Thank you for your answer.
I’m using the latest version of Visual Fortran and the CUDA Fortran Compute Capability setting is set to automatic. Could you tell me how to set compute capability manually using command line?
Also, I wrote a simple vector addition code to compare the number of registers in CUDA C and CUDA Fortran. The CUDA C code uses 12 registers and CUDA Fortran uses 16. That’s fine but I found that the code uses 22 registers if I declare device variables under the module ‘vectorDevice’ (so I don’t need to pass those as arguments to the kernel). Below is the code that declares the device variables in the host code.
module vectorDevice
contains
attributes(global) subroutine vectorAddKernel(C, A, B, size)
implicit none
integer, value :: size
integer :: i, n
integer, dimension(:) :: A, B, C
i = (blockIdx%x - 1) * blockDim%x + threadIdx%x
if (i .le. size) then
do n = 1, 20
C(i) = C(i) + A(i) + B(i)
end do
end if
end subroutine vectorAddKernel
end module vectorDevice
program vectorFortran
use cudafor
use vectorDevice
implicit none
integer :: inputSize, gridSize, blockSize, n, m, cValue
logical :: valid
integer, dimension(:), allocatable :: h_A, h_B, h_C
integer, device, dimension(:), allocatable :: d_A, d_B, d_C
inputSize = 100000
allocate(h_A(inputSize), h_B(inputSize), h_C(inputSize))
allocate(d_A(inputSize), d_B(inputSize), d_C(inputSize))
h_A = 1
h_B = 2
d_A = h_A
d_B = h_B
blockSize = 1024
gridSize = ceiling(real(inputSize) / blockSize)
call vectorAddKernel<<<gridSize, blockSize>>>(d_C, d_A, d_B, inputSize)
h_C = d_C
valid = .true.
do n = 1, inputSize
cValue = 0
do m = 1, 20
cValue = cValue + h_A(n) + h_B(n)
end do
if (h_C(n) .ne. cValue) then
valid = .false.
print *, "Invalid !!!", h_C(n), ":", cValue
exit
end if
end do
if (valid .eq. .true.) then
print *, "Valid !!!"
end if
deallocate(h_A, h_B, h_C)
deallocate(d_A, d_B, d_C)
end program vectorFortran
Thank you for your help.
