoded_sm[0][0]
Total params: 68,040,712
Trainable params: 67,945,096
Non-trainable params: 95,616
2021-07-02 12:23:20,990 [INFO] __main__: Number of images in the training dataset:	    10
Epoch 1/1
 2/10 [=====>........................] - ETA: 34:42 - loss: 96.4671  /usr/local/lib/python3.6/dist-packages/keras/callbacks.py:122: UserWarning: Method on_batch_end() is slow compared to the batch update (3.052041). Check your callbacks.
  % delta_t_median)
Epoch 00001: saving model to /workspace/tlt-experiments/yolo_v4/experiment_dir_unpruned/weights/yolov4_resnet50_epoch_001.tlt
Do you mean you wait for 10+ minutes between
and
Epoch 1/1
No, those two appear at the same time and then I wait 10+ minutes before I see the first info about the progress of the 1 epochs
OK. Will check. At that point, it will indeed take time to move on. But 10+ minutes is a bit longer.
Can you share your training spec? You mention that it is the same as default spec file from Yolo_v4. Appreciate that you can share here.
More, if possible, could you share the 10 images and labels?
For Resnet18 it is 1-2 minutes model loading + 11-37s/step first epoch (when I run multiple times for the test, and there is no other processes using gpu
For Resnet50 it is 3 minutes model loading + 4-5 minutes to start 1st epoch + 16s/step first epoch
For Resnet50 (image size 384x384)
it is 3 minutes model loading + + 4-5 minutes to start 1st epoch + 55s/step first epoch
I use batch size = 1 because I have OOM with 8GB videoram for image size 1248x348
small_train_dataset.zip (7.6 MB)
yolo_v4_train_resnet18_kitti.txt (2.3 KB)
yolo_v4_train_resnet50_kitti.txt (2.3 KB)
yolo_v4_train_resnet50_kitti_384x384.txt (2.3 KB)
Thanks for the info. I will check if I can reproduce.
I ran resnet18 with your shared spec file and small_train_dataset. But I cannot reproduce.
After “Epoch 1/1”, it cost about 10s to start the progress of 1 epoch.
I ran on Geforce 1080 Ti gpu card.
Could you double check? Or check NVIDIA TAO Documentation ?
I have the same issue here, whether with a T4 or an A100 GPU. Take 20 minutes to get started for the first epoch.
It seems it depends on the backbone used. YoloV4 cspdarknet53 takes the longest (20 minutes) while YoloV4 resnet18 takes about 5 minutes to load. YoloV3 with similar backbones takes less time to load.
