WARNING: The requested image's platform (linux/amd64) does not match the detected host platform (linux/arm64/v8)
how to fix this on spark ? WARNING: The requested image’s platform (linux/amd64) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
I think you will need to offer more details on what you’re trying to do and how you’re trying to do it before help can be offered.
a lot of docker containers from HF are built with linux/amd64 but spark has another arch
Hi, this is a larger topic than Spark alone; this is a discussion for how to generate ARM container images. One method is to raise the issue with HF and its projects.
another method is if you have the Dockerfile and sources to recreate the image, you can simply build an arm64 image:
docker buildx create --use
docker buildx build --platform linux/arm64 -t myimg:arm64 --load .
