Welcome! Please Read before Posting
Before posting a new topic, please follow the instructions below
  1. Check out our FAQ to see if your questions is answered there: DGX Spark / GB10 FAQ - #7
  2. Search through the other topic and see if someone else has posted about the same issue
  3. If you create a new issue, please provide a detailed description of the issue as well as any reproduction steps you can share. Also follow the directions here so we can best assist you: *** If you have a problem PLEASE read this first ***
If you have received an answer or otherwise solved your issue, make sure to mark the related reply as the Answer so others can easily see.
