Visual Studio Code Pylint installl
I’m having an issue installing pylint.
alex@CareVision:~$ /usr/bin/python3 -m pip install -U pylint
Collecting pylint
  Using cached https://files.pythonhosted.org/packages/37/42/948d1486727806df2e0016f1cfc2d3beafe289f96d53dfc85d967f79afc5/pylint-2.11.1-py3-none-any.whl
Collecting astroid<2.9,>=2.8.0 (from pylint)
  Using cached https://files.pythonhosted.org/packages/55/36/bd5e2919e9cfe635e6b0a1c30fdaebdd9742acc1fad2a49a73b478e8e7b3/astroid-2.8.4-py3-none-any.whl
Collecting mccabe<0.7,>=0.6 (from pylint)
  Using cached https://files.pythonhosted.org/packages/87/89/479dc97e18549e21354893e4ee4ef36db1d237534982482c3681ee6e7b57/mccabe-0.6.1-py2.py3-none-any.whl
Collecting isort<6,>=4.2.5 (from pylint)
  Using cached https://files.pythonhosted.org/packages/04/1f/ec0216083b34f944c6d94e96368ea180f1a00cfa9acc71e45ef01ee1ef8f/isort-5.10.0-py3-none-any.whl
Collecting platformdirs>=2.2.0 (from pylint)
  Using cached https://files.pythonhosted.org/packages/b1/78/dcfd84d3aabd46a9c77260fb47ea5d244806e4daef83aa6fe5d83adb182c/platformdirs-2.4.0-py3-none-any.whl
Collecting typing-extensions>=3.10.0; python_version < "3.10" (from pylint)
  Using cached https://files.pythonhosted.org/packages/74/60/18783336cc7fcdd95dae91d73477830aa53f5d3181ae4fe20491d7fc3199/typing_extensions-3.10.0.2-py3-none-any.whl
Collecting toml>=0.7.1 (from pylint)
  Using cached https://files.pythonhosted.org/packages/44/6f/7120676b6d73228c96e17f1f794d8ab046fc910d781c8d151120c3f1569e/toml-0.10.2-py2.py3-none-any.whl
Collecting lazy-object-proxy>=1.4.0 (from astroid<2.9,>=2.8.0->pylint)
  Using cached https://files.pythonhosted.org/packages/bb/f5/646893a04dcf10d4acddb61c632fd53abb3e942e791317dcdd57f5800108/lazy-object-proxy-1.6.0.tar.gz
Collecting setuptools>=20.0 (from astroid<2.9,>=2.8.0->pylint)
  Using cached https://files.pythonhosted.org/packages/70/e9/84e2865fddfaba4506bc5d293d2a535bf27e31b12ca16d31564f8ce28cdb/setuptools-58.5.3-py3-none-any.whl
Collecting typed-ast<1.5,>=1.4.0; implementation_name == "cpython" and python_version < "3.8" (from astroid<2.9,>=2.8.0->pylint)
Collecting wrapt<1.14,>=1.11 (from astroid<2.9,>=2.8.0->pylint)
  Using cached https://files.pythonhosted.org/packages/eb/f6/d81ccf43ac2a3c80ddb6647653ac8b53ce2d65796029369923be06b815b8/wrapt-1.13.3.tar.gz
    Complete output from command python setup.py egg_info:
      File "<string>", line 1, in <module>
      File "/tmp/pip-build-hcp8xb9l/wrapt/setup.py", line 42, in <module>
        ext_modules=[] if disable_extensions else extensions
      File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 129, in setup
        return distutils.core.setup(**attrs)
      File "/usr/lib/python3.6/distutils/core.py", line 121, in setup
        dist.parse_config_files()
      File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 494, in parse_config_files
        ignore_option_errors=ignore_option_errors)
      File "/usr/lib/python3/dist-packages/setuptools/config.py", line 106, in parse_configuration
        meta.parse()
      File "/usr/lib/python3/dist-packages/setuptools/config.py", line 382, in parse
        section_parser_method(section_options)
      File "/usr/lib/python3/dist-packages/setuptools/config.py", line 355, in parse_section
        self[name] = value
      File "/usr/lib/python3/dist-packages/setuptools/config.py", line 173, in __setitem__
        value = parser(value)
      File "/usr/lib/python3/dist-packages/setuptools/config.py", line 430, in _parse_version
        version = self._parse_attr(value)
      File "/usr/lib/python3/dist-packages/setuptools/config.py", line 305, in _parse_attr
        module = import_module(module_name)
      File "/usr/lib/python3.6/importlib/__init__.py", line 126, in import_module
        return _bootstrap._gcd_import(name[level:], package, level)
      File "<frozen importlib._bootstrap>", line 994, in _gcd_import
      File "<frozen importlib._bootstrap>", line 971, in _find_and_load
      File "<frozen importlib._bootstrap>", line 953, in _find_and_load_unlocked
    ModuleNotFoundError: No module named 'wrapt'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-hcp8xb9l/wrapt/
I plan on uninstalling everything and re-installing, but if anyone has a different fix I would appreciate it.
Have a check this link.
