Hi there, while I was studying the Unified Memory I am encountering an illegal memory access that I can’t really figure out.
That’s the code (heavily taken from code-samples/dataElem_um_c++_2.cu at master · NVIDIA-developer-blog/code-samples · GitHub):
It is running on Windows 10, with CUDA 11.4 on a GTX 1080 Ti
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include <stdio.h>
#include <iostream>
#include <cstring>
class Managed {
public:
void *operator new(size_t len) {
void *ptr;
printf("Copying memory (managed class): size_it is %i\n", len);
cudaMallocManaged(&ptr, len);
cudaDeviceSynchronize();
printf("Returning ptr!\n");
return ptr;
void operator delete(void *ptr) {
cudaFree(ptr);
__host__ __device__ bool cuStrcmp(const char *a, const char *b) {
bool str_end_a = false;
bool str_end_b = false;
int i = 0;
while (!(str_end_a || str_end_b)) {
if (a[i] == '\0')
str_end_a = true;
if (b[i] == '\0')
str_end_b = true;
if (a[i] != b[i]) {
return false;
i++;
return (str_end_a && str_end_b);
class cuString : public Managed {
private:
char * s;
short int length;
cuString();
void copyConstChar(const char * input) {
length = (short int)strlen(input) + 1;
printf("Copying char array of size %i\n", length);
cudaMallocManaged(&s, length);
memcpy(s, input, length);
public:
cuString(const std::string& s) {
printf("String copy constructor\n");
copyConstChar(s.c_str());
cuString(const cuString& other) {
printf("cuString copy constructor\n");
length = other.length;
memcpy(s, other.s, length);
cuString(const char * input) {
copyConstChar(input);
__device__ __host__ unsigned short int get_length() const{
return length;
__device__ __host__ const char * c_str() const{
return s;
__device__ __host__ bool operator==(const cuString& other) const{
if (length != other.length)
return false;
short int i = 0;
for (; i < length; i++)
if (s[i] != other.s[i])
return false;
return true;
__device__ __host__ bool operator==(const char* other) const {
return cuStrcmp(s, other);
~cuString() {
printf("Freeing cuStr memory\n");
cudaFree(s);
class DataElem : public Managed {
public:
const cuString str2;
const double t;
__host__ std::string get_str2() {
return std::string("str2");
DataElem() :str2("prova2"), t(5.0) {};
__global__ void printKernel(DataElem* p) {
printf("(device) PP is %f\n", p->t);
printf("(device) PP is (%s; %f)\n", p->str2.c_str(), p->t);
if (p->str2.c_str() == "teststring")
printf("Hey, operator works!\n");
else
printf("Hey, operator also works!\n");
__host__ void printKernelHost(DataElem* p) {
printf("(host) PP is (%s; %s; %f)\n", p->str2.c_str(), p->str2.c_str(), p->t);
else
int main()
std::string s = "teststring";
// cuString * cu = new cuString(s);
DataElem * p = new DataElem();
printKernelHost(p);
printKernel << <1, 1 >> > (p);
cudaError_t cudaerr = cudaDeviceSynchronize();
if (cudaerr != cudaSuccess)
printf("kernel launch failed with error \"%s\".\n",
cudaGetErrorString(cudaerr));
return 0;
The output is:
Copying memory (managed class): size_it is 24
Returning ptr!
Copying char array of size 5
(host) PP is (test; test; 5.000000)
(device) PP is 0.000000
kernel launch failed with error "an illegal memory access was encountered".
The weird thing is that if, I swap the order of const cuString str2 and const double t; in the class DataElem, thus it becomes:
public:
const double t;
The output now is:
Returning ptr!
(device) PP is 5.000000
(device) PP is (test; 5.000000)
And it works correctly. Can someone help me what’s happening here? Sorry if the code is messy.
Thank you for your help!
