Hello there, I’m having this strange issue that I’m stuck on
For whatever reason, vkQueuePresentKHR is completely blocking my GPU, there is no explicit synchronization there, all command submits have been made at this point and they don’t wait for anything (submit after previous frame fence)
I’m assuming that the block might be due to app switching context to DX12, but why would it do so to begin with
According to Nsight system trace, this DX12 context is used by nvogl64.dll, performs some copy and then presents
I’m using vkAcquireFullScreenExclusiveModeEXT, surface format is BGRA8_UNORM and result is the same when using SRGB variant, transform set to identity, using present mode immediate, generally presentation engine seems to be set correctly for the least amount of interference, window was created with GLFW
I’ve tried disabling Nsight overlay just to make sure the DX12 copy is not Nsight putting the rectangle with information on my screen but that didn’t change anything
Framerate reported by RivaTuner is matching the one seen in Nsight so it’s not just profiler overhead
I’m pretty sure this is not overheating either since if I switch my renderer to GL, all tools report higher framerate (both renderers are near 100% GPU usage)
I also explicitly disabled integrated GPU (even though monitor is plugged to discrete GPU) to make sure it’s not trying to copy the back buffer between them
I am out of ideas at this point
I’m using Windows 11, RTX 4090 with game ready driver 566.03
