Hello everyone! I want to ask that I am running Yolov4 in real time at 4.6 FPS using TensorRT but now what I want is to send the feed of the camera in real time from nano display LCD to a remote location that is 200 meters away. So how can I do it?
Is there any solution or whether I need to change something?
Kindly help as soon as possible because this is a part of my project and I an not able to move forward without the solution!
I am using Logitech C920 Pro USB webcam.
A valid usecase is to run RTSP streaming. You may check DeepStream SDK:
After the installation through SDKManager, you will see Yolo models in
/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo
Yolov4 is not inculded. You can try the default models first and then try to insert your model.
For RTSP streaming, you can enable it in sink group( type=4 ):
https://docs.nvidia.com/metropolis/deepstream/dev-guide/index.html#page/DeepStream_Development_Guide/deepstream_ref_app_deepstream_app.html#wwpID0E0TB0HA
