This is great stuff. Unfortunately, having an issue when building per instructions. I should say – build is fine, but running with Docker or Docker compose per provided examples fail. Stack as follows:
(APIServer pid=1) INFO 01-18 19:40:15 [config.py:307] Overriding max cuda graph capture size to 1024 for performance.
File "<string>", line 1, in <module>
File "/usr/lib/python3.12/multiprocessing/spawn.py", line 122, in spawn_main
exitcode = _main(fd, parent_sentinel)
File "/usr/lib/python3.12/multiprocessing/spawn.py", line 131, in _main
prepare(preparation_data)
File "/usr/lib/python3.12/multiprocessing/spawn.py", line 246, in prepare
_fixup_main_from_path(data['init_main_from_path'])
File "/usr/lib/python3.12/multiprocessing/spawn.py", line 297, in _fixup_main_from_path
main_content = runpy.run_path(main_path,
File "<frozen runpy>", line 280, in run_path
File "/usr/lib/python3.12/pkgutil.py", line 170, in <module>
iter_importer_modules.register(
File "/usr/lib/python3.12/functools.py", line 892, in register
if _is_union_type(cls):
File "/usr/lib/python3.12/functools.py", line 842, in _is_union_type
from typing import get_origin, Union
File "/usr/local/lib/python3.12/dist-packages/cv2/typing/__init__.py", line 61, in <module>
import numpy
File "/usr/local/lib/python3.12/dist-packages/numpy/__init__.py", line 181, in <module>
from . import lib
File "/usr/local/lib/python3.12/dist-packages/numpy/lib/__init__.py", line 23, in <module>
from . import _index_tricks_impl
File "/usr/local/lib/python3.12/dist-packages/numpy/lib/_index_tricks_impl.py", line 12, in <module>
import numpy.matrixlib as matrixlib
File "/usr/local/lib/python3.12/dist-packages/numpy/matrixlib/__init__.py", line 4, in <module>
from . import defmatrix
File "/usr/local/lib/python3.12/dist-packages/numpy/matrixlib/defmatrix.py", line 12, in <module>
from numpy.linalg import matrix_power
File "/usr/local/lib/python3.12/dist-packages/numpy/linalg/__init__.py", line 88, in <module>
from . import _linalg
File "/usr/local/lib/python3.12/dist-packages/numpy/linalg/_linalg.py", line 22, in <module>
from typing import NamedTuple, Any
ImportError: cannot import name 'NamedTuple' from partially initialized module 'typing' (most likely due to a circular import) (/usr/local/lib/python3.12/dist-packages/cv2/typing/__init__.py)
(APIServer pid=1) Traceback (most recent call last):
(APIServer pid=1) File "/usr/local/bin/vllm", line 10, in <module>
(APIServer pid=1) sys.exit(main())
(APIServer pid=1) ^^^^^^
(APIServer pid=1) File "/workspace/vllm/vllm/entrypoints/cli/main.py", line 73, in main
(APIServer pid=1) args.dispatch_function(args)
(APIServer pid=1) File "/workspace/vllm/vllm/entrypoints/cli/serve.py", line 60, in cmd
(APIServer pid=1) uvloop.run(run_server(args))
(APIServer pid=1) File "/usr/local/lib/python3.12/dist-packages/uvloop/__init__.py", line 96, in run
(APIServer pid=1) return __asyncio.run(
(APIServer pid=1) ^^^^^^^^^^^^^^
(APIServer pid=1) File "/usr/lib/python3.12/asyncio/runners.py", line 194, in run
(APIServer pid=1) return runner.run(main)
(APIServer pid=1) ^^^^^^^^^^^^^^^^
(APIServer pid=1) File "/usr/lib/python3.12/asyncio/runners.py", line 118, in run
(APIServer pid=1) return self._loop.run_until_complete(task)
(APIServer pid=1) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(APIServer pid=1) File "uvloop/loop.pyx", line 1518, in uvloop.loop.Loop.run_until_complete
(APIServer pid=1) File "/usr/local/lib/python3.12/dist-packages/uvloop/__init__.py", line 48, in wrapper
(APIServer pid=1) return await main
(APIServer pid=1) File "/workspace/vllm/vllm/entrypoints/openai/api_server.py", line 1325, in run_server
(APIServer pid=1) await run_server_worker(listen_address, sock, args, **uvicorn_kwargs)
(APIServer pid=1) File "/workspace/vllm/vllm/entrypoints/openai/api_server.py", line 1344, in run_server_worker
(APIServer pid=1) async with build_async_engine_client(
(APIServer pid=1) File "/usr/lib/python3.12/contextlib.py", line 210, in __aenter__
(APIServer pid=1) return await anext(self.gen)
(APIServer pid=1) File "/workspace/vllm/vllm/entrypoints/openai/api_server.py", line 171, in build_async_engine_client
(APIServer pid=1) async with build_async_engine_client_from_engine_args(
(APIServer pid=1) File "/workspace/vllm/vllm/entrypoints/openai/api_server.py", line 212, in build_async_engine_client_from_engine_args
(APIServer pid=1) async_llm = AsyncLLM.from_vllm_config(
(APIServer pid=1) File "/workspace/vllm/vllm/v1/engine/async_llm.py", line 207, in from_vllm_config
(APIServer pid=1) return cls(
(APIServer pid=1) File "/workspace/vllm/vllm/v1/engine/async_llm.py", line 134, in __init__
(APIServer pid=1) self.engine_core = EngineCoreClient.make_async_mp_client(
(APIServer pid=1) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(APIServer pid=1) File "/workspace/vllm/vllm/v1/engine/core_client.py", line 122, in make_async_mp_client
(APIServer pid=1) return AsyncMPClient(*client_args)
(APIServer pid=1) File "/workspace/vllm/vllm/v1/engine/core_client.py", line 824, in __init__
(APIServer pid=1) super().__init__(
(APIServer pid=1) File "/workspace/vllm/vllm/v1/engine/core_client.py", line 479, in __init__
(APIServer pid=1) with launch_core_engines(vllm_config, executor_class, log_stats) as (
(APIServer pid=1) File "/usr/lib/python3.12/contextlib.py", line 144, in __exit__
(APIServer pid=1) next(self.gen)
(APIServer pid=1) File "/workspace/vllm/vllm/v1/engine/utils.py", line 921, in launch_core_engines
(APIServer pid=1) wait_for_engine_startup(
(APIServer pid=1) File "/workspace/vllm/vllm/v1/engine/utils.py", line 980, in wait_for_engine_startup
(APIServer pid=1) raise RuntimeError(
(APIServer pid=1) RuntimeError: Engine core initialization failed. See root cause above. Failed core proc(s): {'EngineCore_DP0': 1}
Any clue or anyone with a similar problem?
