I’m looking to buy a Jetson Nano so that I can experiment with low latency upscaling of an input video stream. For this I need to know if the Jetson Nano supports VK_PRESENT_MODE_IMMEDIATE_KHR among other things. Can someone post the results of vulkaninfo here?
Please check
$ vulkaninfo
VULKAN INFO
Vulkan Instance Version: 1.2.70
Instance Extensions:
Instance Extensions count = 16
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities: extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2: extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities: extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
VK_EXT_debug_report : extension revision 9
VK_EXT_debug_utils : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
Layers: count = 0
Presentable Surfaces:
'DISPLAY' environment variable not set... skipping surface info
None found
Device Properties and Extensions :
GPU0
VkPhysicalDeviceProperties:
apiVersion = 0x402083 (1.2.131)
driverVersion = 134332672 (0x801c100)
vendorID = 0x10de
deviceID = 0x93ba03d7
deviceType = INTEGRATED_GPU
deviceName = NVIDIA Tegra X2 (nvgpu)
VkPhysicalDeviceLimits:
maxImageDimension1D = 32768
maxImageDimension2D = 32768
maxImageDimension3D = 16384
maxImageDimensionCube = 32768
maxImageArrayLayers = 2048
maxTexelBufferElements = 0x8000000
maxUniformBufferRange = 0x10000
maxStorageBufferRange = 0xffffffff
maxPushConstantsSize = 256
maxMemoryAllocationCount = 4294967295
maxSamplerAllocationCount = 4000
bufferImageGranularity = 0x400
sparseAddressSpaceSize = 0xffffffffffffffff
maxBoundDescriptorSets = 32
maxPerStageDescriptorSamplers = 1048576
maxPerStageDescriptorUniformBuffers = 15
maxPerStageDescriptorStorageBuffers = 1048576
maxPerStageDescriptorSampledImages = 1048576
maxPerStageDescriptorStorageImages = 1048576
maxPerStageDescriptorInputAttachments = 1048576
maxPerStageResources = 4294967295
maxDescriptorSetSamplers = 1048576
maxDescriptorSetUniformBuffers = 90
maxDescriptorSetUniformBuffersDynamic = 15
maxDescriptorSetStorageBuffers = 1048576
maxDescriptorSetStorageBuffersDynamic = 16
maxDescriptorSetSampledImages = 1048576
maxDescriptorSetStorageImages = 1048576
maxDescriptorSetInputAttachments = 1048576
maxVertexInputAttributes = 32
maxVertexInputBindings = 32
maxVertexInputAttributeOffset = 0x7ff
maxVertexInputBindingStride = 0x800
maxVertexOutputComponents = 128
maxTessellationGenerationLevel = 64
maxTessellationPatchSize = 32
maxTessellationControlPerVertexInputComponents = 128
maxTessellationControlPerVertexOutputComponents = 128
maxTessellationControlPerPatchOutputComponents = 120
maxTessellationControlTotalOutputComponents = 4216
maxTessellationEvaluationInputComponents = 128
maxTessellationEvaluationOutputComponents = 128
maxGeometryShaderInvocations = 32
maxGeometryInputComponents = 128
maxGeometryOutputComponents = 128
maxGeometryOutputVertices = 1024
maxGeometryTotalOutputComponents = 1024
maxFragmentInputComponents = 128
maxFragmentOutputAttachments = 8
maxFragmentDualSrcAttachments = 1
maxFragmentCombinedOutputResources = 16
maxComputeSharedMemorySize = 0xc000
maxComputeWorkGroupCount[0] = 2147483647
maxComputeWorkGroupCount[1] = 65535
maxComputeWorkGroupCount[2] = 65535
maxComputeWorkGroupInvocations = 1536
maxComputeWorkGroupSize[0] = 1536
maxComputeWorkGroupSize[1] = 1024
maxComputeWorkGroupSize[2] = 64
subPixelPrecisionBits = 8
subTexelPrecisionBits = 8
mipmapPrecisionBits = 8
maxDrawIndexedIndexValue = 4294967295
maxDrawIndirectCount = 4294967295
maxSamplerLodBias = 15.000000
maxSamplerAnisotropy = 16.000000
maxViewports = 16
maxViewportDimensions[0] = 32768
maxViewportDimensions[1] = 32768
viewportBoundsRange[0] =-65536.000000
viewportBoundsRange[1] = 65536.000000
viewportSubPixelBits = 8
minMemoryMapAlignment = 64
minTexelBufferOffsetAlignment = 0x10
minUniformBufferOffsetAlignment = 0x100
minStorageBufferOffsetAlignment = 0x10
minTexelOffset = -8
maxTexelOffset = 7
minTexelGatherOffset =-32
maxTexelGatherOffset = 31
minInterpolationOffset =-0.500000
maxInterpolationOffset = 0.437500
subPixelInterpolationOffsetBits = 4
maxFramebufferWidth = 32768
maxFramebufferHeight = 32768
maxFramebufferLayers = 2048
framebufferColorSampleCounts = 15
framebufferDepthSampleCounts = 15
framebufferStencilSampleCounts = 31
framebufferNoAttachmentsSampleCounts = 31
maxColorAttachments = 8
sampledImageColorSampleCounts = 15
sampledImageDepthSampleCounts = 15
sampledImageStencilSampleCounts = 31
sampledImageIntegerSampleCounts = 15
storageImageSampleCounts = 15
maxSampleMaskWords = 1
timestampComputeAndGraphics = 1
timestampPeriod = 1.000000
maxClipDistances = 8
maxCullDistances = 8
maxCombinedClipAndCullDistances = 8
discreteQueuePriorities = 2
pointSizeRange[0] = 1.000000
pointSizeRange[1] = 2047.937500
lineWidthRange[0] = 1.000000
lineWidthRange[1] = 64.000000
pointSizeGranularity = 0.062500
lineWidthGranularity = 0.062500
strictLines = 1
standardSampleLocations = 1
optimalBufferCopyOffsetAlignment = 0x1
optimalBufferCopyRowPitchAlignment = 0x1
nonCoherentAtomSize = 0x40
VkPhysicalDeviceSparseProperties:
residencyStandard2DBlockShape = 1
residencyStandard2DMultisampleBlockShape = 1
residencyStandard3DBlockShape = 1
residencyAlignedMipSize = 0
residencyNonResidentStrict = 1
Device Extensions count = 92
VK_KHR_8bit_storage : extension revision 1
VK_KHR_16bit_storage : extension revision 1
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_buffer_device_address : extension revision 1
VK_KHR_create_renderpass2 : extension revision 1
VK_KHR_dedicated_allocation : extension revision 3
VK_KHR_depth_stencil_resolve : extension revision 1
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_device_group : extension revision 4
VK_KHR_draw_indirect_count : extension revision 1
VK_KHR_driver_properties : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_imageless_framebuffer : extension revision 1
VK_KHR_maintenance1 : extension revision 2
VK_KHR_maintenance2 : extension revision 1
VK_KHR_maintenance3 : extension revision 1
VK_KHR_multiview : extension revision 1
VK_KHR_pipeline_executable_properties: extension revision 1
VK_KHR_push_descriptor : extension revision 2
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 3
VK_KHR_sampler_ycbcr_conversion : extension revision 14
VK_KHR_separate_depth_stencil_layouts: extension revision 1
VK_KHR_shader_atomic_int64 : extension revision 1
VK_KHR_shader_clock : extension revision 1
VK_KHR_shader_draw_parameters : extension revision 1
VK_KHR_shader_float16_int8 : extension revision 1
VK_KHR_shader_float_controls : extension revision 4
VK_KHR_shader_subgroup_extended_types: extension revision 1
VK_KHR_spirv_1_4 : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_swapchain : extension revision 70
VK_KHR_swapchain_mutable_format : extension revision 1
VK_KHR_timeline_semaphore : extension revision 2
VK_KHR_uniform_buffer_standard_layout: extension revision 1
VK_KHR_variable_pointers : extension revision 1
VK_KHR_vulkan_memory_model : extension revision 3
VK_EXT_blend_operation_advanced : extension revision 2
VK_EXT_buffer_device_address : extension revision 2
VK_EXT_calibrated_timestamps : extension revision 1
VK_EXT_conditional_rendering : extension revision 2
VK_EXT_conservative_rasterization : extension revision 1
VK_EXT_depth_clip_enable : extension revision 1
VK_EXT_depth_range_unrestricted : extension revision 1
VK_EXT_descriptor_indexing : extension revision 2
VK_EXT_discard_rectangles : extension revision 1
VK_EXT_display_control : extension revision 1
VK_EXT_external_memory_host : extension revision 1
VK_EXT_fragment_shader_interlock : extension revision 1
VK_EXT_global_priority : extension revision 2
VK_EXT_host_query_reset : extension revision 1
VK_EXT_index_type_uint8 : extension revision 1
VK_EXT_inline_uniform_block : extension revision 1
VK_EXT_line_rasterization : extension revision 1
VK_EXT_memory_budget : extension revision 1
VK_EXT_pipeline_creation_feedback : extension revision 1
VK_EXT_post_depth_coverage : extension revision 1
VK_EXT_sample_locations : extension revision 1
VK_EXT_sampler_filter_minmax : extension revision 2
VK_EXT_scalar_block_layout : extension revision 1
VK_EXT_separate_stencil_usage : extension revision 1
VK_EXT_shader_demote_to_helper_invocation: extension revision 1
VK_EXT_shader_subgroup_ballot : extension revision 1
VK_EXT_shader_subgroup_vote : extension revision 1
VK_EXT_shader_viewport_index_layer : extension revision 1
VK_EXT_subgroup_size_control : extension revision 2
VK_EXT_texel_buffer_alignment : extension revision 1
VK_EXT_transform_feedback : extension revision 1
VK_EXT_vertex_attribute_divisor : extension revision 3
VK_EXT_ycbcr_image_arrays : extension revision 1
VK_NV_dedicated_allocation : extension revision 1
VK_NV_dedicated_allocation_image_aliasing: extension revision 1
VK_NV_device_diagnostic_checkpoints : extension revision 2
VK_NV_fill_rectangle : extension revision 1
VK_NV_fragment_coverage_to_color : extension revision 1
VK_NV_framebuffer_mixed_samples : extension revision 1
VK_NV_coverage_reduction_mode : extension revision 1
VK_NV_geometry_shader_passthrough : extension revision 1
VK_NV_sample_mask_override_coverage : extension revision 1
VK_NV_shader_sm_builtins : extension revision 1
VK_NV_shader_subgroup_partitioned : extension revision 1
VK_NV_viewport_array2 : extension revision 1
VK_NV_viewport_swizzle : extension revision 1
VK_NVX_device_generated_commands : extension revision 3
VK_NVX_multiview_per_view_attributes: extension revision 1
VkQueueFamilyProperties[0]:
queueFlags = GRAPHICS | COMPUTE | TRANSFER | SPARSE
queueCount = 16
timestampValidBits = 64
minImageTransferGranularity = (1, 1, 1)
VkPhysicalDeviceMemoryProperties:
memoryHeapCount = 2
memoryHeaps[0] :
size = 4011069439 (0xef140fff) (3.74 GiB)
flags:
VK_MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryHeaps[1] :
size = 704643072 (0x2a000000) (672.00 MiB)
flags:
memoryTypeCount = 6
memoryTypes[0] :
heapIndex = 0
propertyFlags = 0x1:
VK_MEMORY_PROPERTY_DEVICE_LOCAL_BIT
memoryTypes[1] :
heapIndex = 0
memoryTypes[2] :
heapIndex = 0
propertyFlags = 0x7:
VK_MEMORY_PROPERTY_HOST_VISIBLE_BIT
VK_MEMORY_PROPERTY_HOST_COHERENT_BIT
memoryTypes[3] :
heapIndex = 0
propertyFlags = 0xb:
VK_MEMORY_PROPERTY_HOST_CACHED_BIT
memoryTypes[4] :
heapIndex = 1
propertyFlags = 0x21:
memoryTypes[5] :
heapIndex = 1
VkPhysicalDeviceFeatures:
alphaToOne = 1
depthBiasClamp = 1
depthBounds = 1
depthClamp = 1
drawIndirectFirstInstance = 1
dualSrcBlend = 1
fillModeNonSolid = 1
fragmentStoresAndAtomics = 1
fullDrawIndexUint32 = 1
geometryShader = 1
imageCubeArray = 1
independentBlend = 1
inheritedQueries = 1
largePoints = 1
logicOp = 1
multiDrawIndirect = 1
multiViewport = 1
occlusionQueryPrecise = 1
pipelineStatisticsQuery = 1
robustBufferAccess = 1
samplerAnisotropy = 1
sampleRateShading = 1
shaderClipDistance = 1
shaderCullDistance = 1
shaderFloat64 = 1
shaderImageGatherExtended = 1
shaderInt16 = 1
shaderInt64 = 1
shaderSampledImageArrayDynamicIndexing = 1
shaderStorageBufferArrayDynamicIndexing = 1
shaderStorageImageArrayDynamicIndexing = 1
shaderStorageImageExtendedFormats = 1
shaderStorageImageMultisample = 1
shaderStorageImageReadWithoutFormat = 1
shaderStorageImageWriteWithoutFormat = 1
shaderTessellationAndGeometryPointSize = 1
shaderUniformBufferArrayDynamicIndexing = 1
sparseBinding = 1
sparseResidency2Samples = 1
sparseResidency4Samples = 1
sparseResidency8Samples = 1
sparseResidency16Samples = 1
sparseResidencyAliased = 1
sparseResidencyBuffer = 1
sparseResidencyImage2D = 1
sparseResidencyImage3D = 1
shaderResourceMinLod = 1
shaderResourceResidency = 1
tessellationShader = 1
textureCompressionASTC_LDR = 1
textureCompressionBC = 1
textureCompressionETC2 = 1
variableMultisampleRate = 1
vertexPipelineStoresAndAtomics = 1
wideLines = 1
Format Properties:
FORMAT_UNDEFINED:
linearTiling FormatFeatureFlags:
None
optimalTiling FormatFeatureFlags:
None
bufferFeatures FormatFeatureFlags:
None
FORMAT_R4G4_UNORM_PACK8:
VK_FORMAT_FEATURE_SAMPLED_IMAGE_BIT
VK_FORMAT_FEATURE_BLIT_SRC_BIT
VK_FORMAT_FEATURE_SAMPLED_IMAGE_FILTER_LINEAR_BIT
VK_FORMAT_FEATURE_TRANSFER_SRC_BIT_KHR
VK_FORMAT_FEATURE_TRANSFER_DST_BIT_KHR
VK_FORMAT_FEATURE_UNIFORM_TEXEL_BUFFER_BIT
FORMAT_R4G4B4A4_UNORM_PACK16:
FORMAT_B4G4R4A4_UNORM_PACK16:
FORMAT_R5G6B5_UNORM_PACK16:
VK_FORMAT_FEATURE_COLOR_ATTACHMENT_BIT
VK_FORMAT_FEATURE_COLOR_ATTACHMENT_BLEND_BIT
VK_FORMAT_FEATURE_BLIT_DST_BIT
(skip....)
It is vulkaninfo of TX2 in Jetpack 4.6.4. It is same as Jetson Nano. For Vulkan support on Jetson platforms, please refer to
Vulkan Support on Jetson Linux | NVIDIA Developer
