I tried the following example to compute sum of an array using warp aggregated atomics. But it does not give the correct sum. Could anyone please suggest what is the mistake?
#include
#include <cuda.h>
#include <cuda_device_runtime_api.h>
#include <cuda_runtime.h>
#include <device_launch_parameters.h>
#include <math.h>
#include <string.h>
#include <cooperative_groups.h>
#include <time.h>
const int SUB_IMAGE_COUNT = 1;
const int NUM_ELEMENTS = 10;
namespace cg = cooperative_groups;
// warp-aggregated atomic increment
device int atomicAggInc(int *counter)
cg::coalesced_group active = cg::coalesced_threads();
int mask = active.ballot(1);
// select the leader
int leader = __ffs(mask) - 1;
// leader does the update
int res = 0;
if (active.thread_rank() == leader)
res = atomicAdd(counter, __popc(mask));
// broadcast result
res = active.shfl(res, leader);
// each thread computes its own value
return res + __popc(mask & ((1 << active.thread_rank()) - 1));
global void sum_approach2(double *dst, int *nres, const double *src)
int id = threadIdx.x + blockIdx.x * blockDim.x;
for (int i = id; i < NUM_ELEMENTS; i += gridDim.x*blockDim.x)
if(src[i] > 0)
dst[atomicAggInc(nres)] = src[i];
int main()
FILE A_f = fopen(“sample.txt”, “r”);
int i;
double h_A = (double)malloc(NUM_ELEMENTS sizeof(double));
if (A_f == NULL) { return 1; }
for (i = 0;i<NUM_ELEMENTS;++i) {
fscanf(A_f, “%lf”, &h_A[i]);
printf(“\n h_A[%d]=%0.15f \n”,i,h_A[i]);
double h_sum2 = (double)malloc(SUB_IMAGE_COUNT* sizeof(double));
for (i = 0;i<SUB_IMAGE_COUNT;++i) {
h_sum2[i]=0.0f;
int h_nres=0;
int *d_nres;
cudaMalloc(&d_nres, sizeof(int));
cudaMemset(d_nres, 0, sizeof(int));
double d_A,d_sum2;
cudaMalloc(&d_A, NUM_ELEMENTS sizeof(double));
cudaMalloc(&d_sum2, SUB_IMAGE_COUNT sizeof(double));
cudaMemcpy(d_A, h_A, NUM_ELEMENTS* sizeof(double), cudaMemcpyHostToDevice);
cudaMemcpy(d_sum2, h_sum2, SUB_IMAGE_COUNT* sizeof(double), cudaMemcpyHostToDevice);
sum_approach2<<<1, 10>>>(d_sum2, d_nres, d_A);
cudaDeviceSynchronize();
cudaMemcpy(&h_nres, d_nres, sizeof(int), cudaMemcpyDeviceToHost);
cudaMemcpy(h_sum2,d_sum2, SUB_IMAGE_COUNT* sizeof(double), cudaMemcpyDeviceToHost);
// Generate host output with host filtering code.
int host_flt_count=0;
for (int i=0; i < NUM_ELEMENTS; i++)
if (h_A[i] > 0)
h_A[host_flt_count++] = h_A[i];
printf(“\nWarp Aggregated Atomics %s \n”, host_flt_count == h_nres ? “PASSED” : “FAILED”);
printf(“\n Approach 2: Final Sum = %0.15f \n”, h_sum2[0]);
return 0;
Sample input:
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
output got is:
Approach 2: Final Sum = 1.00000
