I was kinda bothered that I either had to use the Nvidia Sync Dashboard to see the GPU utilization (not showing CPU) or something like btop to see the CPU/memory, but w/o GPU utilization. I created a monitor, specially for the DGX, showing all 20 Cortex cores (grouped by high performance vs. efficiency) plus the GPU. Also, Memory view distinguishes between GPU-used and CPU-used memory. Otherwise (except that it is a WebUI and not a terminal app) it looks very btop-ish. It can either be run as systemd service (own install target) or as a simple SEA executable (i.e. via Nvidia Sync)… GitHub - ollidraese/vanmon: A (WebUI-based) system monitor, specialized for Nvidia DGX Spark (GB10). · GitHub
Related topics
| Small monitor program for DGX Spark | 18 | 1668 | April 1, 2026 | |
| A TOP monitor program specific for the DGX SPARK | 9 | 3477 | March 16, 2026 | |
| Native Monitoring Terminal App | 1 | 273 | May 25, 2026 | |
| DGX Dashboard metrics | 5 | 1329 | October 27, 2025 | |
| Minimalistic dashboard for the DGX Spark / GB10 | 0 | 305 | September 10, 2026 | |
| Monitoring NVIDIA DGX Spark (GB10) with Prometheus + Grafana | 4 | 963 | August 17, 2026 | |
| CPU Utilisation on the DGX Dashboard | 2 | 281 | November 17, 2025 | |
| [Community project] A dependency-free monitoring dashboard built for the DGX Spark | 6 | 847 | July 23, 2026 | |
| Monitoring GPU utilization of dGPU on DRIVE AGX Pegasus | 12 | 2678 | April 30, 2021 | |
| Dgxtop v2: unified memory visualization and GPU process history for DGX Spark | 0 | 182 | October 12, 2026 |
