We want to use GPU+DLA. How do I use DLA when converting onnx to trt model? Is there a python sample
Please find an example in the below topic:
This is my code to convert the onnx model to the trt model. Is the part of the DLA code configured correctly? Do I need to configure DLA-related information for subsequent inference work? How do I know that DLA is working?
def build_engine():
"""Takes an ONNX file and creates a TensorRT engine to run inference with"""
EXPLICIT_BATCH = 1 << (int)(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
with trt.Builder(TRT_LOGGER) as builder, \
builder.create_network(EXPLICIT_BATCH) as network, \
trt.OnnxParser(network, TRT_LOGGER) as parser, \
builder.create_builder_config() as config:
builder.max_workspace_size = 1 << 28
builder.max_batch_size = 1
#导入到DLA
config.max_workspace_size = 1 << 28
config.set_flag(trt.BuilderFlag.GPU_FALLBACK)
config.set_flag(trt.BuilderFlag.FP16)
config.default_device_type = trt.DeviceType.DLA
config.DLA_core = 0
if builder.platform_has_fast_fp16:
builder.fp16_mode = True
print('Loading ONNX file from path {}...'.format(onnx_file_path))
with open(onnx_file_path, 'rb') as model:
print('Beginning ONNX file parsing')
if not parser.parse(model.read()):
print("errors:")
for error in range(parser.num_errors):
print(parser.get_error(error))
print('Completed parsing of ONNX file')
engine = builder.build_cuda_engine(network)
print("Completed creating Engine")
with open(engine_file_path, "wb") as f:
f.write(engine.serialize())
return engine
You can check this through the TensorRT log.
For example:
TRT_LOGGER = trt.Logger(trt.Logger.INFO)
def build_engine():
Then it is expected to see the detailed layer placement information like below:
[07/12/2021-13:54:22] [I] [TRT] --------------- Layers running on DLA:
[07/12/2021-13:54:22] [I] [TRT] {Convolution28}, {ReLU32,Pooling66,Convolution110}, {ReLU114,Pooling160}, {Plus214},
[07/12/2021-13:54:22] [I] [TRT] --------------- Layers running on GPU:
[07/12/2021-13:54:22] [I] [TRT] (Unnamed Layer* 0) [Constant] + Times212_reshape1, (Unnamed Layer* 16) [Constant] + shuffle_(Unnamed Layer* 16) [Constant]_output, (Unnamed Layer* 3) [Constant] + (Unnamed Layer* 4) [Shuffle] + Plus30, (Unnamed Layer* 9) [Constant] + (Unnamed Layer* 10) [Shuffle] + Plus112, Times212_reshape0, Times212, shuffle_Times212_Output_0,
