On a ESX 6.7, I installed this drivers:
NVIDIA-VMware_ESXi_6.7_Host_Driver-440.53-1OEM.670.0.0.8169922.x86_64.vib
but I’m not able to have nvidia on my vms,
and the commande nvidia-smi vgpu answer is :
[root@localhost:/vmfs] nvidia-smi vgpu
Not supported devices in vGPU mode
However, the nvidia-smi command says:
Thu Feb 13 09:36:42 2020
| NVIDIA-SMI 440.53 Driver Version: 440.53 CUDA Version: N/A |
| 0 Tesla T4 On | 00000000:5E:00.0 Off | 0 |
| N/A 37C P8 17W / 70W | 92MiB / 15359MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 2104612 G Xorg 5MiB |
Could it be a problem with the driver ?
If that’s the case, is there another driver I have to use ?
Thanx for you help !
John
