Ihave a GPU kernel which is throwing a Cuda error return code = 30 [nebulous something is wrong error]. I find that I can eliminate the error with the addition of a single lineof code that changes a float variable i calculated:
[font=Consolas][I am running Cuda 4.0 on a Win 7 box with a Fermi processor: GT 430][/font]
Thisthrows the error:
[font=Consolas]float F = w00 * x00 + w10* x10 + w01 * x01 + w11 * x11; // x are 4 data values;w are 4 weights between 0 and 1.0[/font]
[font=Consolas] int pOffset = ((y * nss +x) * MSI_LIVE + nc); // pointer to output pixel x 4 bytes/DTYPE [/font]
[font=Consolas] float *pOutPix;[/font]
[font=Consolas] pOutPix = (pOut + pOffset); // pOut is a pointer to global memory[/font]
[font=Consolas] [/font][font=Consolas] //F=123.456;[/font]
[font=Consolas] if (pOffset >= 0 &&pOffset < maxyO) // check in bounds[/font]
[font=Consolas] *pOutPix = F; // store result in global memory[/font]
[font=Consolas] [/font]If I uncomment the line F=123.456; then it runswithout an error – return code = 0 !
[font=Calibri] [/font]So something is fishy about F some of the time. I have tested for F == NULL but that doesn’t help. Nvcc wont let me do a try/catch block.
[font=Calibri]Any other suggestions on how to test for bad F ? How could it be bad ? underflow ?? [/font]
[font=Calibri]typical values of F are [-5000.0:5000.0][/font]
