Please provide the following information when creating a topic:
- Hardware Platform (GPU model and numbers) H100
- System Memory 320
- Ubuntu Version 22.04
- NVIDIA GPU Driver Version (valid for GPU only) 570.124.06
- Issue Type bug
- How to reproduce the issue ? docker compose up
Hi! Have issue starting VSS pipeline using local deployment on single GPU.
VSS pipeline doesn’t start due to errors in Guardrails and CA RAG.
Guardrails
via-server-1 | Ctrl+C to exit ...
via-server-1 | Using nvila
via-server-1 | Starting VIA server in release mode
via-server-1 | 2025-07-03 14:04:49,612 INFO Initializing VIA Stream Handler
via-server-1 | INFO: Started server process [230]
via-server-1 | INFO: Waiting for application startup.
via-server-1 | INFO: Application startup complete.
via-server-1 | INFO: Uvicorn running on http://127.0.0.1:60000 (Press CTRL+C to quit)
via-server-1 | Exception in thread Thread-3 (run):
via-server-1 | Traceback (most recent call last):
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/urllib3/connection.py", line 174, in _new_conn
via-server-1 | conn = connection.create_connection(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/urllib3/util/connection.py", line 95, in create_connection
via-server-1 | raise err
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/urllib3/util/connection.py", line 85, in create_connection
via-server-1 | sock.connect(sa)
via-server-1 | ConnectionRefusedError: [Errno 111] Connection refused
via-server-1 |
via-server-1 | During handling of the above exception, another exception occurred:
via-server-1 |
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/urllib3/connectionpool.py", line 715, in urlopen
via-server-1 | httplib_response = self._make_request(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/urllib3/connectionpool.py", line 416, in _make_request
via-server-1 | conn.request(method, url, **httplib_request_kw)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/urllib3/connection.py", line 244, in request
via-server-1 | super(HTTPConnection, self).request(method, url, body=body, headers=headers)
via-server-1 | File "/usr/lib/python3.10/http/client.py", line 1283, in request
via-server-1 | self._send_request(method, url, body, headers, encode_chunked)
via-server-1 | File "/usr/lib/python3.10/http/client.py", line 1329, in _send_request
via-server-1 | self.endheaders(body, encode_chunked=encode_chunked)
via-server-1 | File "/usr/lib/python3.10/http/client.py", line 1278, in endheaders
via-server-1 | self._send_output(message_body, encode_chunked=encode_chunked)
via-server-1 | File "/usr/lib/python3.10/http/client.py", line 1038, in _send_output
via-server-1 | self.send(msg)
via-server-1 | File "/usr/lib/python3.10/http/client.py", line 976, in send
via-server-1 | self.connect()
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/urllib3/connection.py", line 205, in connect
via-server-1 | conn = self._new_conn()
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/urllib3/connection.py", line 186, in _new_conn
via-server-1 | raise NewConnectionError(
via-server-1 | urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7229577a6290>: Failed to establish a new connection: [Errno 111] Connection refused
via-server-1 |
via-server-1 |
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/requests/adapters.py", line 667, in send
via-server-1 | resp = conn.urlopen(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/urllib3/connectionpool.py", line 801, in urlopen
via-server-1 | retries = retries.increment(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/urllib3/util/retry.py", line 594, in increment
via-server-1 | raise MaxRetryError(_pool, url, error or ResponseError(cause))
via-server-1 | urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='0.0.0.0', port=8006): Max retries exceeded with url: /v1/embeddings (Caused by NewConnectionError('<urllib3.connect
ion.HTTPConnection object at 0x7229577a6290>: Failed to establish a new connection: [Errno 111] Connection refused'))
via-server-1 |
via-server-1 |
via-server-1 | File "/usr/lib/python3.10/threading.py", line 1016, in _bootstrap_inner
via-server-1 | self.run()
via-server-1 | File "/usr/lib/python3.10/threading.py", line 953, in run
via-server-1 | self._target(*self._args, **self._kwargs)
via-server-1 | File "/usr/lib/python3.10/asyncio/runners.py", line 44, in run
via-server-1 | return loop.run_until_complete(main)
via-server-1 | File "/usr/lib/python3.10/asyncio/base_events.py", line 649, in run_until_complete
via-server-1 | return future.result()
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/actions/llm/generation.py", line 134, in init
via-server-1 | await asyncio.gather(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/actions/llm/generation.py", line 261, in _init_bot_message_index
via-server-1 | await self.bot_message_index.add_items(items)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/embeddings/basic.py", line 185, in add_items
via-server-1 | await self._get_embeddings([item.text for item in items])
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/embeddings/cache.py", line 307, in wrapper_decorator
via-server-1 | return await func(self, texts)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/embeddings/basic.py", line 156, in _get_embeddings
via-server-1 | embeddings = await self._model.encode_async(texts)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/embeddings/providers/nim.py", line 59, in encode_async
via-server-1 | result = await self.document_embedder.aembed_documents(documents)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/embeddings/embeddings.py", line 67, in aembed_documents
via-server-1 | return await run_in_executor(None, self.embed_documents, texts)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/runnables/config.py", line 588, in run_in_executor
via-server-1 | return await asyncio.get_running_loop().run_in_executor(
via-server-1 | File "/usr/lib/python3.10/concurrent/futures/thread.py", line 58, in run
via-server-1 | result = self.fn(*self.args, **self.kwargs)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/runnables/config.py", line 579, in wrapper
via-server-1 | return func(*args, **kwargs)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_nvidia_ai_endpoints/embeddings.py", line 163, in embed_documents
via-server-1 | all_embeddings.extend(self._embed(batch, model_type="passage"))
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_nvidia_ai_endpoints/embeddings.py", line 137, in _embed
via-server-1 | response = self._client.get_req(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_nvidia_ai_endpoints/_common.py", line 473, in get_req
via-server-1 | response, session = self._post(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_nvidia_ai_endpoints/_common.py", line 366, in _post
via-server-1 | self.last_response = response = session.post(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/requests/sessions.py", line 637, in post
via-server-1 | return self.request("POST", url, data=data, json=json, **kwargs)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/requests/sessions.py", line 589, in request
via-server-1 | resp = self.send(prep, **send_kwargs)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/requests/sessions.py", line 703, in send
via-server-1 | r = adapter.send(request, **kwargs)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/requests/adapters.py", line 700, in send
via-server-1 | raise ConnectionError(e, request=request)
via-server-1 | requests.exceptions.ConnectionError: HTTPConnectionPool(host='0.0.0.0', port=8006): Max retries exceeded with url: /v1/embeddings (Caused by NewConnectionError('<urllib3.conn
ection.HTTPConnection object at 0x7229577a6290>: Failed to establish a new connection: [Errno 111] Connection refused'))
via-server-1 | 2025-07-03 14:04:50,241 ERROR Error in guardrails: LLM Call Exception: HTTPConnectionPool(host='0.0.0.0', port=8007): Max retries exceeded with url: /v1/chat/completions (Cau
sed by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7229577a6fb0>: Failed to establish a new connection: [Errno 111] Connection refused'))
via-server-1 | 2025-07-03 14:04:50,241 INFO Stopping VIA Stream Handler
via-server-1 | 2025-07-03 14:04:50,241 INFO Stopped VIA Stream Handler
via-server-1 | 2025-07-03 14:04:50,241 ERROR Failed to load VIA stream handler - Guardrails failed
via-server-1 |
via-server-1 |
via-server-1 | urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7229577a6fb0>: Failed to establish a new connection: [Errno 111] Connection refused
via-server-1 |
via-server-1 |
via-server-1 | urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='0.0.0.0', port=8007): Max retries exceeded with url: /v1/chat/completions (Caused by NewConnectionError('<urllib3.c
via-server-1 |
via-server-1 |
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/actions/llm/utils.py", line 92, in llm_call
via-server-1 | result = await llm.agenerate_prompt(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/language_models/chat_models.py", line 796, in agenerate_prompt
via-server-1 | return await self.agenerate(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/language_models/chat_models.py", line 756, in agenerate
via-server-1 | raise exceptions[0]
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/language_models/chat_models.py", line 924, in _agenerate_with_cache
via-server-1 | result = await self._agenerate(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/language_models/chat_models.py", line 964, in _agenerate
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/llm/providers/_langchain_nvidia_ai_endpoints_patch.py", line 45, in wrapper
via-server-1 | return generate_from_stream(stream_iter)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/language_models/chat_models.py", line 88, in generate_from_stream
via-server-1 | generation = next(stream, None)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_nvidia_ai_endpoints/chat_models.py", line 420, in _stream
via-server-1 | for response in self._client.get_req_stream(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_nvidia_ai_endpoints/_common.py", line 560, in get_req_stream
via-server-1 | response = self.get_session_fn().post(
via-server-1 | requests.exceptions.ConnectionError: HTTPConnectionPool(host='0.0.0.0', port=8007): Max retries exceeded with url: /v1/chat/completions (Caused by NewConnectionError('<urllib
via-server-1 |
via-server-1 |
via-server-1 | File "/opt/nvidia/via/via-engine/via_stream_handler.py", line 507, in _create_llm_rails_pool
via-server-1 | response = self._LLMRailsPool[0].generate(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/rails/llm/llmrails.py", line 990, in generate
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/rails/llm/llmrails.py", line 703, in generate_async
via-server-1 | new_events = await self.runtime.generate_events(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/colang/v1_0/runtime/runtime.py", line 167, in generate_events
via-server-1 | next_events = await self._process_start_action(events)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/colang/v1_0/runtime/runtime.py", line 363, in _process_start_action
via-server-1 | result, status = await self.action_dispatcher.execute_action(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/actions/action_dispatcher.py", line 253, in execute_action
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/actions/action_dispatcher.py", line 214, in execute_action
via-server-1 | result = await result
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/library/self_check/input_check/actions.py", line 72, in self_check_input
via-server-1 | response = await llm_call(llm, prompt, stop=stop)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/nemoguardrails/actions/llm/utils.py", line 96, in llm_call
via-server-1 | raise LLMCallException(e)
via-server-1 | nemoguardrails.actions.llm.utils.LLMCallException: LLM Call Exception: HTTPConnectionPool(host='0.0.0.0', port=8007): Max retries exceeded with url: /v1/chat/completions (Cau
via-server-1 |
via-server-1 |
via-server-1 | File "/opt/nvidia/via/via-engine/via_server.py", line 1368, in run
via-server-1 | self._stream_handler = ViaStreamHandler(self._args)
via-server-1 | File "/opt/nvidia/via/via-engine/via_stream_handler.py", line 409, in __init__
via-server-1 | self._create_llm_rails_pool()
via-server-1 | File "/opt/nvidia/via/via-engine/via_stream_handler.py", line 513, in _create_llm_rails_pool
via-server-1 | raise Exception("Guardrails failed")
via-server-1 | Exception: Guardrails failed
via-server-1 |
via-server-1 |
via-server-1 | File "/opt/nvidia/via/via-engine/via_server.py", line 2880, in <module>
via-server-1 | server.run()
via-server-1 | File "/opt/nvidia/via/via-engine/via_server.py", line 1370, in run
via-server-1 | raise ViaException(f"Failed to load VIA stream handler - {str(ex)}")
via-server-1 | via_exception.ViaException: ViaException - code: InternalServerError message: Failed to load VIA stream handler - Guardrails failed
CA-RAG
ia-server-1 | 2025-07-03 13:54:20,603 INFO Warming up LLM meta/llama-3.1-8b-instruct
via-server-1 | 2025-07-03 13:54:23,345 ERROR Error warming up LLM meta/llama-3.1-8b-instruct: Connection error.
via-server-1 | 2025-07-03 13:54:23,345 ERROR Error warming up LLM: Connection error.
via-server-1 | 2025-07-03 13:54:23,345 ERROR Exception Connection error.
via-server-1 | 2025-07-03 13:54:23,348 ERROR Traceback (most recent call last):
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpcore/_exceptions.py", line 10, in map_exceptions
via-server-1 | yield
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpcore/_backends/sync.py", line 100, in connect_tcp
via-server-1 | sock = socket.create_connection(
via-server-1 | File "/usr/lib/python3.10/socket.py", line 845, in create_connection
via-server-1 | File "/usr/lib/python3.10/socket.py", line 833, in create_connection
via-server-1 |
via-server-1 | The above exception was the direct cause of the following exception:
via-server-1 |
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpx/_transports/default.py", line 60, in map_httpcore_exceptions
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpx/_transports/default.py", line 218, in handle_request
via-server-1 | resp = self._pool.handle_request(req)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpcore/_sync/connection_pool.py", line 262, in handle_request
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpcore/_sync/connection_pool.py", line 245, in handle_request
via-server-1 | response = connection.handle_request(request)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpcore/_sync/connection.py", line 92, in handle_request
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpcore/_sync/connection.py", line 69, in handle_request
via-server-1 | stream = self._connect(request)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpcore/_sync/connection.py", line 117, in _connect
via-server-1 | stream = self._network_backend.connect_tcp(**kwargs)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpcore/_backends/sync.py", line 99, in connect_tcp
via-server-1 | with map_exceptions(exc_map):
via-server-1 | File "/usr/lib/python3.10/contextlib.py", line 153, in __exit__
via-server-1 | self.gen.throw(typ, value, traceback)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpcore/_exceptions.py", line 14, in map_exceptions
via-server-1 | raise to_exc(exc) from exc
via-server-1 | httpcore.ConnectError: [Errno 111] Connection refused
via-server-1 |
via-server-1 |
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/openai/_base_client.py", line 972, in _request
via-server-1 | response = self._client.send(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpx/_client.py", line 901, in send
via-server-1 | response = self._send_handling_auth(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpx/_client.py", line 929, in _send_handling_auth
via-server-1 | response = self._send_handling_redirects(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpx/_client.py", line 966, in _send_handling_redirects
via-server-1 | response = self._send_single_request(request)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpx/_client.py", line 1002, in _send_single_request
via-server-1 | response = transport.handle_request(request)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpx/_transports/default.py", line 217, in handle_request
via-server-1 | with map_httpcore_exceptions():
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/httpx/_transports/default.py", line 77, in map_httpcore_exceptions
via-server-1 | raise mapped_exc(message) from exc
via-server-1 | httpx.ConnectError: [Errno 111] Connection refused
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 |
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/vss_ctx_rag/context_manager/context_manager.py", line 119, in run
via-server-1 | self._initialize()
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/vss_ctx_rag/context_manager/context_manager.py", line 93, in _initialize
via-server-1 | self.cm_handler = ContextManagerHandler(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/vss_ctx_rag/context_manager/context_manager_handler.py", line 103, in __init__
via-server-1 | self.configure_init(config, req_info)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/vss_ctx_rag/context_manager/context_manager_handler.py", line 175, in configure_init
via-server-1 | notification_llm = ChatOpenAITool(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/vss_ctx_rag/tools/llm/llm_handler.py", line 109, in __init__
via-server-1 | self.warmup(model)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/vss_ctx_rag/tools/llm/llm_handler.py", line 117, in warmup
via-server-1 | logger.info(str(self.invoke("Hello, world!")))
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/vss_ctx_rag/tools/llm/llm_handler.py", line 45, in invoke
via-server-1 | return self.llm.invoke(*args, **kwargs)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/runnables/configurable.py", line 133, in invoke
via-server-1 | return runnable.invoke(input, config, **kwargs)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/language_models/chat_models.py", line 286, in invoke
via-server-1 | self.generate_prompt(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/language_models/chat_models.py", line 786, in generate_prompt
via-server-1 | return self.generate(prompt_messages, stop=stop, callbacks=callbacks, **kwargs)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/language_models/chat_models.py", line 643, in generate
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/language_models/chat_models.py", line 633, in generate
via-server-1 | self._generate_with_cache(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_core/language_models/chat_models.py", line 851, in _generate_with_cache
via-server-1 | result = self._generate(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/langchain_openai/chat_models/base.py", line 683, in _generate
via-server-1 | response = self.client.create(**payload)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/openai/_utils/_utils.py", line 274, in wrapper
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/openai/resources/chat/completions.py", line 668, in create
via-server-1 | return self._post(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/openai/_base_client.py", line 1259, in post
via-server-1 | return cast(ResponseT, self.request(cast_to, opts, stream=stream, stream_cls=stream_cls))
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/openai/_base_client.py", line 936, in request
via-server-1 | return self._request(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/openai/_base_client.py", line 996, in _request
via-server-1 | return self._retry_request(
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/openai/_base_client.py", line 1074, in _retry_request
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/openai/_base_client.py", line 1006, in _request
via-server-1 | raise APIConnectionError(request=request) from err
via-server-1 | openai.APIConnectionError: Connection error.
via-server-1 |
via-server-1 | 2025-07-03 13:54:24,578 ERROR Error initializing Context Manager: Failed to load Context Manager Process no.: 0
via-server-1 | 2025-07-03 13:54:24,578 INFO Stopping VIA Stream Handler
via-server-1 | 2025-07-03 13:54:24,578 INFO Stopping VLM pipeline
via-server-1 | 2025-07-03 13:54:25,578 INFO Stopped VLM pipeline
via-server-1 | 2025-07-03 13:54:25,578 INFO Stopped VIA Stream Handler
via-server-1 | 2025-07-03 13:54:25,579 ERROR Traceback (most recent call last):
via-server-1 | File "/opt/nvidia/via/via-engine/via_stream_handler.py", line 480, in __init__
via-server-1 | self._create_ctx_mgr_pool(config)
via-server-1 | File "/opt/nvidia/via/via-engine/via_stream_handler.py", line 536, in _create_ctx_mgr_pool
via-server-1 | ContextManager(config=config, process_index=self.num_ctx_mgr)
via-server-1 | File "/usr/local/lib/python3.10/dist-packages/vss_ctx_rag/context_manager/context_manager.py", line 278, in __init__
via-server-1 | Exception: Failed to load Context Manager Process no.: 0
via-server-1 |
via-server-1 | 2025-07-03 13:54:25,579 ERROR Failed to load VIA stream handler - CA-RAG setup failed.
via-server-1 |
via-server-1 |
via-server-1 | File "/opt/nvidia/via/via-engine/via_stream_handler.py", line 485, in __init__
via-server-1 | raise (ValueError("CA-RAG setup failed.")) from e
via-server-1 | ValueError: CA-RAG setup failed.
via-server-1 |
via-server-1 |
via-server-1 | via_exception.ViaException: ViaException - code: InternalServerError message: Failed to load VIA stream handler - CA-RAG setup failed.
via-server-1 | Killed process with PID 83
LLM (meta/llama-3.1-8b-instruct) is accessible and working via shell using POST request, base_url in config.yaml is updated as required, docker commands without sudo.
With disabled Guardrails and CA-RAG VSS pipeline starts.
Thanks in advance!
