I’m using Jetson Orin 64GB.
VPI 2.0
So I’m trying to understand if using VPI for remapping will be efficient on VIC in our case but got a bit lost when reading the performance table in the Remap section.
In the current test I use stream for each camera, and run it one by one (2 cameras/images).
First camera output is 3848x1606 and the second camera output is 1920x1280.
Each image format type is BGR but I convert those to BGRA (due to VIC limitations) and then using the VPI stream convert the image to NV12_ER and run the Remap (will try to omit the conversions later on).
Questions:
- According to the performance table of the Remap (Orin, nv12_er, using VIC, 1 stream) I should see ~3.8msec for the remap operation in case of 1920x1280, is that correct ?
- Didn’t got the interval column in the table, what does it stands for?
- I’ve read in VPIs performance section that you have measured the performance after using clock.sh to max out the VIC clock, Should I use it as well ? What is the price for running the script constantly on startup?
- Can I assume that the performance shown in the table for the VIC will be proportional to the pixel count of different image size ?
Thanks in advance,
Barak
1. Based on the VPI 2.0 document here:
1920x1080 remap with VIC is around 3.691~3.71ms.
2. Interval indicates the “control point interval (density)”.
3. Yes, the clock setting can boost VIC performance.
It’s a valid setting so no harm to the device.
4. Suppose yes.
Thank you for your response.
I turned to use CUDA backend to achieve the performance of the table and also failed.
For RGB Image of 1920x1280 I got 2.78 msec which is far from the values in the table.
I’ve also ran clocks.sh --max according to the profiling description.
Any idea for the reason of the difference ?
Thanks,
Barak
Please check our document below:
https://docs.nvidia.com/vpi/2.0/algo_performance.html#benchmark
The value is calculated with batches and has some warm-up.
Do you profile it with a similar approach?
An example can be found in /opt/nvidia/vpi2/samples/05-benchmark/.
Please benchmark the algorithm directly.
Wrapper from OpenCV induces some extra IO latency.
For example:
CHECK_STATUS(vpiEventRecord(evStart, stream));
for (int i = 0; i < AVERAGING_COUNT; ++i)
CHECK_STATUS(vpiSubmitGaussianFilter(stream, backend, image, blurred, 5, 5, 1, 1,
VPI_BORDER_ZERO));
CHECK_STATUS(vpiEventRecord(evStop, stream));
