I want to use nvxuSemiGlobalMatching on custom image buffers. Therefore I mapped the buffers to an vx_image using the vxCreateImageFromHandle function:
vx_imagepatch_addressing_t addrLeft[1];
addrLeft[0].dim_x = width;
addrLeft[0].dim_y = height;
addrLeft[0].stride_x = sizeof(uint8_t);
addrLeft[0].stride_y = width*sizeof(uint8_t);
vx_imagepatch_addressing_t addrRight[1];
addrRight[0].dim_x = width;
addrRight[0].dim_y = height;
addrRight[0].stride_x = sizeof(uint8_t);
addrRight[0].stride_y = width*sizeof(uint8_t);
vx_imagepatch_addressing_t addrDisp[1];
addrDisp[0].dim_x = width;
addrDisp[0].dim_y = height;
addrDisp[0].stride_x = sizeof(int16_t);
addrDisp[0].stride_y = width*sizeof(int16_t);
// dataLeft, dataRight, dataDisp are pointers to allocated cuda memory
void *ptrsLeft[1] = { dataLeft };
void *ptrsRight[1] = { dataRight };
void *ptrsDisp[1] = { dataDisp };
auto vxImageLeft = vxCreateImageFromHandle(context, VX_DF_IMAGE_U8, addrLeft, ptrsLeft, NVX_MEMORY_TYPE_CUDA);
auto vxImageRight = vxCreateImageFromHandle(context, VX_DF_IMAGE_U8, addrRight, ptrsRight, NVX_MEMORY_TYPE_CUDA);
auto vxDisparity = vxCreateImageFromHandle(context, VX_DF_IMAGE_S16, addrDisp, ptrsDisp, NVX_MEMORY_TYPE_CUDA);
After that I call the nvxuSemiGlobalMatching function using these images. Somehow the output in vxDisparity is rubbish.
The weird thing is that when I create a temporary vxDisparityTemp, pass that image to nvxuSemiGlobalMatching and then copy that image using nvxuCopyImage to vxDisparity, the result looks good.
What could be the reason for that? Why can nvxuCopyImage write into vxDisparity and nvxuSemiGlobalMatching not? Do I miss something?
Thanks,
Markus
