While running the VIA Summarization model i am getting the below mentioned error:
ERROR We couldn’t connect to ’
https://huggingface.co’
to load this file, couldn’t find it in the cached files and it looks like sentence-transformers/all-MiniLM-L6-v2 is not the path to a directory containing a file named config.json.
ERROR Failed to load VIA pipeline - CA-RAG setup failed. Check if NVIDIA_API_KEY set correctly and/or LLM configuration in CA-RAG config is valid.
Please note:
I have downloaded the VITA 2.0 Model from web and kept the files inside folder: VIA/nvidia_tao_vita_2.0.1_vila-llama-3-8b-lita/ . and given the export NGC_MODEL_CACHE as the same.
If I am downloading the Hugging face model
